Question about Home Security
Solar security light item number 69643 and not get it to work it's fully charged will not turn on and off when needed works on on position will not work on auto
Noggin
  • 944 Answers
SOURCE: backlight doesn't work
Go to this link; http://world.casio.com/wat/download/en/manual/ and enter the four digit code on the back of the watch, you should get a user manual - i do think you are probably right however. Hope this helps :)
Posted on Apr 18, 2007
SOURCE: Tatronic inverter problem
Tightened up battery connections
Posted on Sep 24, 2008
  • 5 Answers
SOURCE: I have a Lincoln electric auto darkening hood and the solar power
helmet need batt.
solar power only works with batteries
Posted on Apr 08, 2009
dnewcombe1
  • 1564 Answers
SOURCE: 1988 nissan300 zx auto non turbo engine will not
You've got to check remove and clean your battery terminals and the connectors.Also check the main ground on the block from the battery negative terminal. Then check the tightness of the large red wire going to the starter from the positive battery terminal. And lastly, make sure the small push on terminal to the starter solenoid is tight. if not remove it and pinch it hard with your thumb and index finger. Push it back into place and see if it will start. If so while it is running check your charging systenm with a voltmeter,it should read between 13- 14.5 volts. If it does not start then jump the battery from another vehicle and then check the charging system. If your charging system is fine and the next morning you cannot get it to turn over you'll need a new battery.
Posted on Sep 06, 2009
SOURCE: we bought a solar light
For first time use solar light needs to charge in full sunlight for 8-12 hours with the switch in the "ON" position to allow the rechargeable battery to reach maximum capacity.
There is also a protective film on the solar panel that needs to be removed.
After doing that, fully charging the battery with the switch in the "ON" position, then if the light does not turn on, remove the 4 screws from the solar cell assembly, remove the battery, wipe both ends and reinstall battery. Make sure the battery is making secure contact with the terminals. I had a new one and the battery was loose inside, making the light go on and off. I reseated the battery and all is well.
However you should not have to replace the battery or the unit, it should still be under warranty if you just bought it. Westinghouse guarantees this unit for one year.
A description is here
http://www.westinghousesolarlights.com/products/solar/instructions/371366-08.pdf
Waranty information is here
http://www.westinghousesolarlights.com/products/solar/1yrwarranty.pdf
I would counsel you to just take the unit back for exchange or refund, as the warranty has an exclusion clause and one of the exclusions is if the unit has been opened. Opening the unit might invalidate the warranty.
Posted on Jun 25, 2011
Do solar panels need direct sunlight to work?
No. It will work in with diffused light too. Some sensitive ones will generate voltage even at moon-light.
Electro help
Nov 09, 2014 | Moultrie Feeders 12V Solar Panel
Flood Lights. 180 Degree Motion Activated Solar Powered Floodlight -
Sounds like the batteries are not getting charged. Check to see if there was some packing material in place to keep the batteries disconnected for shipping.
Dec 05, 2013 | Cooper Lighting Flood Lights. 180 Degree...
Lightmates power series model 348695 sensor blink red no light
Had same problem on my unit and temporarily removing the battery and charging it for 24 hours with a modified 7.5 volt 200 ma. power adaptor seems to resolve the issue. Lamp is now working, hope this fix will last. Seems the solar panel does not charge the battery fully. Tried locating a replacement battery to no avail. The battery is 8V3.5AH, no other model information. Battery is 3.75" H x 3.5" W x 1.75" D
Mar 15, 2013 | Televison & Video
What is solar camping gear?
Solarcamping gear is a great environmental solution that allows campers to use thenatural sun to power camping equipment instead of needing batteries foreverything. You can get solar spot lights, battery chargers, generators, andeven solar showers.
Aug 02, 2012 | Camping, Backpacking & Hiking
We bought a solar light a Westinghouse item # 37136608W It had a least 7 hrs of direct sunlight for over 7 hrs.but still does not work, We think we had it on. is it possible that the off switch shuts off...
Mar 20, 2011 | Garden
No charge in solar light
The button should be on, and it usually takes a solid eight hours to charge.
Mar 19, 2010 | Water Heaters
Buttons on casio pro trek watch stopped working -time still shows
Sounds like the solar back up cell needs to be replaced. You can get it repaired for rather cheap less that $30(US). You can contact www.casiosalesandservice.com to have it serviced. 877.659.0761
Jun 25, 2009 | Casio Protrek Triple Sensor Tough Solar...
Solar battery charger
Yes, but the efficiency of solar cells is terrible. Its one thing to use free sunlught to charge the cells, its another to have to pay the electric company to do it. If you can access the batteries in the solar rig easily and they are in the correct voltage range, I think you would be better off getting a battery tender (trickle charger). Just let the van sit outside until the batteries are fully charged, then connect the battery tender to keep it fully charged.
Jun 04, 2008 | 1992 Dodge Ram 250
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
