Question about Garden
With spark plug out pull start works normal. with plug in it pulls very hard and locks up & will not return, using great amount of pressure it will come out afew more inches. viper mc 43
    Top Expert:
  • Garden Master
  • 51,307 Answers
Check the reach ( thread length) of the plug as it may be too long and hitting the top of the piston
if it is a small engine ( whipper snipper , chainsaw etc the reach will be about 12mm or 1/2 inch)
Posted on Apr 22, 2017
Echo t330 chainsaw has compression lock cant pull start cord
remove your spark plug and try to pull over. if it still won't turn over then you will have to decarbon your head or you have vapor lock so then with plug removed pull recoil and if fuel sprays out of plug hole keep pulling over until there is no more spray from hole. clean plug off. reinstall and try starting
Oct 14, 2014 | Echo Garden
Rope hard to pull
if there is an auto shut off adjust the cable its not pulling all the way open
Mar 08, 2014 | Karcher 2500 PSI Pressure Washer
Engine surges especialy when pulling hard
When pulling a load,especailly a heavy load,fuel is demanded and so is air,greatly,a failing fuel return,a partial plugged fuel filter,or even a dirty air filter can do this,
Aug 27, 2012 | Cars & Trucks
Enjine will not start. pulls too hard
if it feels as if the engine has jammed you can remove the spark plug and apply a squirt of WD40. then get a long thin screwdriver and push the piston GENTLY down a bit. this worked for me. replace the spark plug and start as normal.
Nov 19, 2010 | Dewalt Garden
Starter cord wont pull
Try removing your spark plug, you could have fuel on top of the piston or even "vapor lock". If that doesnt work try squeezing the trigger of gun/wand as you pull.
May 31, 2010 | Honda Pressure Washer PSI 3000
Gas powered pressure washer wont start
On pressure washers the more you pull the cord the more pressure builds up making it difficult to pull and start. I hold the trigger down as i pull this keeps the pressure down. If this is not the problem then take a look at the Spark plug, Air Filter if all is fine then check the fuel. How often do you use it, fuel loses its Octane when sitting around. Please give a 4 THUMBS UP if this free answer is helpful in anyways. Good Luck and have a Great Day.
Apr 02, 2010 | Briggs & Stratton Gas Pressure Washer...
The motor's pull start seems locked. How do I
Usually what I do first is pull the pump off the engine. After doing that use your hand to back the motor's shaft up about a quarter turn. Then without the pump on try to start the motor. If it starts put the pump back on and try to run it. Sometimes the crank and piston get set just perfectly so you cant pull it over. If that doesn't work post here again and I will help you further.
Jan 14, 2010 | Northstar Professional Series Pressure...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
