Question about Dryers
I am having a problem with the installation of a Dyno by Minka Aire.
I completed the installation but the fan is extremely noisy like something is rubbing on the inside of the fly wheel. When I take the flywheel off, the motor turns normally with no rubbing noise. Any idea where the noise is coming from?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I am having an issue with assembling my Minka Dyno. I cannot get the flywheel to attach evenly to the motor assembly. When I tighten the screws (criss-cross) the flywheel lies crooked. I've tried twice but it's still crooked. Any help is appreciated.
Posted on Jul 10, 2017
  • 4 Answers
SOURCE: Minka aire ceiling fan
This may not apply. There could be an electrical problem. But if you installed the bulb with your hand, the oil on your skin can cause the buld to heat excessively and fail. I suggest you use the packaging or part of it when installing it, taking great care not to touch it.
Posted on Mar 31, 2008
SOURCE: Minka Aire Remote control R211
You need to change the tiny DIP switch settings so each fan is set up differently. (Note that each pair of remote transmitters--the one in the fan body, held in a bracket above the light kit when you drop that down; plus the one on the wall switch or in a hand-held remote, must be set with the same combination.)
Our Minka Aire Churchill model has 4 DIP switches; I have seen Casablancas with 5.
Posted on Dec 13, 2008
SOURCE: Minka Aire remote controlled ceiling fan
I have a newer Minka w/ wall controller. The books says to make sure both the wall control and the receiver(up in the fan) are both programmed the same. My receiver has no little switches but has a sticker stating that you need to hold the 'fan off' button down for 3 seconds after turning on the power so the receiver can memorize the program in the wall switch. You have 60 sec to do this after power is turned on. Good luck !
Posted on Feb 25, 2009
  • 10865 Answers
SOURCE: Como Fan MInka Aire light bulb burned out
remove the cover and unscrew the bulb. get a replacement especially designed for a ceiling fan.
Posted on Sep 07, 2009
  • 13 Answers
SOURCE: Noisey Minka Aire Napoli ceiling fans
Minka fan are life time warrantied, have you tried contacting customer service... Minka fans motors have a very simply design... uninstall the fan... try balancing the fan on a table or some where that allows you to remove the shell that covers the main body of the fan... Carefully (someone that is very familiar with the electrical components.) soft wire the fan allowing you to see the motor as the blades turn... You will then see what is making the scraping noise... I may have some extra fan parts that you can easily replace... If you like to write me at payitforwardx2 @ gmail . com I am willing to try to further assist you...
Posted on Apr 23, 2010
Minka f502 is noisy - how do you tighten the screws that attach the fan blade to the motor hub?
With a screw driver? And perhaps you also clean all blades. Sorry if you already did that.
Mar 16, 2015 | Minka Aire Ceiling Fans Gyro Traditional...
How do you tighten the fan blade to the motor hub. My fan is noisy.
Probably need to take the screen cover off then the bottom of the small motor to see if you can get to the screws. Or call Minka Aire @ 1-800-307-3267
Minka Aire model f603 reverse switch?
Not sure what model of fan or manufacture you have. Says Hunter 52" & Minka aire F603. If it's the Minka , Then push the button on the lower part of the remote (6 o'clock). If that doesn't work then you might need a new receiver.
Jul 23, 2014 | Hunter 52" Ceiling Fan With Light And...
Minka aire gyro fan quit oprating
Contact Minka Aire @ 1-800-307-3267. You might have to ship it back to Minka for repair or replacement depending how old it is. fanman9952@aol.com
Feb 28, 2014 | Minka Dryers
How do I reset my minka aire model f601 fan?
You probably need a new receiver But you can call Minka aire @ 1-800-307-3267
Jan 09, 2014 | Dryers
Minka Aire Ceiling Fan light wont come on
Probably needs a new remote receiver.Contact Minka Aire @ 1-800-307-3267
Apr 30, 2013 | Minka Aire Ceiling Fan
Minka Aire Como F603 ceiling fan - light bulb replacement
Try Googling (Minka Aire)(F603)(manual) without parens for instructions.
Jul 28, 2017 | Minka F603-WH Ceiling Fan
Traditional Gyro by Minka Aire - Just installed and does not work
I would triple check that the wiring is correct, then I would check the dip switches on the receiver and the wall switch to make sure they are set the same.
Apr 28, 2008 | Minka Aire F602-BNCH Gyro? Fan
Dryers Logo
Top Dryers Experts
