Question about Filter Heating & Cooling
Mach 3 shutdown when I opened the ceiling filter door
Tip
2010 BMW 528XI Garage Door Opener Homelink Setup
**** >>> This setup I performed with my new 2010 BMW 528XI Garage Door Homelink and Chamberlain Garage Door Opener <<< ****
Chamberlain:
01. Power off or unplug the garage door opener motor power supply (which is mounted on ceiling of the garage) ;;;
02. keep the garage door opener transmitter in your hand (do not press any button at this time) ;;;
03. In your 2010 BMW 528XI Homelink button (which resides under rear view mirror) press the 1st and 3rd homelink button together for about 30-40 seconds (i.e., until the yellow light blinks fast) and when the yellow light next to the homelink button blinks fast release from pressing the (homelink) buttons ;;;
04. now hold the garage door opener transmitter closer (means within 2-4 inches) to the homelink button (either 1st or 2nd or 3rd) whichever you are planning to program to open the garage door ;;;
05. now press the garage door opener transmitter button and chosen homelink button (either 1st or 2nd or 3rd whatever you need) together ;;;
06. the yellow light (next to homelink button) initially may blink slowly but after few seconds (may be 10-20 seconds) will blink fast; once it started blinking fast release from pressing both garage door opener transmitter and homelink button ;;;
07. Now plug or power on the main garage door opener motor (which is mounted on garage ceiling) ;;;
08. On the main garage door opener motor (which is mounted on garage ceiling) press the "LEARN" button (once you press it may have yellow/orange color light; make sure the light is on) ; then within 30 seconds do the next steps #9, #10, #11 very carefully ;;;
09. go to your car and press the homelink button you programmed and hold it for 4 seconds and then release it --> 1st iteration ;;;
10. again hold the same homelink button you programmed and hold it for 4 seconds and then release it --> 2nd iteration ;;;
11. again hold the same homelink button you programmed and hold it for 4 seconds and then release it --> 3rd iteration ** important note; generally three iterations are not necessary; and steps #9, #10, #11 must be performed within 30 seconds ** ;;;
12. during one of the iteration you will hear "CLICK" sound one-time from Garage door motor (which is mounted on ceiling) and if you have light attached with it; it will blink once (** if you hear the CLICK sound and/or light blinks once**) then the particular homelink button is programmed ;;;
13. now press the programmed homelink button; the garage door will open or close (but always it will take 3 or 4 blinks in yellow light or 2-3 seconds before the garage door opens or closes and which is normal) ;;;
** Thats it, your 2010 BMW 528XI Garage Door Opener Homelink setup is complete ** ;;;
You can program rest of the homelink button the same way but following from the steps between #4 and #13 ;;;
Hope this steps will help you to program chamberlain Garage door opener in 2010 BMW 528XI Homelink. ;;;
** possibly the above same steps may work with other BMW 5-series cars homelink too (but I'm not sure) **
on May 29, 2010 | BMW 528 Cars & Trucks
Need fan switch for coleman a/c model 6734B917
Any RV dealer should be able to get you one, if not try inquiring here.
http://www.rvcomfort.com/rvp/contact.php
May 24, 2012 | Coleman Mach 3 Plus Roof Mount A/c Unit W/...
How can I find the model number for the fan. I have a 1999 avion with a coleman mach air the fan makes a lot of noise.we oil it but it quit last night and I think it may need replacing.
The model number of you upper unit which can be seen from inside on bottom of unit behind filter etc at ceiling, will give enough info for replacement fan. Here's a good spot to find part #'s etc for your unit.
http://www.rvcomfort.com/rvp/tech_info/manuals.php
Aug 20, 2011 | Coleman Mach III Air Conditioner
I have a Manitowc ice mach, mod QDO452A. The customer complaint, the machine stopped making ice. The mach failed 3 times. the 1st time the mach was unplugged when I arrived. I cleaned the machine ( annual...
Based on your finding on your second trip, the machine shut of on one of the safety timeouts that limit the harvest and freeze cycles. Its possible that the evaporator has lost some nickel plating and the ice is hanging, but first the heat build up in the storeroom is a problem if you get running again come back a few hours later and check the ambient temp in the room,its probably above the machine design temp. Can a vent be cut in the ceiling? an exhaust fan to **** that heat away would be good.
Jul 01, 2011 | Manitowoc MAN-CVD2075 Condenser Unit...
Daikin a/c FDY100LVIR N81. installed in suspended ceiling approx 2 mtrs. away from ceiling filter inlet. No filter pad provided for this inlet?. Told to attach a piece of wire to end of unit to withdraw...
Is this a new unit? Lots of units now come with no filter slot. I'm assuming this is above an acoustic tile ceiling. 24x48??? You need to have a 24×24 filter back return grill that lays in the ceiling. That way you change the filter by standing on a ladder. I'm a little confused about the wire thing but, the installer should have thought about how the return air was being filtered BUT, technically not their "responsibility." I'm guessing above the ceiling there is no duct attached to the return side of the unit??? If this were my unit I would buy a filter rack and have it attached to the unit and have my filters the unit. I'm assuming this is a business so what about your fresh air intake?? What filters that??? You need a filter AT THE UNIT. Not attached to a wire or whatever some i*^*t suggested. Hire professionals with credentials capable of doing the job right the first time!
May 26, 2017 | Heating & Cooling
Front door won't open
Check water draining from mach...if not clean filter.....Good luck
Sep 29, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
A.c compressor kicks on and off
How long has it been there, without experiencing any problems? This just start recently? Have you cleaned intake air filters at ceiling? Fan keeps running?
Jul 18, 2009 | Coleman Mach 15 Air Conditioner
COLEMAN MACH 3 MOUNTING ON INSIDE OF CAMPER NOT ALIGNING WITH MY
Did you purchase a new Ducted Ceiling Unit with the Upper Unit air conditioner? If you are replacing an older mach 3, the ducted ceiling packs are not compatible and you will need to purchase the ceiling pack as well. The ducted ceiling pack part number for the 8333 series Mach III AC is below.
1. Heat/Cool Air Distribution Box - 8330B735
2. Cool only ADB - 8330A733
3. Wall Thermostat (if needed) - 7330G3351
Hope this helps.
Jul 01, 2009 | Coleman Heating & Cooling
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Heating & Cooling Logo
22 people viewed this question
Top Filter Heating & Cooling Experts
Coss
MightyMikeJr
Are you a Filter Heating and Cooling Expert? Answer questions, earn points and help others
