Question about Cameras
Problem with menu screen.it split in half and alternated sides.model 72.80809400
Ie. N & melt. *Softe IteS. Favor NY. Optio
4 Suggested Answers
SOURCE: I get sound but no picture from my DVD player.
Check if you don´t activate the progresive scan function or video sistem
Posted on Apr 23, 2009
  • 47 Answers
SOURCE: my dvd/vcr is show double
on your remote you need to hi the pip button. thats picture in picture. it allows the screen to be split so you can watch two things at once, though most equpiment doesnt support this function yet so its useless.
Hope this helps. Please take a moment to rate:]
Posted on May 07, 2011
SOURCE: screen is a mess
Presuming the screen hasnt received an impact, the most likely causes will be the graphics processor unit (GPU) which is a common failure in HP laptops ( typical cure would be to reflow the solder joints and improve the heat disapation), apart from this check the LVDS cable .
Posted on Sep 14, 2012
Kyocera model c5155 split into two
you should get another one from the company
Feb 25, 2014 | Cell Phones
Half screen
Hi, You might have it in split screen mode. Go to menu and look for something that will make your screen normal again. Good luck.
May 30, 2012 | Sanyo Televison & Video
I cant get it to work on full screen
I am having this same problem as this one above (62HM95). The issue I'm having is that it will also not work full screen. I selected the 'Split' option on the remote and the picture on the left is fine... absolutely clean and perfect, with audio. The picture on the right is completely distorted in very strange colors (mostly constant variations of purple), with audio as well. You should note, that the same video information was feed into different imputes to select for the split. In other words, I feed the cable stream into the TV using the component video (Y B R) as well as the coaxial cable and selected both options for the purposes of displaying the same information side-by-side. On screen I selected video option four (4 for color stream HD) and option (0 for cable/antenna). If I highlight either side and select one of them (4 or 0) the screen goes full screen and I see nothing but one solid color of purple. I've researched the purple and they call it 'Electric Purple'. That is all I see... just the solid purple, with the audio. What I have also noticed is that, If toggle between imputes while in the full screen option and come back to either option (4 or 0) the image plays/appears OK for about 2 seconds then goes back to solid purple. I just can't understand why this is happening especially when the on-screen menu displays perfectly fine. I cannot enjoy this TV by only watching half of it in split mode. Besides the multiple replacement bulbs I've had to buy I've completely had it with this TV
May 29, 2012 | Toshiba 62HM95 62" HDTV
I JUST NEED TO KNOW WHAT MY TONNAGE IS.
Look for your model number on your condensor, outdoor unit. Your tonnage will be towards the end of it and divisable by 6. I.E. 36=3tons or 42=3.5tons. Ac units are messured by the half ton. If you have a split system I.E. heater inside and ac outside your system will be 1 - 5 tons. If this doesn't help post your model and serial number. I can then give you tonnage, age, so forth.
May 16, 2011 | Heating & Cooling
My dvd/vcr is show double almost like a split screen. There is a bar in the middle of the screen and the screen itself is slpit into two parts. When i put up the menu screen for it i can see half of one...
May 07, 2011 | Televison & Video
I can't access my menu, a lock icon appears on the screen for a Pentax Optio M10 Camera
your menu's locked (yellow icon) if it's in green mode. exit the green mode, and you'd get your menu back.
just fyi, since i helped my dad troubleshoot his cam (same model as yours) a while back.
Jul 02, 2009 | Pentax Optio M10 Digital Camera
Split colors on screen
Replace the two convergence Ics they are STK392-110 if your model is the 53FDX20B you can get replacement Ics with installation instructions at the following link.
http://servicemanuals.vstore.ca/
May 11, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Apr 23, 2009 | Samsung DVD-V5500 DVD Player/VCR
Samsung LCD television screen fault
My new TV LCD Samsung LC32C530 Series 5 has one half darker and with less contrast than the other.This is noticeable now always. There is a distinct and clear division down exactly half the display which separates the dark and light sides.. Any ideas?Thank you.
Jul 08, 2008 | Televison & Video
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
