Question about Garden
Hello. I've got a twin Dixie and when I'm mowing under a load the blades almost come to a stop. The motors never slow down but the blades do. Any help would be great
    Master:
  • 604 Answers
Replace the belts
Posted on Apr 23, 2017
GOOD MORNING, I HAVE A D140 JOHN DEERE LAWN MOW,IT RUN WELL WHEN NOT MOWING BUT WHEN ENGAGED IT SLOW DOWN AS THOUGH IT HAS TO CATCH IT'S BREATH LESS THAN THREE YEARS OLD
Make sure there isn't anything binding the deck belt or blades. Check the spindles for free movenent. If all that is good then it might be the linkage that is supposed to adjust the throttle when the engine is under load or it might be a carb issue...especially if you run ethanol gas in it.
Aug 27, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
What causes blades to stop in low setting?
Scott, sounds like belt or pulleys could be worn out, also see if your pulley tension spring is still on the tensioner pulley arm if your machine is equipped.
Apr 04, 2016 | Garden
Mtdproducts com
This most often happens when you are mowing too much grass at once, or when the deck (or chute if you have a bagger) is clogging for some reason. Sometimes this is made worse by having dull blades. Usually mowing at a slower speed or mowing more frequently will help solve this. If the motor is struggling with the blades, these are usually the culprits. Clean your deck thoroughly, cut the lawn more often, or cut it slower.
In some cases, if your PTO belt may be worn, stretched, or need adjustment. When this happens, the motor will not slow down with the blades but will keep running normally and you may smell a burning rubber smell as the blades slow down.
Jul 16, 2013 | Garden
Bolens st160 hydro eliminator 16hp tilling transmission .took the blades off 2 sharpen,1ata time,installed them, probably not in exactly the same position.started mowing the mower mows about a foot then...
Make sure the shape edge of the blades is installed closer to the ground. I don't think it matters what the position of the blade is.
Gary
Apr 25, 2011 | Garden
The blades stop turning under a heavy load on my Craftsman 42" mower deck. Is there an adjustment that can be made?
"the adjustment" is to slow down in high grass areas. alternatively mow more often so the grass does not get so high between mowings
Apr 12, 2011 | Garden
Electric mower keeps slowing down and stopping
Two things come to mind. The brushes in the motor should be replaced. (Get them at a local motor repair shop, but take one of them in with you to get the correct one). If that is not the problem it may be the switch in the handle that you turn it on and off with. The switch may be corroded or bent. Good luck...Lee
May 29, 2010 | Black & Decker Black and Decker Mm575 18"...
Once engaged and start mowing, you can mow for about 20 feet or more and then it just slows down and the engine wants to die, but stop pulling immediately and the engine catches up and goes back to full...
This actually happened to a friend of mine! I saw it! Mow about 20 feet, and had to stop, then 20 feet...well, you get the picture. It was his air filter! Stopped up pretty good. We blew it out and it worked fine.
I really hope this helps. --W/D--
Aug 15, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
