Question about Sewing Machines
Winding bobbin on 4411 with right tension
My bobbin fills but the thread is too loose
  • 209 Answers
Hello Joyce Strohl
This happens quite often when the thread is not totally engaged through the tension disc before reaching the empty bobbin. You can refer to page 12 or the free downloadable manual found at this link:
Note that the thread must winde around the tensioning device in a letter "e" style to be effective.
Place the "mushy" bobbin where the spool of thread normally resides and winde the mushy thread onto another empty bobbin .... this way there is no loss of good thread.
Happy Stitching
Posted on Apr 24, 2017
The thread winder is winding the thread too loose on the bobbin. How do I adjust that.
The thread usually goes through a tensioner on its way to the bobbin in the winding process. Check that you are threading the bobbin winding correctly, or possibly the tensioner is defective.
Depending on the make & model machine you have, you may be able to pick up a stand-alone bobbin winder (called a "Sidewinder" avlb at JoAnn's, Amazon, or other places) for ~$30. You can get it for battery and/or AC use. Just be sure that your particular machine's bobbins will work on the Sidewinder, as some do not. I find this little tool quite useful as it allows me to wind bobbins without unthreading my machine plus it saves wear and tear on my machine.
Nov 02, 2017 | Sewing Machines
My JUKI 1541 S thread winder is winding too loose. How do I adjust it?
Are you running your thread through the small tension at the upper right of the machine before you run it down to the bobbin? If you are and it is still loose, turn that small white knob to the right to increase the tension on your bobbin thread. If that doesn't seem to be working, pull the two tension discs apart that you have run the thread through, and see if there is a piece of thread or something caught between them that is not allowing the tension discs to close as they should.
Nov 01, 2017 | Juki Sewing Machines
When I rewind my boobin, the thread is too loose. How do I adjust it on a JUKI DNU 1541-S?
You're saying the thread on the bobbin is loose/sloppy? That would be a result of the tension placed on the bobbin during winding. Make sure you are using the correct threadpath to wind the bobbin, or the winding tension needs to be adjusted.
I can only get the bobbin wind up half way?
So the thread is filling only the bottom half of the bobbin? When winding (slowly), use a pencil, stilleto, or something similar and lift the thread between the thread tensioner and the bobbin to help fill the top of the bobbin. Your machine's winder probably needs an adjustment or the thread path for bobbin winding is not correct.
Oct 18, 2017 | Sewing Machines
Why is thread getting caught and unable to pick up the bobbin thread?
try tightening the needle thread tension as it appears to be too lose
try loosing of the bobbin thread tension a fraction as it may be to hard to pull out of the bobbin case under the spring
changing thread sizes and material thickness generally requires a tension adjustment of the threads
Sep 16, 2015 | Singer 4411 Heavy Duty Sewing Machine
Bobbin not winding tightly
BRAND new Janome 1420qdc. New needle, doesn’t need oil. Will NOT wind a bobbin. Used almost an entire spook of thread doing this. At my wits end. HELP!
Mar 28, 2012 | Janome Memorycraft 9700 Computerized...
Loose boobin winding
You need to ensure that the thread is going from the thread spool at the back of the machine, through the eyelet, then around the silver tension disc on top of the machine, then to the bobbin when you are winding it. Also, pull the thread tail up through the hole in your bobbin to start and hold the tail so the thread starts to fill smoothly and doesn't loosen.
I've marked the disc in red on this image
Please read my Tip on bobbin winding; its really important to get a good wind and you can add more tension yourself by applying gentle pressure to your thread spool on the back pin as you wind off it.
Link is
The stopping when full is possibly because your bobbin is winding unevenly but I never run it until it stops itself anyway, and do the winding at 3/4 speed, not flat out. You want a really smoothly tensioned even wind onto the bobbin so your thread comes off the bobbin when stitching with even tension, not stretched, then loose.
Hope this helps you with your problem.
Dec 14, 2011 | Elna Quilter's Dream 6003Q
The bobbin thread keeps breaking! It is very loose and then snaps?? I've replaced the needle to make sure it was sharp, I bought the highest grade thread I could find, adjusted the tension... then...
Sounds more like the way the bobbin has been wound, is it loose and uneven or tight and smooth. Is it properly into the tension spring? being loose doesn't sound right, a thread under correct bobbin tension is usually pretty firm.
Is it loaded into the bobbin holder the right way ?
Also check the bobbin itself hasn't been damaged in some way, not worn/bent. It needs to turn smoothly in the bobbin holder so if one edge has been bent a little this will cause problems.
When winding bobbins, you must have tension on the thread so it winds smoothly with consistent tension on the thread. Most machines have a little tension disc on top or the thread goes through the regular tensioner in order to achieve this. But I always wind bobbins at about 3/4 speed and also add a little extra tension by holding my scissors handle on top of the thread spool so it doesnt bounce around. Also start winding with a little tail pulled through a hole on top of the bobbin and wind until this starting end is covered, then stop and snip off the tail. Then continue winding and watch the thread, giving it a nudge so that it fills evenly across the bobbin, not just all in the middle.
Think of it like the garden hose reel; if you wind it really fast the hose all goes into the middle of the reel, then jams up and you can't get the whole hose onto it. Same thing, wind smoothly and evenly across the whole depth of the bobbin so that the thread is smooth and even. Then when the thread feeds off it will be smooth evenly tensioned and should stitch out evenly.
There is some good trouble shooting information on this page too which might help you to work out what is causing this thread breakage.
Jul 17, 2011 | Necchi Sewing Machines
Bobbin stich is uneven and a tangled mess
you can dowload a manual from the singer website
If the bottom stitching is uneven, its mostly the top thread not under tension correctly so check the tension dial and the threading up from the thread spool to the needle.
Also, review how you wind a bobbin, you want a nice smooth wind, not twisting or uneven build across the bobbin. The manual for this machine is pretty brief on this but bobbin winding is crucial to getting a good even flow from the bobbin when stitching seams. You want to wind thread smoothly onto the bobbin, across the full width of it, not just mainly in the middle. Give the thread a nudge with your finger tip to fill top and bottom as it winds.
Also, ensure the thread goes through the bobbin tension disc on top of the machine, and even then, use your scissors handle to put some downward gentle pressure onto the thread spool you are winding off so it doesn't jump or bounce as you wind. Wind the bobbin to 3/4 full, then stop.
And lastly, load the bobbin correctly following the manual directions, make sure it is turning the right way in the bobbin case. Also look at page 16, it shows the "dangle" test where you can check the tension on the bobbin case is right, you should be able to dangle the bobbin by the thread tail and it should "stay" but you should be able to pull on it to release thread too. Adjust the little tension screw in minute increments to get this right. Bobbin case tension springs can fail or break too, so check this out.
Hope this helps you; it is my experience that 90% of machine issues are caused by blunt or wrong sized needles, wrong threading, no tension or incorrect tension or lack of maintenance.
Apr 16, 2011 | White Sewing 1888 Mechanical Sewing...
Singer 7444 trouble winding bobbin
It sounds like you don't have any tension on the thread when winding the bobbin. Make sure that you are running the thread through the tension disc on the top of the machine before going to the bobbin winder.
Feb 28, 2009 | Singer 3116 Simple
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
