Question about Car Audio & Video
Can't find the reset button on my Linwood car stereo Kdx 494
How do I get my phone to play my music to my car stereo Linwood model kdc-bt645u
Check your phone and stereo manual. This is normally a Bluetooth setup.
Jun 01, 2015 | Cell Phones
I have an in dash vehicle stereo, no power to it after changing vehicle batteries. Is there a reset button in the stereo. Model # 3L3T-18C815-AA. Fuses are fine.
Some have internal fuses some have a fuse on the back if you have wired the battery incorrect and the radio was connected to the battery terminals you have probably fried the stereo.
Nov 25, 2014 | Cars & Trucks
I want to reset a stereo of chrysler town and country 2010
Most modern OEM stereos require coding changed to accept an ipod. Dealers can do this so can decent garages. To reset the unit try disconnecting and reconnect the battery but be prepared to lose learnt data, this means the car may require a re-learn / drive cycle afterwards
Feb 20, 2012 | Cars & Trucks
My question is, I have a Meade Autostar #494 How do I see through the lenses?
The 494 is the HAND CONTROLLER NUMBER--- not the telescope. What Meade telescope do you own??
Aug 20, 2011 | Meade 494 AutoStar Telescope Control Unit...
Can I just swap out my meade 492 motorized mount remote for a used 494 autostar remote or 497?
It depends on which model Meade telescope you own-- you never said?
Yes you can swap a 494 for another 494-- but we need more information to be able to say a 497.
May 11, 2011 | Meade 494 AutoStar Telescope Control Unit...
Hi. I have a stock 1998 kdx 200 that needed a blackbox. I bought a replacement cdi but the wiring on the bike is different to the 98 cdi unit. Colors are different too. The wiring on the bike is a kdx as...
Try following the wire from the stop button on the handle bar back to the CDI box. Simply unplug that wire. CDI is disabled by grounding. Does the KDX have a key switch or just the stop button. Try just connecting the pick up wire to the CDI and CDI to coil. You have to isolate ground to CDI to run. Check air gap at pick up. Use a matchbook for a gauge.(.018)
May 20, 2017 | 1998 kawasaki KDX 200
How do i eject a cd from the JVC KD G510 car stereo. A CD is already in there but i can't figure out how to get it out and put a new one in
A malfunctioning stereo may least allow feature buttons to perform extractions of CDs. Depending on how the stereo was installed, the car would have to be powered on to attain stereo functionalities. Second, CDs have to be inserted with the readable media side facing the appropriate lenses to achieve results. A wrong insertion of the CD into stereo compartment may require forceful extraction. Observe the type of stereo to ascertain CD extraction also known as reset buttons. Usually a tiny area, the reset button allows inserting an object that forces the car stereo to eject stuck disks. Every mean to eject stereo disk have to be performed while the car is turned on to utilize the source of power. An unsuccessful attempt to dislodge CDs in stereo compartments would require auto electrician's consultation. An unsuccessful dislodge attempt usually requires acquiring a new stereo in replacement of the malfunction.
Feb 02, 2011 | JVC KD-G510 CD Player
I want to reset the low tire pressure light from my 2001 chevy impala. I go into the stereo disp. Button but the option is not in there how can I reset it without using the stereo?
I want to reset the low tire pressure light on my 2003 chevy impala. I go into the stereo disp. button, but the option is not there. How can reset it without using the stereo?
May 20, 2010 | Cars & Trucks
Celica stereo
are stereos known to be good. try buying wiring kit for use in your application.
Oct 27, 2008 | 1992 Toyota Celica
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
