"No channels In master list" is displayed on tv screen. Remote will not work. Have put in new batteries, no success. HELP
techman
  • 3130 Answers
SOURCE: remote control
The correct model number is iLO2600.. That remote is available at http://www.remotes.com CHEAP!!
Posted on Sep 05, 2006
  • 280 Answers
SOURCE: remote control changing channels
Make sure to push the TV button on the remote. some times it will be in the wrong mode ie VCR.
Posted on Apr 18, 2008
  • 8 Answers
SOURCE: rca rcr860 remote manual code list
http://157.254.235.130/public/RCR860.pdf
http://157.254.235.130/public/RCR860_code_list.pdf
These are the sites for the manual and Code List
Posted on May 29, 2008
  • 979 Answers
SOURCE: no channels on the list
Be sure that you are on the "Tuner" input, and that if you are using a converter box, that you have the set tuned to the single channel that the box puts out. (In the US, that's either 3 or 4.)...accordianman
Posted on Jul 01, 2008
  • 718 Answers
SOURCE: Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Posted on Mar 16, 2009
My TV, AKURA AODV211T-S, the on screen display is not showing ? Unable to see volume level, channel numbers, menu display ? There is no info in the Manual Instructions book.
The display driver section circuit should be troubleshooted. Contact any experienced service technician. It is a skilled work; not a user repairable one.
Mar 22, 2013 | Audiovox Televison & Video
No channels in Master List message on Vizio xvt3d554sv with Dish Network Satellite...what to do?
I had this same problem. My TV had sound and the lights were on but no picture. The screen said "No Channels in Master List."Here is how I fixed it:1) I made sure that my Dish Remote was on the TV mode (when pressing down buttons, the TV button would light up).2) Once that was confirmed, I pressed 03 to ensure I was on Channel 3.3) (this was the hardest part!) I found the remote that came with the TV. I never use it so it was hard to find...4) I pressed the Input button and selected the correct Satellite option. On my TV, that option is: "HDMI-1 Satellite"5) The picture was restored!
Aug 19, 2011 | Vizio L37 Television
Remote will not respond. New batteries installed. I can change channels at receiver, but the remote will not do anything, even though all the led's on the remote will show lite when pushed. 6.4 ir/uhf...
Is the remote for TV 1 or TV 2. If it is for TV 2, the blue tab with the number 2 should already be on the bottom of the remote. If it's for TV 1, you need to remove the blue tab from the bottom of the remote and flip the tab over (should be a green tab with only a green 1 on it). Once you change the tab, see if you can change channels. If you can't, follow the instructions below.
At your TV 1 location on your receiver, press the System Info button to display the System Info on your TV. At the bottom of the screen, you should see Primary and Secondary Remote Addresses. Make a note of the remote addresses. With the new remote, press the record button. If this is the TV 2 remote (blue tab on the bottom), the secondary number may change; if TV 1 remote (green tab on the bottom), the primary address should change. Exit from all the menus on the TV screen till you are back to your TV picture - then try the remote.
If the above steps do not work, try the instructions below to manually program the remote to the receiver.
  • Remote to the receiver:
    1. Go to System Info screen.
    2. Hold down the SAT button until all mode lights light up.
    3. Enter a number between 1 and 15 using the numeric keypad on the remote.
    4. Press the pound (#) button.
    5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Aug 16, 2011 | DISH Network IR Remote Control
There. Is a channel lock on my tv. So I can't change the channels. How do I take it off?? Help!
Hello
you have to unlock your jvc set, and reset the V-Chip settings. There are two ways to unlock JVC TVs, you have to find out which proceedings frome below mentioned will work with your TV.
[1]
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
[2]
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password.
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger. TVPG provides you
May 10, 2011 | JVC AV-27020 TV
My problem is with my remote control...either cable remote or TV remote can only do one function -sound on channel selection my cable box (cablevision scientific atlantuc 4250HD) is programmed....the...
Set your device with an other set up code and then check. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Mar 04, 2017 | Samsung AH5900092W Remote Control
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
Mitsubishi TV Channel Tuning/Remote Problems
To restore full functionality to your set you must replace the remote that came with set. Universals only control the most basic of functions.
Apr 27, 2017 | Televison & Video
Can't clear channel off screen of Sony Trinitron with remote
Press (on your regular remote for your satellite) the t.v. button, then press info, this worked for me and I tried everything. another viewer posted this solution and it worked great! this is not the original remote, it is the satellite remote.
Nov 22, 2007 | Televison & Video
Menu will not display
If the channel and volume visual display was not set up on the menu to display on screen , neither will show up even if either the remote or set front button are used. Make sure that the tv button is selected on the remote to access the menu .If that does not work ,then either the batteries are dead or the remote is dead.If it is you will need a new remote,sadly. Then you can press the m button , select sound and then select "display volume" and check "during adjustment". The channel display settings are found on "features" from the main menu. Hope this helps.
May 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
