Question about Kitchen Ranges
DG47-00021B. The outside two burners are work but the center burner is not working. Does this part out of order? Need to replace which part ?
    Top Expert:
  • Kitchen Ranges Master
  • 50,593 Answers
Could simply mean that the gas jet for that burner is blocked
call in a gas fitter to check and diagnose as gas is not in the diy domain
Posted on Apr 22, 2017
DCS 305 cootktop: one burner will not stop clicking + the simmer flame is not on consistently around the burner.
Hello- What is probably happening is that the simmer orifice is clogged. If this gets clogged-up and not enough gas comes out to the burner it will continue to click. This is usually pretty easy to remedy. Take off the burner cap and you will see two holes, one in the center for the main burner and a smaller one that is on the perimeter of the burner. Look down that small hole and you should see a bronze orifice, it is pretty small, about 1/8" in diameter on the outside, looks like a nut. Most likely you will see grease or charred bits on the top of it (you can use one of the other burners for a reference if you are having trouble seeing it clearly) In the center of the orifice is a tiny hole, this is the part that is likely clogged. Now, you'll need to find something really skinny, like thin sewing needle and poke it into the orifice opening. Sometimes it is necessary to hold onto the needle with needle-nosed pliers in order to get it far enough in. Just be gentle with it and if what you are using seems too large in diameter then it probably is, you don't want to dent or cause any damage to the orifice opening. Once you get it cleaned out it should work ok. Let me know if you have any questions. Best regards.
Sep 26, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Middle burner looks ok but has huge yellow flame
Sounds to me like the new burner that was put on, has the wrong gas orifice in it. Possibly a nat gas orifice instead of a propane orifice. If it's a propane grill, take it to your local propane co and have them look at it. Also, sometimes just a spiderweb or dirt dobber nest in the burner's venturi tube can cause that kind of problem. Blow it out with an air compressor and see if that's the problem.
May 14, 2010 | Weber Genesis Silver B Grill
Center burner doesn't ignite all the way around
I had this same problem. You will need to lift off the burner and remove the two 9/32" nuts and lock washers from the bottom of the center burner. Then separate the top section from the bottom. You will need to clean the inside of both sections down using a green scotchbrite pad removing and debris or small surface film the may have built up. Then rinse with warm water and dry them well. Reassemble it and your burner should work as good as new. Remember even just a small grease film on the burner holes will create this issue.
Apr 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ducane lp gas grill flame pulsates
Have you replaced the battery ? They do rust and lose contact over time outside.
Apr 14, 2010 | Char-Broil Commercial Stainless Steel...
We have a Charmglow 720-0234 5 burner gas grill. Replacing the burners that rusted out but can't get the screws out of the back of the grill that holds burners in place. Ideas?
yes. These screws are literally rusted in place. Begin by squirting each one with WD-40 Penetrating Lubricant. Let that sit over night so the lube will indeed penetrate. The next day the screws may back out, if not and you can get a pair of needle-nosed locking pliers on them, back em out that way. As a last resort, drill them out. Joe
Mar 18, 2010 | Grilling
Very low flame, like very little gas is getting thru, tank is ful
Okay, what you are dealing with is called "vapor-lock". The way these grills need to be turned off is, close the tank valve first and after the burners go out, then turn the burners off. The way you are doing it is trapping the gas and you are getting a weak flame. Fortunately this is an easy fix. First, light the grill by turning the gas valve open, then turn the burners on to light the grill...as soon as that is done, close the gas valve on the tank then turn the burners off. Repeat this procedure until you get a good flame. If this procedure hasn't fixed the problem after the third time, you need a new regulator and regulators are easy to find in any home improvement store like Lowe's or Home Depot.
Dec 15, 2009 | Weber Genesis Silver B Grill
I have a Sears bought Kenmore Elite Electric Range 790.9912 with a glass top. The right front burner has a middle, center and outside element. The center element stopped working tonight....the middle and...
the burner must be replaced . easy job, open oven look under lip of stovetop there are two 1/4 inch drive nuts , remove them then you can lift the cooktop you will see the underside of the burner . its held in with two screws , carefull of the clips,there easy to loose . let the old burner hang by its wires . when you get the new one in move the wires one by one to the new burner ... you will need two people one to hold the top up and one to do the work . dont forget to turn power off to stove . part will cost around 100.00 should take no longer than 15 mins to do the job . have fun and good luck ........ please rate this answer i need votes to stay here , thanks
Feb 01, 2009 | Kitchen Ranges
Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Sep 23, 2008 | Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
