Question about Car Audio & Video
I have drivers 1-826-085-11 and i cant find out there wattage or how many ohms they are. Please help. Thanks.
Can I bridge my 1200watt 2channel sony xplod amplifier?
How many ohms at two channels, remenber ohms law, amp should be stable at lower ohm RMS wattage..whenn you say 1200 watts its that full wattage, now you got a RMS wattage..What is it?
Apr 04, 2016 | Sony Car Audio & Video
I am needing to replace my piezo drivers for the S715 cabinets and they are 8 ohm 15 watt drivers. Will these cabinets only safely handle 15 watts, or can I replace them with higher wattage drivers? I am...
No worries here, in fact you can attach a non-piezo hf driver, coupled with a 2.2uf/3.3uf MKT filter and that should do the job with ease, even better than with piezoelectric devices, hope this helps...
Sep 14, 2013 | Phonic Powerpod 740 Plus S715 PA System
I dont know how many watts it is
4 Ohm Stereo Power (RMS): 250W X 2
4 Ohm Mono Power (RMS): 850W X 1
2 Ohm Stereo Power (RMS): 450W X 2
Signal-to-noise ratio: 100 dB
Frequency Response: 5 Hz - 50 KHz
Total Harmonic Distortion: 0.05%
Input Sensitivity: 200mV-4V
Length: 16.93"
Width: 11.66"
Height: 2.37"
Continuously variable 0 - 18dB Bass Boost
Built-in continuously variable 18dB per octave crossover, from 50Hz to 250Hz
Dec 23, 2010 | Concept CC-2502 Car Audio Amplifier
I have just bought a used Sony Integrated amplifier TA- F210 and it didn't come with the owner's manual so I don't know the RMS wattage to enable me connect speakers with the appropriate wattage. Could...
Hi, I brought a Sony TA-F-210 new back in 1990 $ 650 NZ , and has been a very .. very good amp. Earthquake ruined it !! I still have the owners manuel and it says for UK and other countrys DIN, 1 kHz, 8 ohms . 70w + 70w . or . 20Hz-20kHz THD 0.05%, 8 ohms . 50w + 50w Hope this helps. Have been running big old 3 way 8 ohm 50w speakers for all its life and it grunts.. or did !! Nobody belived me I was running only 50w speakers !! I dont know what I will replace it with.. You will enjoy. Might look for another one ! Wayne.. NZ CHCH
Nov 26, 2010 | Audio Players & Recorders
What is the wattage capacity of Sound Tech CX4C PA Speaker? yeah! brand: Sound Tech/ model CX4C. thanks..
SOUNDTECH CX4C 2-way monitor wedges (2).
380 Watts Power / 190 Watts RMS, Full Range 2-way, 12" speaker, 1" Compression Driver(horn). Carpet Covered, Pole Mount capable, 8 ohm.
Impedance - 8 ohm
Woofer Size - 12"
Magnet Weight - .
Voice Coil Dia. -
H.F. Driver/Exit - 1"/Compression
RMS Power Rating - 190W RMS(8 Ohms)
Dimensions - 18.5"w x 16"d x 27"h
Weight - 52(lbs.)
Aug 31, 2010 | Sound Design Lifeworks Technology iHome...
Burned out 450 Ohm resistor. Where can I get a new
Mouser electronics.
some surplus places like all electronics.
Please make sure you purchase the right wattage... sorry covering by bases for you...
cant goto Radio shack and get a 470 Ohm resister in a 1/2 watt... it will burn up...
check the additional markings on the bad one...
May 15, 2010 | Food Processors
A3200e wattage
Here are some specs:
  • 4800W Max, High-Current 2-Channel Car Amplifier
  • RMS Power Rating:
    • 300 watts x 2 chan. @ 4 ohms
    • 600 watts x 2 chan. @ 2 ohms
    • 1200 watts x 2 chan. @ 1 ohm
    • Bridged:
      • 600 watts x 1 chan. @ 4 ohms
      • 1200 watts x 1 chan. @ 2 ohms
      • 2400 watts x 1 chan. @ 1 ohm
  • Max Power Output: 4800 watts @ 1 ohm
  • this is the web site I got the specs from
  • Hope this Helps...
  • Jul 22, 2009 | AudioBahn A2300HCT Car Audio Amplifier
    Whirlpool side-by-side - Model ED25RQXYW02 Light burned out on fridge side - replaced bulb but still no light? Is there also a fuse someplace? Thanks, Dave
    What a compliment. Thanks, Dave!
    I was off on the ohms, though, I was figuring on a lower wattage bulb -- the higher the wattage the lower the ohms.
    May 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Which speakers can I use?
    You can use any wattage speakers as long as they are not less than the watts from your amp. However you can still use lower wattage speakers as long as you don't turn up the volume full or two loud! Otherwise your damage the speaker.
    HOWEVER you must get the ohms matched up right. You must never connect any speaker with a low Ohm to a high rated amp. Or you will blow the output stage transistors or IC.
    Most Amps are 8 ohms, so you could connect an 8 or 16 etc, but not a 4 ohm.
    Dec 10, 2008 | Audio Players & Recorders
    Kicker l7 dvc 2 ohm wired to sony xplod xm1652z amplifier isnt pushing the sub
    it is not the way how get most wattage from your amp. If it is rated to drive a 4-ohm load then it should be ok for a 4-ohm load. If it is rated for a 2-ohm load, then you should not be loading less than that impedance. I recommend a 4-ohm load.
    Take note: it is the sound quality from the source that makes up all the total quality of your audio system. If you are overdriving the amps it will give distortion too.
    There are many factors to consider when it comes to quality of a car sound system- speaker enclosure design, choice of speaker or driver, equalization, etc...
    One more thing, try to get at least no voltage drops if you are wiring the subwoofer amp away from the car's battery.
    hope this helps.
    Oct 17, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
    Car Audio & Video Logo
    121 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
