Question about Craftsman Garden
Trying to buy 2 belts for my craftsman gt5000 but can not find size info for either the primary mower drive belt or the primary blade belt. Can someone give me info on sizes of both these belts please
    Habit-Forming:
  • 158 Answers
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Craftsman Master
  • 917 Answers
Craftsman usually has the belt numbers under the hood. but get the model numbers off the body or deck if it is still there and take the numbers to a mower parts store they can get you what you are needing.
Posted on Apr 22, 2017
  • 5 Answers
SOURCE: the blades on my craftsman 22hpohv gt5000 won't
Hi, when was the last time you had the carburator serviced, secondly, you must check the governor to make sure it is working correctly under load.
Posted on Jul 02, 2009
  • 133 Answers
SOURCE: belt size
Go to www.sears.com and click on partsdirect. Enter your model number of your tractor (found on a data plate usually under seat). It will take you to the page with your parts diagram. Look for the belt in diagram and scroll down to the appropriate number and it will give you the part number for the belt. You can order it from sears and pay shipping or go to local small engine parts department and give them the part number or you can just give them the model number of your tractor and they can get you the belt.
roundo4
Posted on Aug 13, 2009
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
  • 19 Answers
SOURCE: drive belt size mtd 21 " 6.75hp mower
If you post the model number of the machine, I can probably find the belt dimensions..
Tim
Posted on Oct 27, 2011
SOURCE: 42" craftsman mower deck belt 144200 to tight on the deck
Manual lists the incorrect number for this model! i learned through many difficulties. Correct belt is a # 144959, 1/2 " by 95"
Posted on May 01, 2012
Part # for drive belt craftsman gt 3000
http www searspartsdirect com model part 3000A 0736 1509200 WL000217 00005... Lawn Mower Variable Speed Belt Part Number 754 0280 GUARANTEED FIT from... Belt 715 0 Part Number 754 0370 GUARANTEED FIT from Sears PartsDirect
Here are 3 links to Sears. The first is a diagram of the drive system of the gt3000. They show 2 belts. One looks to be the drive belt and the other is for the blades. Those are the other links. Hope this helps
Jun 25, 2015 | Craftsman Garden
What is the size of the belt on a craftsman Lt1000 21 horse Briggs and Stratton 42 inch deck
do not just buy a belt that is "close" to your size belt. the size of the belt is not always a standard size, there is a width as well as a length and also a power rating , that is critical in belt replacement. you must have the model number of the Mower unit "not the engine model" to get the correct belt. OEM belts are made to certain specifications to withstand certain actions of the mower and the wrong size belt could result in a dangerous situation of the blade not stopping or engaging sporadically, or if it is a transmission belt , the mower may not go forward or not stop moving which again is dangerous.
Mar 05, 2015 | Craftsman Garden
What are the belt sizes for a craftsman snowblower model# C950-52379-5
Based on the following info from SearsPartsDirect.
Will this fit my Craftsman Canadian model c9
The auger drive belt is part number 585416MA, and the drive belt is part number 1733324SM.
Feb 09, 2015 | Craftsman Garden
Dont know wheter to get primary mower belt or secondary mower belt for craftsman gt3000 48 inch deck mower...?
primary belt goes from the engine to the deck the secondary goes on the deck and connects the blades together
Aug 24, 2012 | Craftsman 48" Cut Riding Lawn Mower Deck...
12 hp roper lawn tractor need belt size for blade drive
take a piece of rope and run it around all the pulleys a mower shop or parts store can match it to that
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman gt5000 26hp 54" deck. I removed the cutting deck cleaned and replaced blades then when i put it all together the belt wont fit. Theres a belt tensioner rod that i disengaged but...
Belts do not change length. You are doing something wrong with the routing. Maybe the tensioner goes on the other side of the belt or the belt should be routed around the other side of both the tensioner & idler.
Gary
Jul 06, 2011 | Craftsman GT 5000 26 HP54" Garden Tractor...
Craftsman mower keeps breaking primary mower belt
Have you check the tensioners? The idler pulleys that are on the arms with springs on them. My reasoning is, if the arms are rusted, or stuck for some reason and not moving freely then the springs can't pull the belt tight. If that's the case, I could see where the belt could be slipping more than it needs to and prematurely wearing out. Just something to check. Good luck.
Jul 29, 2010 | Craftsman Garden
Aug 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
The blades on my craftsman 22hpohv gt5000 won't
Jun 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I change out the primary belt on a Craftsman 17.5 hp 42" mower? The new belt is around the pulleys but it is very loose.
This belt is easist to install with the deck all the way down. Make sure there are no burrs on any of the pulleys, (will eat up your new belt in short order), also make sure that the 2 drive pulleys for the blades turn freely, (may have grass impacted around them, you may need to remove the 2 guards on top of the deck to clean, (if they do not spin eaisly). Triple check to make sure the belt is properly routed, one mistake and your belt is broken as soon as you engage. With the engine OFF, engage blades to check tension. If the belt is still loose, you likely have it routed incorrectly.
Jun 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
32 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
