Question about LG Washing Machines
My lg DD front load had PF. Is working now, but the power goes off and on just before every spin. What do I need to do?
  • LG Master
  • 2,355 Answers
I would check for loose connection in your power cord or outlet first.
Posted on Jul 21, 2017
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
This PF error or fault code indicates that the appliance lost power temporarily. Press CANCEL to clear the display.
The fact that it is doing this regularly points to the main control printed circuit board being faulty.
Posted on Jul 20, 2017
  • 210 Answers
SOURCE: LG WM-1280 DD front loading washing machine
When the unit is off, open the door and spin the drum, does the noise occur? If the answer is no then there is nothing wrong with the bearings. Chances are the hall sensor on the motor is on the way out. Call for service and ask them to replace it. Make sure you are using a "HE" branded detergent,,,, less is best.
Sgt 48
Posted on May 31, 2008
  • 37 Answers
SOURCE: replaced sensors today in my LG Front Load washer,
All the Bolts tightened?
Probably don't have the sensor seated properly
Affordable Appliance Repair
Lake Foreat, CA. 92630
Posted on Aug 22, 2009
GodBlessU
  • 3513 Answers
SOURCE: my LG front load washer won't spin! Has code OE or
Check the door lid switch. Maybe it's not closing good. Try to stick a screwdriver in the switch.
Thanks
Posted on Oct 20, 2009
  • 6277 Answers
SOURCE: My LG WM052HW front load
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 14, 2011
pmeneide
  • 382 Answers
SOURCE: LG wm2655hva front loader won't stay powered up. Initially showed a PF code, now shows 3 dashes. Power button works for 5 seconds & shuts down machine....
Hey Kemp!
  • Unplug the machine and hold the power button to reset.
  • OR TRY Unplugging the washer for 5 minutes to see if it will reset itself.
  • If NOT, you will have to replace the control board to fix the problem.
Best of Luck!
JP
Posted on Jun 08, 2015
Why would machine throw a PF error code in spin cycle?
The PF error code indicates "power failure" condition. The fact that it was indicating on the display while fully loaded tells me that you have a bad electrical connection somewhere on the machines PC boards or supply.
The spin cycle is also triggering this condition when the vibration on the machine shakes the "bad" connection and causes a brief loss of power to the machine.
Sep 19, 2015 | LG SteamWasher Series WM2650HWA
My LG comes up with the error code PF
PF - Power Failure - PF error code indicates a power failure during the washer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks
Oct 23, 2011 | LG WM-2277HW Front Load Washer
PF code when on spin cycle
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Oct 15, 2010 | LG WM1814CW Front Load Washer
Machine will not spin and displays FP fault
Hi There
I have this for you and i hope this will get you in the right direction. Let me know how this goes. By the way Merry X-Mass and a Happy New Year.
PF Power Failure PF flashes if the washer loses power during a running cycle. The washer does not flash PF when it is first plugged in.
Press START to continue the cycle from the moment that power was lost -OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle. Thank you for writing to fix ya.
Best Regards Richard
Dec 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My LG front load washer won't spin! Has code OE or PF will not drain water!
Thanks
Oct 20, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Apr 11, 2009 | LG WM2042 Front Load Washer
LG WM1814CW Front load washer PF continues to come on and stops cycle
Seen This before Main control board fixed it It would go through most of the wash cycle and just quit no errors but PF
Jan 29, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
142 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
