Question about Garden
How to fix self propelled not working - Garden
    An user who is expert in 3 categories / brands.
  • Garden Master
  • 924 Answers
Martha, most all the time it is because the belt that drives the wheels is worn. replace it and clean under where the belt cover goes and it should work good. there are you tube videos that show how to replace that belt.i hope this helps.
Posted on Apr 22, 2017
  • 7 Answers
SOURCE: yardman push mower self propell not working
check to see if it is belt or gear driven
Posted on May 02, 2009
  • 284 Answers
SOURCE: Self-propelled doesn't work
remove plastic cover to access drive mechanism
check belt and remove debris and try again
Posted on May 26, 2009
#1 Taper
  • 1040 Answers
Have you checked the belt that drives the wheel? This is more than likely the problem. It may be broken.
Posted on May 30, 2009
SOURCE: I have a Scotts Turf Vac3 self propelled mower.
my pulling string has broke and i am trying to replace HELP! have taken apart
Posted on Aug 14, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
I have the Toro time master 30" self propelled. The self propel doesn't work. How do I fix it?
These are very expensive units, a little overpriced. If the self propelling system isn't working, see if the cable is actually disengaging the self propelling clutch, if it is and there is still no movement, the trans is shot and the way you fix that unfortunately is to buy a new transmission gear box. Save money and do it yourself if your kinda handy.... Go onto you tube, search for self propelling transmission replacement and you will have a few to choose from. If you are going to take it to a shop, be prepared to pass out when they give you the estimate for the parts and labor. Maybe you will get lucky and it's just the cable which is a very easy fix and the cable shouldn't run ya more than 20 to.25 bucks. BUT get a Toro part no aftermarket! !
Oct 04, 2015 | Toro Garden
I have a Toro mower made in 5/09 self propel system it grinds when you pull it in reverse. The selp propel is not working. The belt is on. and it seems to be only the left rear wheel? The cable is not...
Yes it is the transmission. A Mower shop will charge you about $225 to fix.. I order parts online and fixed mine for $90. Transmission consist of 3 gears which turns the rear wheels to self-propel.
Jul 21, 2014 | Toro Lawn Mower. 22 in. Personal Pace with...
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
MTD front wheel drive self-propelled 21". Self-propelled does not work. Can it be fixed?
Yes it can be fixed. Try some basics first.
1) Check under belt drive cover for excess debris
2) Belt and Idler pulley condition
3) Control cable operation
a) rusted, frozen, broken, disconnected
Dec 03, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Self-propelled feature does not work at all! Any suggestions?
You might have a broken belt to the self propelled or a broken spring or whatever engages the self propel. Take off the cover and see if anything is broken or missing. Have someone engage the self propel while you are watching and see what is going on.
Aug 12, 2009 | Toro Lawn Mower With Toro Power Tools
Self propelled Yardman won't engage - cable problem I think???
are you in vero beach if so you can email me and i can fix it
May 21, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Self-propelled Broken?
I have the same problem, found out there is a cable that is broken, I'm trying to figure out how to fix it.
Aug 11, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
