Question about The Computers & Internet
How can I reduce the number of screens retained in "recent screens"?
  • Ajika coates
    Ajika coates Apr 23, 2017
    Hi Rodger Fraase, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Only recently my portable heller air conditioner is oosing out buckets of water each night. does it mean it finished and needs replacement,
Portable air conditioners cool the air, and in so doing, dehumidify the air. The "buckets" of water are coming from the humid air in your environment, so you need to do things that will reduce humidity, of be prepared to empty the condensate receptacle fairly often.
Using a small room, closing doors and windows to the room you want cooled, avoiding cooking or heating water, reducing the frequency of people walking into/out of the room and limiting the number of people in the room will all help in reducing, and keeping low, the ambient humidity.
Jan 03, 2015 | Heating & Cooling
I need a manual for an Alcatel phone recently purchased from Radio Shack. Charlotte Szabo -- wunolqltr@yahoo.com
I purchased a new alcatel phone a couple of days ago and wanted
to retain my old phone number and transfer minutes, however,
ended up with new number and no transfer of minutes. HELP
Aug 10, 2013 | tracfone.com
Troubleshoot dell e5500
Depending upon your operating system, try reducing your resolution to something lower. If your resolution is currently at 1920 x 1600, reduce it down to 1280 x 1024. This should allow you back up & regroup.
On a blank portion of your screen, <Right Click> your mouse, choose "Properties" for Windows XP or "Screen Resolution" for Windows 7, for Windows XP go to the last tab, Find the Resolution slider or drop down menu and choose a lower resolution than the one you are currently using.
If your laptop is connected to an external monitor, use the monitor menu buttons to recenter and shrink the image back to factory settings.
Good Luck. Dell Certified Systems Engineer - DellTech1
May 03, 2013 | Dell Superb Choice Laptop Replacement...
The top part (about one third) of my SyncMaster 920LM screen is brighter than the rest and seems to retain simultaneously the new and the previous picture for 2 to 3 seconds before it gradually fades out...
This is usually do to a section of your controller chips dying. This is not fixable by the end user, the only thing I could say to try is to try different resolutions to see if you can reduce the issue.
Mar 15, 2011 | Samsung SyncMaster 920LM 19" LCD Monitor
Hi, I have a Bosch Dishwasher. Can't see the model number. Recently the spray pressure from the middle and top nozels have reduced. I've taken the nozels of and run the m/c up; seems that the pump...
Either there is corrosion in the water lines or the arms themselves. Calcium and water deposit buildup can reduce pressure. If all these are clean and it is the same, then you likely have a clogged or worn pump
Nov 16, 2009 | Kitchen Ranges
The the width of the picture on my Monitor is reduced.
hi
you may click the right button of your mouse and go to the properties.From there you can adjust the screen resolution.
Jul 01, 2009 | Computers & Internet
Acer aspire 3050 black
refer to ur user manual to see which key for brightness e.g.fn+f 9
(reduce brightness)if havnt got one can easily download one of net.try to swich screen to monitor.connect external moniter and press fn+f 5.(refer to manual maybe different key)
press down and release screen lid button see if any response.if all fail need to disassemble.
remove screw in about middle of pc underneath.this ia retainer screw for key board.remove screws dirrectly behind screen to remove plate with buttons.then can get access to keyboard and lift away (do not disconnect it just rest it on screen or front of pc )check cables from mother board to screen.check inverter.
all these are worth checking but initially sounds like inverter faulty.
Mar 05, 2008 | Computers & Internet
Touch Screen not working and fequently gives trouble
1st take back up of the data then  do softreset then see or try to reduce some data from ur mobile then try else visit service center
Gizmo1
Oct 09, 2007 | i-mate JAMin Smartphone
Computers & Internet Logo
56 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
