Question about Metra 2002 Kia Sedona
Replaced sensor and speedometer still doesn't work
2002 kia sedona - replaced output speed sensor - which cause in put speed sensor to go which made speedometer not work - now with part replaced speedometer still doesn't work???? what else could it be
  • 4 more comments
  • bykmb Jul 24, 2009
    i think so i am not sure
    well what if the answer is yes????
    someone else is working on my car and their line is busy so while i wait...
    ok - they say it is
  • yadayada
    yadayada May 11, 2010
    I NEED ACCURATE INFO TO HELP U, IF YOU NEED FASTER INFO USE THE PAY PREMIUM QUESTION OPTION OR LIVE CHAT.
  • yadayada
    find out and let me know
  • yadayada
    this sensor was it the VSS sensor?
  • 21 Answers
Wrong part or somethings disconnected
Posted on Jul 24, 2009
Speed sensor
Speedometer sensor measures axle(driveshaft) speed for your speedometer gauge.
Input speed sensor measures the speed of the input shaft of the transmission.
The output speed sensor measures the output shaft, the ECM compares these two signals to determine the amount of clutch slippage and adjusts parameters accordingly for optimal operation.
Feb 02, 2014 | 2002 Kia Sedona
Replaced output speed sensor on 2002 kia sedona a few times.
Given the transaxle & the age
I would say it is time to either
part with the vehicle,that would be
my suggestion, while you can, or have the
transaxle rebuilt
Lets be realistic here
Were any of those sensors ever tested
or failed a test,I doubt it
Again-- as with the couple thousand lost souls
that come here every week,you do have a check
light on- so you start there as always
I owned a trans shop,your trans is worn out ,enough said
The shifting symptoms are telling you the problems, like it
is talking to you,now you continue to drive it as everyone does
& ruin it for good
Feb 19, 2013 | 2002 Kia Sedona
Where i can find vehicle speed sensor for kia sedona 2002
It is mounted on the tail end of the transmission. It has two wires coming out of it typically.
Nov 14, 2009 | 2002 Kia Sedona
I have a 2002 kia sedona and occacionly the car jumps while i am driving and then runs very rough...I have learned that when i shut the car off and turn it back on it seems to run normal again
Sounds like either an input or an output shaft speed sensor. In a nut shell, the transmission's shifting is controlled electronically; at a stop or very slow speed, the transmission is automatically in first gear...when these sensors 'sense' that the vehicle is travelling at a certain speed, it tells the transmission to shift into second. At the next specified speed, it shifts into third; etc. etc. What it sounds like is that one of these sensors is going bad, telling the transmission to downshift, but the other sensor is fighting that command and causing the vehicle to 'act' like it's running rough, when in reality it's probably just the transmission rapidly jumping between gears. These sensors aren't particularly cheap, but are pretty easy to replace. Start by finding a shop that will plug in a code reader for you (or do it yourself if you have one). You're looking for a code in the range of 0715 to 0723. If it reads 0715 to 0718, that's the input side. 0720 to 0723 is the output side. Good luck.
Jul 05, 2009 | 2002 Kia Sedona
My speedometer and odometer stopped working
Your speed sensor has failed. The vehicles speedometer is not cable controled, it's controled by a sensor in your transmission. It's a easy fix, but the new sensor is about $80 to $100 depending on where you get it.
Apr 28, 2009 | 2002 Kia Sedona
While driving the speedometer and odometer quit working.
you have a problem with your speed sensor, you need to check or replace it.
Metra 2002 Kia Sedona Logo
981 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
