Question about Garden
My weedeating runs fine but when you throttle up the head barely spins. Where do I start
    Top Expert:
  • Garden Master
  • 12,962 Answers
The clutch is slipping badly.
Posted on Apr 23, 2017
smartr10U
  • 1305 Answers
SOURCE: weedeater starsts and ildes won't run or accelerate
Make sure your gas supply is fresh...not from last year...
Secondly, clean and service the air filter element... you may need to reoil it before installation...check your manual.
Disconnect the fuel line and drain it and what little is in the carb...push on the prime bulb if it's got one...
Then with a clean air filter and fresh gas... give it a start and after start, disengage the choke..
Let me know how you do..
K
Posted on May 28, 2009
#1 Taper
  • 1040 Answers
SOURCE: Weedeater won't take fuel
You need to remove the carb., disassemble and spay with carb. cleaner. Use a Den Tek Brush, (used for cleaning between teeth), toclean the small portals in carb. Check the small screen. It could have dirt clogged in it. Reasseble and start. If it still doesn't run properly, you will need to buy a carb. kit and replace the screen, needle valve, gasket(s), & diaphragm.
Jim
Posted on Jun 05, 2009
lemmingleejn
  • 173 Answers
SOURCE: Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Posted on Jul 25, 2009
SOURCE: brand new tanaka weedeater, ran fine for 10 minutes,
Just had the exact same problem there is a washer located in there that needs to come out then turn the bras thingy around #18 in parts diagram then put the washer on the outside to space cutting attachment. Manufacturer is an idiot!! Make sure your clutch didn't burn out in the process.
Posted on Aug 16, 2009
MOTORWIZJ
  • 1363 Answers
SOURCE: I have a Poulan WeedEater. It had trouble
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
Ryobi weedeater throttle not working
Check the throttle cable connection at the carburetor throttle linkage, it (cable) may be broken or the carburetor linkage is broke.
Jul 09, 2016 | Ryobi Garden
Weedeater and Homelite shafts interchangeable?
Just give it a try. Some different brands will interchange. I have done this with a Toro and it is still running.
May 18, 2014 | Homelite Garden
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
Hi i have a echo weed eater. It starts with only a couple of pulls and the runs great and sounds great. when i have the head up in the air it spins rather quickly but when i hit grass the head starts to...
check the cable that runs through the shaft from engine to head, it may be brocken or striped but when theres no pressure on the head it spins ok
Jul 24, 2011 | Garden
My weedeater 150 mph starts hard and barely runs at full throttle. I put in new gas, plug, and clean air filter. Please help. John
One cause of such a symptom could be an obstructed exhaust. Make sure the outlet of the muffler is not obstructed (ex. dirt dobber nest), also check the exhaust port by removing the muffler.
Feb 16, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
My weedeater starts and runs fine, but the head won't spin.
The drive shaft is not seated into position properly or the shaft has broken. Have you had the shaft off recently? If so, take the shaft off again and try to seat the shaft as you gently pull on the rope. If you need further assistance, just let me know.
Jim
Jun 08, 2009 | Garden
Jim
Jun 04, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
