Question about Mercury Boating
2007 Mercury Verado 250. How to resest code 220 hi level switch
2 Suggested Answers
  • 48271 Answers
SOURCE: 50 amp fuse on Verado 250 hydraulic digital steering keeps blowing
dead short of pump motor is failing or under excessive load
have it checked by an accredited power steering pump specialist
Posted on Jun 07, 2017
Started to vibrate at 4300 rpm. Got a low voltage warning from smart craft. Could it be a bad spark plug or lose wire?
vibrate at idle ? or in gear? if in gear you could have a bent prop or worse a bent shaft , yes strong vibrations will shake the wires loose
if engine shakes in neutral too , then not all cylinders are firing , ck your wires for seated and tight on plug caps
power will be significantly reduced if not all cylinders are firing
Sep 16, 2015 | Mercury Verado 6 Cyl. Engine Cover 200 225...
I have a Mercury Verado 250 HP 2005. The problem is an oil loss. The only thing i am sure of it is engine oil and despite it was verified by Mercury dealer twice, they didn't find where it con
how many miles are on the car. it is normal for a care with a 100k or more to use a qt of oil about every 1500 to 2000 miles if you keep your foot in it. read your owners manual about how often you should check your oil. it is more often than you would think. think about using an oil additive that helps reduce oil consumption.
Nov 20, 2014 | Mercury Verado 6 Cyl. Engine Cover 200 225...
What is ratio per gallon for mercury 150 v6
Hi Daniel!
Oil mix is 50:1 (Quicksilver recommended. Go figure!)
Here's a link to your service manual if you need it.
Boatinfo Mercury Service Manual for 135 150 175 200 hp
Sep 09, 2014 | Raymarine St6002 Smartpilot Hydraulic...
Mercury verado problems
run the fault codes to determine what sensor/s put the engine /gear box in limp mode . Carry out the repairs then use a scanner to reset the CPU program
Aug 27, 2014 | Mercury Cars & Trucks
What year is Tohatsu M15B2 serial number 351A33838 outboard
You can contact Tohatsu directly using the form provided at the link below.
Hope this helps,
Aug 06, 2014 | Raymarine St6002 Smartpilot Hydraulic...
Verado will not trim up once out of the hole gets up to some position and will not go up any further during idle speed can fully trim the motor out of the water.
You need to check your power trim resevoir to see if it is full. Also check trim ram seals to see if they are worn. When there's bad seals, water penetrates the ram and will prevent the rams from extending to their full potentential under power.
Sep 26, 2011 | Raymarine St6002 Smartpilot Hydraulic...
We have a mercury 60 2stroke outboard engine and nothing happens when you turn the key to start it
go through the basics first: is the kill switch on, battery switch on, battery charged, are the battery cables clean? if not these then most likely the starter solenoid or the key switch itself
May 09, 2010 | Raymarine St6002 Smartpilot Hydraulic...
Changed the ignition switch on 150 EFI mercury Outboard
just take the old one off and put the new one on just like you took the old one off
May 05, 2009 | Raymarine St6002 Smartpilot Hydraulic...
Boating Logo
50 people viewed this question
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Joseph Hoffmann
Are you a Mercury Boating Expert? Answer questions, earn points and help others
