In my manual there is nothing to address this problem
  • Computers & ... Master
  • 16,199 Answers
You would have to tell us the problem and what equipment you have for ANYONE to be able to help you.
Posted on Apr 22, 2017
I cannot connect to the internet when trying to use Netflix. I have used an ethernet directly from modem to Blu-ray and still nothing. Have tried everything and nothing works.
have you set up the ethernet in the blu-ray recorder. IP address has to be set to automatically obtain otherwise it is set up manually and match the subnet mask with the modem and allocate a ip address manually.
Feb 05, 2015 | Netflix
Ip address dynamic
Dynamic and Static addressing are the two main methods used for IP address assignments. Dynamic IP addresses are automatically obtained and nothing needs to be done on the user end. However, Static IP address information must be configured manually. If you do not have a router, you need to input your static IP information directly into your Apple Macintosh.
Click "Apple > System Preferences." Click the "Network" icon. Click the "TCP/IP" tab. Choose "Manually" in the Configure drop-down menu. Click in "Show" and choose your Ethernet device. This is usually called Built-in Ethernet. Enter your IP address into the IP Address field. Enter the Subnet Mask into the Subnet Mask field. If your service provider did not provide you with one, use the default of "255.255.255.0". Enter the Gateway address into the Router field. Enter the DNS Server into the DNS Servers field. Two should have been provided to you. Push the "Apply Now" button to confirm changes.
Apr 07, 2013 | Belkin Ethernet Adapter F5D5050 Network...
Adding Mac address
You can't change or add mac address. The problem is your router having some setting , that is need to change. Your playstation. Is OK.
Apr 13, 2012 | SMC Computers & Internet
Dns failed is coming while i am trying to open internet.
Use your web browser and LOGON to your modem/router administration page (check your modem/router manual for the correct address of your router). Navigate to Broadband or Internet status and check if your modem/router has managed to acquire the following from your ISP:
1) IP Address
2) Primary DNS Server Address
3) Secondary DNS Server Address
If you don't seem to have gotten any valid addresses, please check your ADSL/DSL/Cable for any lose connections, power-off/on router and try again.
If nothing helps, please call your ISP Tech Support as the problem may be with your service provider.
Mar 22, 2011 | Computers & Internet
Changed the IP address on Zhone 6218-I2, can't access browser UI.
Go to start -> run -> cmd.
When the window comes up, type: "ipconfig". The address that says "Gateway" should be the address of the router.
If that is too confusing, try the following combinations:
192.168.0,1,
192.168.0.254,
192.168.1.254
192.168.2.1
192.168.2.254
May 23, 2010 | Zhone (6218-I2-200) Router
IP address of printer on the network has changed
You have to use the utility call SetIP that comes with the printer. Check the CDs. It is easy to use.
May 16, 2010 | Samsung ML-2851ND Laser Printer
Change delivery server IP Address
I had this problem with an Aficio 2018D using scan router ScanRouter V2 Lite. The MFP would say it couldn't update the delivery list. Deleting/Reinstalling SW, resetting the I/O device and so on, nothing worked. At last I had to use the SP 5845 (see maintenance manual) to manually change the Delivery Server IP address, which was initially set to 127.0.0.1 and had by then been corrupted to 0.0.0.0, to 192.168.1.227 which was the IP address of the WinXP where ScanRouter was running (of course port 3870/tcp must be opened as exception in Windows Firewall). The scanner immediately "saw" the delivery list, updated by itself and, touching wood, worked like a charm ever since.
Dec 26, 2008 | Office Equipment & Supplies
INSTRUCTION MANUAL.
I've spent 20 minutes googling matsui>mat110>user manuals>drivers and came up with nothing. I could not even find help at the Matsui web site. I did find several threads on different sites complaining about the lack of documentation. If you have a phone number for them I'd use it.
Sorry and good luck.
Sep 16, 2008 | iLO (2 GB) MP3 Player
Can I reset the address of the router?
wire a computer directly with ypor router.
Have contact? if Yes you can read the IP adress within your operating software.
READ!!
Connecting two routers to each other is not difficult but is a lot more work than only changing the IP address. Firewall/ DHCP and other settings have to be changed on both routers. You need to look this up in the manuals of your routers.
Hope to have helped you.
Pascal
Jan 23, 2008 | Asante (99-00618-71) Router
Wont turn back on with internet nor find the dsl
disable dhcp give manual address to your router
run ipconfig to pc and add manual address to pc
Nov 24, 2007 | Actiontec GT704WG Wireless Router...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
