Question about Boating
Canned get break barrel to catch - Boating
2 Suggested Answers
skaterkid307
  • 86 Answers
SOURCE: when i break the barrel it doesent catch.
Try to clean the barrel and make sure there is not an object jamming the spring.
Posted on May 30, 2010
For some reason, when break the barrel, and crank it down, it doesnt lock anymore - just springs back. Is there something I can adjust - or is it likely something has broken?
Hi Dave:
Just picked mine up from under the desk and had a look.
I'd be guessing that something has interfered with the trigger catch.
If it was mine I would be dis-mantling it and giving it a really good clean and blow out with compressed air. Once you have removed the stock you should be able to see the mechanism.
Cheers.
Jan 12, 2016 | Crosman Phantom .177 Caliber Break Barrel...
How do I install new piston in a homelite XL2 auto chain saw
up from the bottom of the cylinder
make sure that the ends of the ring is at the locating pin in the ring groove
pull the conrod right up and put a set of vice grips on to hold it up position the barrel over the piston and hold the ring in with your fingers
gentle push the barrel over the piston and the taper at the cylinder base will hold the ring in as you continue to push the barrel down
if you have failed to correctly align the barrel on assembly then make sure that the piston is at the top of the stroke before turning the barrel around as the ring ends may catch in the ports of the bore and break the ring.
May 30, 2015 | Homelite Garden
How do I fix a White sewing machine #445 that keeps breaking the upper thread
Check the thread spool to make certain the thread is not getting snagged on the edge of the spool (or the little slit where you pull out the thread from the spool); then check your tension paths and settings (I once found broken, tangled metallic thread in the needle 'uptake' loop that was snagging the thread and making it break).
Canned air is excellent for cleaning out older models as well as the new electronic machines.
Feb 03, 2015 | White Sewing Sewing Machines
Lens error canon s95
There is something wrong with your lens barrel. It can be anything from some sand/dirt that got inside in which you try using some canned air to blow out the particles while continually turning it on and off. Usually what it is from is the camera being dropped, even if it is in a case or inside a bad. The jostle or direct impact of the fall will break some small gears or tweak the lens off of alignment. If it was from an impact then you lens barrel needs to be replaced and in that case the repair cost are usually as much as getting a new camera. You can send it into Canon and get it repair for a flat rate. Sorry about your camera.
May 24, 2011 | Canon PowerShot S95 Digital Camera
Camera was fine when I put it down, but when I went to take a photo the next morning the lens did not come out when I pulled the slide back.
There is something wrong with your lens barrel. It can be anything from some sand/dirt that got inside in which you try using some canned air to blow out the particles while continually turning it on and off. Usually what it is from is the camera being dropped, even if it is in a case or inside a bag. The jostle or direct impact of the fall will break some small gears or tweak the lens off of alignment. If it was from an impact then you lens barrel needs to be replaced and in that case the repair cost are usually as much as getting a new camera. Sorry about your camera.
May 24, 2011 | Cameras
When i break the barrel it doesent catch.
May 27, 2010 | Crosman Phantom .177 Caliber Break Barrel...
Crossman Sierra Pro Air rifle
The piston doesnt lock on the trigger. if trigger is adjustable set adjustment more coarse. Check also sure that trigger mechanism is in forward position and not stuck halfway. If still not hooking see if piston hooh and trigger catch not damaged. very seldom the piston will twist inside making it impossible to hook, just realign piston.
Jun 01, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Boating Logo
21 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
