Question about Dirt Devil Vacuums
HEIGHT ADJUSTMENT ON DIRT DEVIL UPRIGHT DOES NOT WORK AND I CANNOT VACUUM ITS HARD TO PUSH
    Top Expert:
  • Dirt Devil Master
  • 39,061 Answers
The height adjuster may have failed. Best to turn the machine upside down and check operation.
Posted on Apr 23, 2017
Dirt devil breeze bagless height adjustment mafunction
Hi there! If your vacuum is suddenly hard to push your roller lifter assembly, which controls the automatic height adjustment, may be damaged or broken. Check your roller lifter assembly located underneath your unit for damages. Also, your brushes help to maneuver through carpet, check that your brushes are still spinning. If not, replace the belt on your vacuum. I have included a link where you may visit to purchase a replacement belt for your vacuum. Hope this helps!
Style 4
Aug 08, 2014 | Dirt Devil Featherlite Bagless Vacuum...
How to fix wheels that raise and lower the beater bar
Hello! The M085845 has an automatic height adjustment that cannot be manually changed. There is a roller lifter assembly that helps to raise and lower the nozzle depending on whether the vacuum is in the upright or reclined position. You do not have to make any adjustments to the vacuum when going from carpet to hard floors. The brushes will continue to spin at all times when the vacuum is in use. Hope this helps!
Jun 26, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Dirt devil platinum force no longer pushes easily
Hi there! If your vacuum is suddenly hard to push this could be an indication that your belt that controls your brushes has broken. The brush roll helps to maneuver through carpet. Check that the brushes are still spinning. If the brushes are not spinning you will need to take the vacuum in to a Dirt Devil authorized service center to have the belt replaced.
There are also two small wheels underneath the vacuum that controls the automatic height adjustment. Inspect the height adjustment cam, shaft and wheels for damages.
Below is a link where you may go to locate the nearest service center to you. Hope this was helpful! If you require further assistance feel free to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
Service Center Locator
May 01, 2014 | Dirt Devil M091200 Platinum Force Upright...
How to adjust height on bagless dirt devil featherlite
Hello! The M085435 has an automatic height adjustment. The vacuum will adjust to the carpet height without you having to do anything. Hope this helps!
Apr 25, 2014 | Dirt Devil FAN, FEATHERLITE MODEL...
I have a dirt devil vision wide glide, 086700, made may 2006. I found 2 places with reasonable prices and the same excellent explosion diagrams. www.ereplacementparts.com and www.vacpartswarehouse.com hope...
Do you know how to get the height adjustment knob to release the wheel height? Its stuck on high carpet? The knob moves but doesn't change the position?? Identical Vacuum.
Feb 27, 2011 | Dirt Devil M086700 Vision Bagless Upright...
Dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Apr 28, 2009 | Vacuums
Belt slips off motorshaft
It could be an old belt even if the upright is new. Check that the beater bar is not clogged with dust or threads and find a replacement belt for this vacuum and fit it to see if there is any difference. If not, then there's a problem with the vac and it should be returned.
Apr 02, 2009 | Dirt Devil Featherlite Deluxe Bagged...
Dirt Devil Featherlite Bagless Upright
Check the brush roll, are the bristles worn down? Check the belt also, if it is stretched, then it won't drive the brush roll like it should.
Oct 02, 2007 | Dirt Devil Featherlight Bagless Upright...
Vacuums Logo
122 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
