Question about Neptune Washing Machines
Neptune front loading washing machine is stuck on hot and light soil. buttons not responding
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 126 Answers
Posted on Apr 23, 2017
  • 209 Answers
SOURCE: maytag neptune front loading washer
purely based on the vague information you have given, this could sound like the drum bearings and the fact that it has been neglected for so long has resulted in serious damage to your machine, note to all, never continue to use machines making noises, it can only get worse and do mare costly damage, after all the problem could have been a very inexpensive fix problems on this and any other site, to be fixed by messages (without actually seeing the machine) can only be fixed - or advice can only be given based on the details that are given if you say my machine just stopped then you will not get an answer will you? engineers can help sort out lots of problems without seeing the machine if we are given the right DETAILED information, no matter how silly it sounds, so before you shout and complain at others, have a thought about what you are going to write sorry its bad news but i hope i have helped
Posted on Oct 02, 2007
IFIXALL
  • 868 Answers
Change the water valve again ,you most likely got a bad one.The odds of there being no cold water after a new valve is almost impossible.You can test the valve to make sure its working before you go to buy another one.
Posted on May 14, 2008
SOURCE: Neptune front load washer buttons wont work
I tried un pluging the machine for few hours and it will work for 3-4 load and then it will lock up again
Posted on Sep 05, 2008
dh1200s
  • 335 Answers
SOURCE: how to get front panel off neptune fav6800aww washing machine
Just a quick search in this forum fot "Front Panel" returned this post which says it better then I could.
http://www.fixya.com/support/t538238-remove_front_panel
Posted on Jan 18, 2009
  • 274 Answers
SOURCE: My neptune front loading washing
wow its not draining there may be a solution, the drai or pump is clogged try this take every thing out put draino-max in tub and let it set over-nite,then run machine on heavy-duty hot water no clothes,this well unclog pump and drain as well,the pumps on these new washers are real small.and they get clogged real easy,hjair,pet-hair strings etc. seem to clog them.After machine has gone through full cycle.run a quick wash to get rid of resdue.then try washing load this always works for for us.
Posted on Sep 04, 2010
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
How much water should this washer use on light soil setting
According to maytag the washer will use a total of 15 gallons for all cycles
Mar 28, 2014 | Maytag Neptune MAH5500B Front Load Washer
Mah5500b mother board
Sounds more like the key is stuck or shorted.
You can try to do a membrane test by putting it into the service mode. Have the unit on, press and hold the delicates and heavy soil key together until it shows 00 on the display. Next
press the wrinkle free key. This will let you test every key on the keypad. You can toggle them off and on and see if they are responding. If they are not responding then you can assume that the keypad is your problem.
The keypad is not hard to install. Just a ribbon that plugs into the board. You may want to try to clean the end of the ribbon with a eraser and see if that fixes the problem. Always work with unit unplugged.
Dec 16, 2013 | Maytag Neptune MAH5500B Front Load Washer
The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
I can't set my Neptune washer temperature to cold water wash. I press the HAND WASH button which originally used cold water but now it stays on hot water (highest temperature setting). the arrows where you...
you need to call your parts store or the factory number in your book,give the model and serial number to them and order the console,the touch pad is damaged and they sell you the whole top console on the washer
Feb 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer options not working on control panel. The options that aren't working or responding to controls are: presoak, stain cycle, extra rinse, heavy soil, normal soil, light soil. Other options work and am...
when you push the button to select the options that arent working do the lights at the selected option come on? if they do not then you need a new control panel they will cost you approx 100$ to sell it as is you would be lucky to get rid of it, they only last for 7 or eight years max anyway before the outer tub bearing fails.
Sep 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a mah5500b. prob is washer will not start or do anything. it just beeps. tried the diagnostic test. by pressing delicates and heavy soil. led shows 00. when i push other buttons to check functions....
I had a similar problem on my Neptune. All the machine would do is beep. I believed it was a stuck button so I got a new touch pad and that solved the problem. I also substituted a control board prior to buying the touch pad but the problem was the same.
May 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washing Machine electronic malfunction.
barry, sounds more like the keypad is stuck or shorted. You can try to do a membrane test by putting it into the service mode. Have the unit on, press and hold the delicates and heavy soil key together until it shows 00 on the display. Then press the wrinkle free key. This will let you test every key on the keypad. You can toggle them off and on and see if they are responding. If they are not responding then you can assume that the keypad is your problem. At repairclinic.com you can order the part you need and if it doesn't solve the problem they will take it back no questions asked. A lot of people are not too fond of these washers because of the many issues they had with them. You would have to weigh the price of the part versus a new washer. The keypad is not hard to install. Just a ribbon that plugs into the board. You may want to try to clean the end of the ribbon with a eraser and see if that fixes the problem. Make sure the unit is unplugged before going in there.
Mar 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Incorrect times on wash cycles
you dont need to reset the times, all that has changed is the soil type. in example, light, regular or heavy. that is what causes the times to change.
you just need to push the options button until it shows the type of cycle you want.
also make sure you have the proper cycle selected and then look to see what other options are selected. you just have too many options turned on, so look at the controls to see what is different then you remember.
Jan 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
All buttons don't light up on fron of washing machine
try unplugging then repower up, if still no response ill step you through another check.
Oct 15, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
Top Neptune Washing Machines Experts
gbob59
Eric Taylor
Are you a Neptune Washing Machine Expert? Answer questions, earn points and help others
