Question about Garden
How do you find the plug to change oil on 2012 push mower model no. 11A-A23K700
    An expert who has written 3 tips or uploaded 2 video tips.
  • 126 Answers
Briggs stratton
Firstly try changing the spark plug. If it still persists check the oil level. It may have too much in it.
Jul 14, 2013 | Yard Machines 158cc Push Lawn Mower #11a...
Where is the oil drain plug for the mtd 11A-O84EO29
Hi dherrin...
Look under the mower housing on the motor and locate a square plug, or maybe a socket screw to remove.
This will be the oil drain.
Free answer...Please take time to rate me
May 21, 2011 | Mtd 22" Yard Machine Push Mower
What type of oil is used in a yard machine lawn mower model no. 11A-414E029
SAE 30WT i.e non detergent. Change oil every 25 hours and every 4th oil change us a detergent 30 WT oil.
The manuals will never tell you that but having worked on small engines since the mid 60's that 4th oil change with a detergent oil does a bang up job of keeping the oil ring from eventually cooking onto the piston. Also washes out the crank case and makes it look like new!
Sep 07, 2010 | Mtd 22" Yard Machine Push Mower
I have a yard machine mower model number 11A-549R729 that will not stay running. Have replace plug,drain fuel tank and clean carb. If you push the primer bulb it will continue to run. But once you stop...
Your carbs main jet is blocked. Using the primer supplements the fuel input and keeps the engine from becoming fuel starved.
You need to remove the main jet and run a strand of fine wire through the jet to clear it.
Aug 17, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
What tool should i use to change the oil on a push Troy Bilt lawmmower Model 11A-439R766 XVS 6.5HP 190CC
The drain plug is made to fit the square end of a 3/8" wratchet extension.
Jun 14, 2010 | Garden
I have a Murray 6.0 hp 20 inch push lawn mower. How much oil do I put in when changing oil.
If there is a dip stick add some oil check the level till you get to the full mark. It should take a little more than a quart. If there is no dip stick then there is an oil fill plug down low on the engine. Fill slowly until the oil reaches the threads in the engine housing (almost overflowing). Be sure to replace the plug or you will have oil everywhere when you start it.
Don't just dump the oil in, check the level as you go!
May 20, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
11A-418A729 - straight gasoline or gas/oil mix
If it has an oil stick, it is sraight gas. No oil stick to check oil then, gas/oil mix needed.
Jul 10, 2009 | Mtd 22" Yard Machine Push Mower
If the oil in my lawnmower is overfull, how do I fix this?
should be a drian plug on the bottom of the mower engine, just drain and tighten up the plug and refill. they usually hold about 16 to 20 ounces of oil. Go buy briggs and stration oil at walmart or kmart just the right amount
Jun 13, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Wont stay started
I found this site if you can not find plug behind engine/blk wire with black cover boot/ pull off.
Please rate. Thanks. jj505
Mar 30, 2009 | Garden
Mower won't run....starts then stops
lawn mower only starts if i prime it. yard machine push mower. m/n 11a-549q229
Mar 01, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
