Question about Garden
Dixie chopper dies when engaging blades. Spindles are good and everything is freed up.
  • 604 Answers
Belt is binding or spindles are frozen
Posted on Apr 23, 2017
3 Suggested Answers
  • 163 Answers
SOURCE: tractor?troy bilt/mtd 2002
the electric clutch that operates the blades needs replaced
Posted on Nov 30, 2008
  • 49186 Answers
SOURCE: Why does my engine sputter when blades are engaged in 2750 magnum dixie chopper with Briggs motor
lack of fuel possibly check filter and pump
Posted on Apr 25, 2015
Dixie Chopper zero turn mower will not start.
check or by pass the parking brake sw. it is on the same circuit.
May 13, 2017 | Seat Cars & Trucks
How to change engine deck belt on a 2006 Dixie chopper mower
there isn't such a thing... it's either a hydro (motion) belt or the deck drive belt. Dixie's also sometimes had 2 belts for the deck... the drive belt and the blade belt. your model number should be under the seat
Sep 13, 2014 | Garden
How to get a dixie chopper repair manual
Don't seem to find a 27060 classic. The only classic available is a 2760 or 2760T or 2760W.
Best to go to this Dixie Chopper support site and select the model carefully. You may not find a service manual but depending on what you may want to repair, the parts manual may be sufficient.
Manuals Dixie Chopper
Aug 19, 2014 | Garden
Lawn mower, Dixie Chopper
Sounds like a linkage issue. Since your mower is new that means it's under warranty. If you do any work to it you will void your warranty. Instead I suggest contact your dealer.
Dec 15, 2017 | Garden
How to change drive belt on Dixie chopper silver eagle lawn mower
Jul 28, 2012 | Garden
Craftsman 19.5hp 42'' deck lawn tractor with vibration only when the cutting blades are engaged.I have changed the blades but the the tractor still vibrates alittle. when I disengage the blades the...
Check your spindles, especially the shafts in the spindles. If one of them is bent, it'll make the blades vibrate as they spin. You can find replacement shafts and spindles at
Dec 18, 2010 | Garden
What would cause my craftsman zero turn to die when i engage the blades?
First, sort out between two possibilities: 1. The safety system is killing the engine -- for example, if the seat switch is faulty or misadjusted, the engine ignition is killed when you activate the blade engagement switch. 2. The blades, spindles, or belts are binding or stuck, which would "drag" the engine to a stop. I suggest you remove the belt that drives the mower from the engine. If the engine still dies when you engage the blade switch, it's problem #1. Check all connections, and check the seat switch with an ohmmeter. If the engine does not die, then you have mechanical drag. With engine off and the belts taken off, turn each spindle to find out if one is frozen or binding. Good luck!
Apr 05, 2010 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Engine chokes & dies when deck PTO engaged...
you need to start with your electric clutch and then backwards to your idler pulleys and deck spindles and bearings.
your electric clutch should almost stop the blades instantly when disengaged ,check the center bolt in the clutch to be sure it is tight also
remove the belt from the electric clutch and energize clutch any noise? sometimes the bearing goes bad in the clutch itself.
check all of your 3 spindles for noise and loose. remove belt and spin by hand and listen for quiet and they should turn free with no binding
check blade tightness
any item the belt goes around needs to be looked at for secure and operable.
Jun 08, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
