Question about The Office Equipment & Supplies
I have a2654 and it will not operate with key on any pos. except the ros. it has always been like this now my son wants it and i would like to fix it.
Error 061-321 xerox workcentre 5024 - Xerox Office Equipment & Supplies
061-321 ROS Motor Fail
BSD-ON: CH6.5
The number of rotation of the ROS Motor did not come within the standard range within the specified time (5 s) after the ROS Motor On.
Cause/Action
1. Turn the power OFF and ON.
2. Check whether the Drum Cartridge is installed.
3. Check the ROS Motor (Output Check [061-001]) for operation failure.
4. Check the LD +5VDC power supply of the LD PWB J140 pin-8.
5. If no problem is found, replace the following parts in sequence:
• ROS Assembly (PL 2.1)
• ESS/MCU PWB (PL 18.3)
http://turbobit.net/upqkewkg8xjt.html
Feb 18, 2017 | Xerox Office Equipment & Supplies
How can I fix my cash register with this E001error appearing always
You didn't finish the last sequence. Turn the key back to where you last had it (error will stop) then finish what you started in that mode before you turn the key.
Apr 05, 2015 | Casio PCR-T48S Cash Register
How i do may my power acoustik play in my truck.power go off and on ?
red pos key on, yellow always pos,blue sends pos to external amp or power antennae if none tape up- black wire neg. the rest pretty much speakers.
Feb 03, 2015 | 1994-1998 Chevy C2500 Truck 10 Piece...
Error mode x1
Press subtotal to exit whtever you were doing and then turn your key to Reg and operate
May 22, 2014 | Casio TE-2400 Cash Register
Reverse operating system
Check the switch down by the gear shift lever, and the wiring to the switch, if one of the wires has come off the switch it will give problems.
May 30, 2013 | Husqvarna YTH22V46 46 inch 22 HP Briggs &...
Engine shuts off when any drive gear is engauged
I hope you have fixed this by now. If you haven't It is possible that the ROS is malfunctioning. The tractor is equipped with a reverse operation system which allows the tractor to mow while backing up. It might be that the wiring in the switch or the shifter has become disconnected or broken.
For reference, the manual says this:
USING THE REVERSE OPERATION SYSTEM -
• Move motion control lever to neutral (N) position.
• With engine running, turn ignition key counterclockwise
to ROS "ON" position.
• Look down and behind before and while backing.
• Slowly move motion control lever to reverse (R) po si tion
to start movement.
• When use of the ROS is no longer needed, turn the
ignition key clockwise to engine "ON" position
Manual is available at: http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2007/NOUS2007-PB175H42LT-405327-96017000401.pdf
Jun 06, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
25 character product key for microsoft 2000
if you have the operating system still on the pc use this software to get the product key
http://www.magicaljellybean.com/keyfinder/
Oct 29, 2009 | Microsoft CompuRegister POS-1000 POS...
Docucolor 12 printing nothing from glass
The only fuses it could be are the 24v fuses going to the ROS. In general it would "normally" be the ROS and Halftone pwb or the Vsel pwb. Both of these might not be sitting right/loose ribbon cables etc, depending if you have been working in that area.
The other option is a defective cleaner clutch for the IBT. This "normally" leaves with just the black left on the print however. You will have to watch the machine and see if there is actually an image being produced on the drum. If not, the ROS (ROS and halftone pwb must always be replaced together)
Jan 19, 2009 | Xerox DocuColor 12 Color Copier
Error 10 laser unit failure on phaser 7700GX
That requires the replacement of either the ROS ( laser) assembly or the MCU board. I have seen both cause that code and indicate the laser has failed.
ROS is the laser assembly.
MCU board may not be detecting the ROS.
It is possible the connector that runs from the ROS to the board is loose, you may want to disconnect and reconnect that.
If the ROS is bad, you also have to have a laptop to connect to the machine to align the colors. That is called the regicon adjustment.
Apr 24, 2008 | Office Equipment & Supplies
23 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
