Question about Locks & Locksmithing
I may have turned the u-shaped portion of a TSA lock clockwise not counterclockwise when setting the pass code.
It is locked in the open position and I do not know what combination it was set on. Can I counteract what I have done?
  • 29 Answers
SOURCE: I just bought a new
Factory preset combo 0-0-0-5
Go to www.kryptonitelock.com/customerservice/FAQ.aspx
under "maintenance" download the pdf instructions.
GGBMDB
Posted on Dec 01, 2008
SOURCE: I HAVE THE TSA COMBINATION LOCK ON A SAMSONITE GRAVITON G LUX
I can't answer the problem - but am interested as we had an identical failure on holiday in South Africa. We had to force the case open as the lock and the mechanism seemed to have come adrift in that when moving the lever with the correct combination - the case neither opened or closed. I'm sending it back to Samsonite under warranty to hopefully get it repaired/replaced. I rang the UK number listed on the Samsonite website. Bit disappointed as Samsonite should be more reliable - particularly given the price of the case, at £295, isn't exactly cheap.
Posted on Oct 11, 2009
SOURCE: Problems to open a Samsonite TSA 007 lock on suitcase
Hi I have a problem to aopen my luggage I think my niece has change my security code accidentally , but now I cannot open my luggage can you please chelp me out?
Posted on Dec 04, 2009
SOURCE: how to unlock a tsa lock that I forgot combination
I have a new carlton misha cabin case and it has arrived with on of the zip arms in the lock and I cant get it to move and have not been given the code, could some one help please
Posted on Nov 13, 2010
SOURCE: bought a Magnum 3016 coil
Try 0005 (It worked for me)
Posted on Mar 08, 2011
How do I can unlock dial lock
The master dial lock is the world's best selling combination padlock.The lock uses three digit combination of 40 numbers.allowing for 15,00 possible variations
.Follow these step to unlock dial lock. 25284217-gdc3ufgmlwaqnv2deqjxyac2-5-0.jpg With the Combination Step 1 Turn the lock until the numbers read right-side-up. Roll the left-most dial until the first number of your combination lines up with the scored hash mark just to the left of the dial.
With the Combination Step 2 Roll the middle dial until the appropriate number lines up with the number to its left. Do the same for the right-most number. Your three-digit combination should now show, left to right, lined up with the scored hash marks.
With the Combination Step 3 Pull the body of the lock away from the U-shaped metal ring without turning any of the dials. The lock will click open to expose a hook. The hook spins 360 degrees so that it can be placed onto, and taken off, luggage.
Forgotten Combination Step 1 Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Forgotten Combination Step 2 Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Forgotten Combination Step 3 Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Resetting Your Combination Step 1 Hold the body of the lock so that the numbers face away from you. Set the combination and release the U-shaped ring.
Resetting Your Combination Step 2 Turn the hook of the U-shaped ring counterclockwise 90 degrees until the notch on the stem of the hook and the hole on the body of the lock line up. Push the stem of the hook down into the body of the lock as far as it will go.
Resetting Your Combination Step 3 Turn the hook another 90 degrees counterclockwise while it is depressed into the body of the lock.
Resetting Your Combination Step 4 Roll the dials until you have your new combination.
Resetting Your Combination Step 5 Turn the hook 90 degrees clockwise and raise the stem out of the body of the lock. Turn it another 90 degrees clockwise and push it back into the locked position. The lock now uses your new combination.
Sponsored Links
Luggage Trolleys Supplier
Supplies Made to Order from World's Largest Supplier Base. Top Deals!
www.alibaba.com $0.01 Web Hosting
Scalable, Secure Web Hosting. Try Our Award-Winning Service Now!
www.hostgator.com/1Penny Rooftop Air Conditioner
low noise, high static pressure. Made in China, Inquire Now!
www.airconditionings.cn Download Facebook Apps
Get The Most Popular Apps For The Largest Social Network. Join Now!
www.facebook.com by Taboola
Sponsored Links
Move Over, Turkey: 9 Side Dishes that Will Steal the ShowKraft Recipes See Another Side of Dubai in HattaDepartment of Dubai Tourism & Commerce Marketing by AFAR
Email Best Practices: Sending Emails That Won't Be IgnoredRackspace
TIP
  • Email yourself the password to your lock, and title the email "Luggage Lock." If you forget the password in the future, simply search your email for the term "Luggage Lock."
WARNING
  • Do not open a lock that does not belong to you. It is against the law.
REFERENCES
RESOURCES
ABOUT THE AUTHOR Christopher Michael began writing in 2004 for his college newspaper. He received a Bachelor of Arts in English and psychology, as well as a certificate in criminal justice from the University of Massachusetts, Amherst.
PHOTO CREDITS
  • Creatas/Creatas/Getty images
Suggest an Article Correction
How to Open a Combination Lock on a Samsonite Suitcase
  • How to Reset the Combination on an American Tourister
  • Airline Rules on Locked Luggage
  • How to Reset a TSA Lock
  • Reagan Airport & Luggage Storage
  • How to Prevent Lost Luggage
  • Cost of Shipping Luggage Ahead to Destination
  • How to Repair Wheels on Luggage
  • The Odds of Losing Luggage
  • How to Make Inexpensive Luggage Tags
  • Solutions to Lost Luggage in Air Travel
  • How to Measure Luggage
  • How to Expedite Lost Luggage Claims
  • What Are the Dimensions of Hand Luggage for Air France?
  • What Rights Do I Have If My Luggage Is Lost?
  • How to Store Luggage While Traveling in Italy
  • pixel.gifHappy Camper: Test Your Outdoors Knowledge
  • pixel.gifCruisin' Along the PCH: Test Your Knowledge
  • pixel.gifWhich U.S. Landmark Would You Be?
  • pixel.gifCan You Pass for a Proper Brit?
  • Nov 15, 2014 | Lands Phones
    Combination rotation
    3 Digit Combination Lock
    31-10-31
    1. NOTE: If your safe DOES NOT have a key, skip Step 3.
    2. Turn the dial to zero.
    3. Insert your key and turn it until the plunger pops out.
    4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
    5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
    6. Turn the dial to the left to the last number (stop the first time on your last number).
    7. Pull the handle down; the door should open.
    3 Digit Combination Locks for Security Safes
    31-10-31
    1. Turn the dial to zero.
    2. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
    3. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
    4. Turn the dial to the left to the last number (stop the first time on your last number).
    5. Insert the key; turn right.
    6. Pull on the key while it's in the lock to open the door.
    3 Digit Combination Locks for Gun Safes
    31-10-31
    5. Pull the handle down; the door should open.
    Electronic Locks
    31-10-31
    1. Insert the tubular key into the lock to the left of the key pad.
    2. Turn the key all the way to the right until the plunger pops out.
    3. Press the five-digit factory code. The green Proceed light will come on.
    4. Pull the handle down; the door should open.
    4 Digit Combination Lock
    31-10-31-10
    2. Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the fourth time).
    3. Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
    4. Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
    5. Turn the dial to the right to the last number (stop the first time on your last number).
    6. Pull the handle down; the door should open.
    You can find more information about Sentry Safes at www.SentrySafeShop.com
    Dec 11, 2010 | Sentry Fireproof Safe
    I have the combination, but I forgot the order that it is supposed to be applied. IE do I start by turning left or right? How many times? then for the next number in the oposite direction, how many...
    31-10-31
    31-10-31
    31-10-31
    Electronic Locks
    31-10-31
    31-10-31-10
    You can find more information about your Sentry Safe at www.SentrySafeShop.com
    Dec 11, 2010 | Sentry FIRE-SAFE Combination Safe DS3431,...
    Is pattern to sentry 1230 safe right left righ
    31-10-31
    31-10-31
    31-10-31
    Electronic Locks
    31-10-31
    31-10-31-10
    You can find more information on your Sentry Safe at www.SentrySafeShop.com
    Dec 08, 2010 | Sentry Fireproof Safe
    How do i unlock my safe with: Model number MSW 3110 Serial Number BK 706346 Dial Combination 23-93-59 Thank you. Dan.
    31-10-31
    31-10-31
    31-10-31
    Electronic Locks
    31-10-31
    31-10-31-10
    Dec 01, 2010 | Safe International SentrySafe Home/Office...
    I need the turns for sentry safe 1330 i seen it on your site and i forgot to write them down can you post it again thank you
    31-10-31
    31-10-31
    31-10-31
    Electronic Locks
    31-10-31
    31-10-31-10
    Nov 29, 2010 | Sentry Safe Qe4531 Firesafe Waterresistant...
    I know the combination of sentry 1610 safe but can not open.
    Are you sure that you are turning the dial correctly? 3 Digit Combination Lock
    31-10-31
    31-10-31
    31-10-31
    Electronic Locks
    31-10-31
    31-10-31-10
    Nov 21, 2010 | Sentry Fireproof Safe
    Nov 08, 2009 | Samsonite Tripod
    SD102 missing the key
    Hi.
    Yes, you need the key to open it.
    Your code is 4 numbers (one or two digits each).
    First turn the knob several times counter clockwise To "reset for starting)
    Turn the knob clockwise. Stop when you hit the first number the fourth time. Then counterclockwise, and stop when hitting the second number the third time. Counterclockwise again until you hit the third number the second time. Counterclockwise, and stop when hitting the fourth number the first time.
    Now you need the key. The safe opens when you turn the key clockwise. I don't know where to order a new key, but I suppose the manufacturer can help. Your key number should be engraved ON the lock. Mine has four digits lock/ key- number.
    I have not been able to find the manufacturers web page...
    I wish you luck!
    Stein/ Norway
    Jul 08, 2009 | Safe International Digital Electronic Safe...
    Erased the code
    FOR YOUR SECURITY THE
    COMBINATION MUST BE CHANGED
    WHEN THE LOCK IS INSTALLED.
    The door must be open.
    On models with the passage feature, make
    sure the passage feature is disengaged: turn
    knob or key should be in vertical
    position (A) (see figure 14-1).
    1. Insert the DF-59 control key (B) into the
    combination change plug assembly (C)
    and unscrew the cylinder by turning the
    key counterclockwise. Remove the combination
    change plug to gain access to
    the combination change sleeve (see figure
    14-1).
    2. Turn the outside knob once clockwise
    (all the way, until it stops) then release.
    The latch should not retract (see figure
    14-4).
    3. Enter the existing combination. On new
    installations, use the factory-set combination:
    depress 2 and 4 simultaneously,
    (release), then 3 (release). You should
    feel a slight click as each button is
    depressed.
    4. Insert the spanner wrench as shown in
    Figure 14-2 to engage the combination
    change sleeve (A). Gently turn the
    spanner wrench clockwise to the stop
    position (a slight click should be felt),
    then turn the spanner wrench counterclockwise
    to the stop position (A) (see figure
    14-3). Remove the spanner wrench.
    5. Turn the outside knob once clockwise all
    the way until it stops, then release. The
    latch should not retract (see figure 14-4).
    6. Choose your new combination, write it
    on page 26, then enter the new combination
    — depress buttons care-fully
    (a slight click should be felt as
    Dec 08, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
    Locks & Locksmithing Logo
    96 people viewed this question
    Top Locks & Locksmithing Experts
    ray gallant
    Tom Chichester
    Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
