Question about The Computers & Internet
How can I change the font to comic sans? - The Computers & Internet
2 Suggested Answers
Orbixx
  • 133 Answers
SOURCE: Fonts missing
Try a system restore to a time previous to that where the fonts were deleted. Start > Programs > Accessories > System Tools > System Restore That should do the trick. If not, do a repair install on your partition with a Windows XP disc, that would also solve your problem - but try the system restore first. Good luck.
Posted on Sep 06, 2007
Font
select font from the menu
Mar 26, 2014 | Computers & Internet
Tip
Common Projection TV Problems and Fixes
In this article we will will outline some of the most common projection TV problems, fixes, pros and cons, and average lifespan.
Average Lifespan: 7-20 YearsPros: Large screen size and excellent picture quality. Some model support HD. Very reliable when they are cared for.
Cons: Heavier and bulkier than the newer plasma or LCD sets so if you live in a cardboard box it may take up a bit more room.
Common Problems/Fixes
Common Problem #1 - Convergence: One the most common problems that you will run into eventually is a convergence failure. This is when the TV colors do not align anymore and the TV will look 3D, warped or distorted. This is a very common problem and a fairly simple DIY fix. Parts to repair this can be found over the internet from sites such as www.TvRepairKits.com . Below are a few photos of a typical convergence problem and a link to a video on YouTube with more details.
utube.png You-Tube video "9oI1Nzq7CR8" placeholder (do not delete) utube.png
Notice how the image looks 3D...this is a classic example of a convergence failure...it may also look warped or have a wave look. But the wave will not fluctuate.
Common Problem #2 - Dull or Dark Video
The second most common problem we see on projection TV sets is whats known as the dull video issue. This is commonly caused by discolored cooling fluid in the lenses. Over many years - usually around 5-7 years - the fluid will discolor and cause the video to wash out or look dull. Changing the CRT fluid out every 7-10 years will restore the image clarity back to factory new conditions. You will actually be amazed at how sharp and clear the video looks once a fluid repair has been done.
Here is a before and after photo notice how it looks washed out. In some cases the images will look like they have halos around them or the screen will have a reddish tint. Bottom line - if your projection TV has never had the lens fluid replaced the video is not as sharp as it can be. You can get fluid kits from the same sites mentioned above. Doing this repair yourself or through a shop will make the video look amazing.
After a fluid replacement
Common Problem #3 - Dead set with no videoIn these cases there can be more than one common issue depending on the TV brand and model. But to make things simple if the TV has no audio or video and its making a constant chirping sound the issue is caused by a short in the convergence. The fix is to do a convergence repair. If however its not chirping constantly it can be one of many issue from failed capacitors, diodes, flybacks, etc.
on Apr 25, 2012 | Televison & Video
Tip
How to Unlock a 16GB iPod Touch
Apple's iPod Touch comes with a screen lock feature that allows you to set a four-digit security code to prevent others from using your iPod. Every time the iPod locks, you must enter this code to unlock the screen and access the user interface. Entering the wrong code too many times, or simply forgetting your security code, can cause you to be completely locked out. When this happens, you can quickly
Instructions
1Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked.
2 If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding.
3 In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore."
4 When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore."
5 After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel.
6 Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration.
Tips & Warnings
Apple notes that the company will not be able to help you unlock your iPod if you forget the security combination. Your only choice is to restore the device to the original factory settings.
on Dec 16, 2011 | Apple Computers & Internet
Fonts missing
Sep 06, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
16 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
