Question about LG Refrigerators
LG fridge model GCL247ENSL not working compressor inoperative
    An expert who has written 3 tips or uploaded 2 video tips.
  • 126 Answers
LG refrigerator with inverter compressor type,model:gl-b552glhl. compressor can't start.l check all temp.sensor,fan it's working and there is small led on control board is flahing,can i have help.
What is the voltage reading at the compressor? Are the fans inside and outside the fridge working? I believe your model is found in Europe correct? Is there a computer board found on the back of your model? Can you provide photos? Contact Me Here
Appliance 911 Sea Breeze
Nov 03, 2015 | LG Refrigerators
I have an LG fridge that has ceased to work. Freezer works but is frosting up.fridge not cold at all. Compressor working and fan.
Generally need more info like Model number, some of the older fridges could be a defroster heater but the newer fridges have circuit boards.
Apr 04, 2015 | LG Refrigerators
LG model LFX21960ST. No cooling in either fridge or freezer. The compressor comes on for about 7 seconds when first turned on and then will cycle on for a few seconds every few minutes. The fan in the...
There could be a loss of freon(unlikely but possible), the start capacitor for the compressor is bad (most likely) or the thermal cut off switch on the compressor is cycling from the hot compressor.
Mar 28, 2017 | LG Refrigerators
I have a LG refrigerator model no. LFX25960ST that stopped working. All my meats in the freezer defrosted and the upper fridge is also warmed. I can hear the fan running. I unplugged it and plugged back...
it is not a great idea turning a fridge off and back on straight away. It will overload the compressor and cause it to trip out. I would suggest that the starter relay has failed on the compressor but if the fridge has been left to cycle on and off too many times, it will damage the compressor. Turn it off and get a fridge tech to look at it and confirm the fault.
Jan 28, 2018 | LG LFX25960ST Stainless Steel French Door...
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
Jul 19, 2011 | LG LRBN20520 Bottom Freezer Refrigerator
I have an LG fridge top / freezer bottom which I purchased exactly 3 years ago. The fridge has stopped cooling, although the inside light stays on. Also, the freezer is still working perfectly. Firstly,...
Most LG fridges have a 1 year warranty with some components exteneded, such as the compressor or sealed system repair. Those are usually 5 years or long, depending on the model.
Can you tell me the temp. in your fridge please? I have a strong suspicion that it may just be the thermostat.
Feb 03, 2009 | Refrigerators
Fridge/freezer inoperative
does your fan work in the back of the unit. Either that or it could have been your compressor
Dec 23, 2008 | GE GSS22JF Side by Side Refrigerator
Compressor constantly on too hot to touch
hi have you cleaned the matrix best done by blowing with air but a soft brush can work,make sure that all the cooling vanes are clear
hope this helps ian
Jul 21, 2008 | LG LRTN22324 Top Freezer Refrigerator
Whirlpool model #GT22DKXGW01 fridge. Compressor is inop, but I can hear a switch activating near the compressor. Is compress. failure common with this model?
copmpressor failurecommon with all refrigs regardless of manufacture, you can try replacing hte overload /relay assy, ( the box mounted on the \side of the compressor. you should also have a 5 year warr on the compressor if needed
May 14, 2008 | Refrigerators
Refrigerators Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
