Question about Kenmore Refrigerators
Kenmore 596.72002015 under bottom freezer water collects in tray freezes then leaks in front every 2 weeks?
    Master:
  • 604 Answers
You have a leaking door gasket
Posted on Apr 23, 2017
Our lg fridge freezer leaks water on to floor every 2 weeks
If the water is collecting and freezing on the bottom of the freezer then the drain under the evaporator in the rear of the freezer section is plugged.
Nov 17, 2010 | LG Refrigerators
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Water collecting under the freezer drawer, then freezing
We just had a similar problem with our Maytag side-by-side in the bottom of the freezer. Just as you described...sort of a glacier on the floor of the freezer that slowly melts toward the door. After several attempts to remove the ice, only to have it form again, my husband spoke with a helpful sales person in an appliance center. He said there's a drainage plug/line on the back that's supposed to funnel condensation to the evaporation tray underneath. It gets clogged and frozen. Sure enough...my husband pulled out the freezer, opened the visible line and it was all frozen and full of gunk. He had to use a hair dryer to thaw it out, then flushed it. It was amazing how much stuff came out of there. We've had no more problem since.
Apr 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water is collecting in the refridgerator
defrost drain under coils in freezer is blocked or frozen with ice down in defrost hole. defrost hole with hairdryer but be careful not to melt the plastic.
Jun 09, 2009 | Whirlpool ET1MHKXM Top Freezer...
Freezer leaking water
My Whirlpool has been filling the bottom under the crispers with water and leaking out the vents (?) from the freezer down into the fridge compartment. I finally caught it today being rather loud, probably in a defrost cycle, and it was positively POURING in the fridge. After some more research on this site I removed the freezer bottom tray (1/4" ratchet needed) and found a layer of 1/2" thick ice under the tray. My guess is the drain hole iced up. Removed all the ice from under the tray and on the metal drain run in the back (danger, seemed sharp) and put it all back together. I didn't try to pour hot water down the drain yet, thinking positive thoughts that the drain itself isn't iced all the way to the tray near the floor. Will watch it carefully.
Apr 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Water leaking
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 12, 2009 | Roper RT21SKXLQ Top Freezer Refrigerator
Leaking water out of the front freezer side
empty out the freezer and remove the back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
43 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
