Question about Kubota Garden
    Top Expert:
  • Kubota Master
  • 48,419 Answers
Most likely a problem clutch
if it is an electric clutch operation check the voltage available at the clutch solenoid
Posted on Apr 22, 2017
Would like to add a creeper gear to my Kubota M110 tractor. I need to achieve .8 mph at 540 pto rpm's. Can it be done.
the specifications for the tractor show a transmission int-shift 24f/24r/(32f/32r) option with creep
creep speed is ( casset e type is listed at optional(.19-.74km/h)
.74 km/h = .459 miles /hr
the specs show that the pto speed is 500 rpms /1000rpms ( interchangable rpm)
reference www.kubota or m110gx-kubota tractor coorporation
you will have to talk with the service dealer technicians as from the specifications , what you want is available as an option
if not and you are using some sort of seeding machine , it may be an option to change the gearing in that machine to achieve the same results
May 16, 2017 | Kubota Garden
Kubota zd28 mower was running fine put away but now PTO wont engage.
if your saying that pto wont do anything , that's either an electrical short or a broken belt , in rare cases the clutches go too , now if your saying the pto engauges and stalls the engine or makes horrible noises , then that's a bearing , im betting the deck shaft bearings are in need of some serious grease work
Mar 04, 2017 | Kubota Garden
How many horsepower does a kubota tractor B8200 has / what year was it made
It was made between 1983 and 1990
Kubota B8200 Power:
Engine (gross): 19 hp [14.2 kW]
PTO (claimed): 16 hp [11.9 kW] (gear)
14.5 hp [10.8 kW] (hydro)
You can find more breathtaking information about this tractor at
Apr 29, 2015 | Kubota Garden
Kubota L 3300 rear PTO will not engage when very cold weather solution please
Try using a lighter gear oil - some oils are thicker in really cold temps - like molasses while its warm drain it and use a lighter grade, - check the manual and go with a thinner type - ask local car parts store. sometimes the manual will give a type for colder weather. Good luck
Nov 30, 2014 | Kubota Garden
Why will my zd21 kubota zero turn mower pto clutch not engage
First check fuse. Then with a volt meter check for voltage on the 2 wires going to the PTO clutch with the key and pto switches on but motor off ( you may need to trigger the seat switch as well). IF voltage is detected the clutch its self is suspect. If no voltage then check for power into the PTO switch and then out of. If power in but not out then the PTO switch is suspect. And keep chasing voltage down the line until you find the failure. Voltage travels from key switch thru fuse, PTO, seat, and reverse switches to the clutch
Sep 01, 2014 | Garden
Pto onmy kubota zero trun zg 23 wont work
Check to make sure you are getting power on both sides of the switch. Check the connectors going to electromagnetic engagement PTO unit. This is mounted right on the base of engine. Check ground wire coming from unit to make sure you have agod grounfd connection.
Feb 27, 2014 | Kubota Garden
Mower pto wont
Check the fuse if it is not blown, then check for power on both sides of PTO switch. If you have power on both sides then check all wire connectors and make sure the ground wire is getting good connection. Check for power at the PTO electromagnetic clutch assembly.
Kubota troubleshooting
Did you checked the battery voltage?
The engine was unused a long period of time?
Oct 19, 2013 | Motorcycles
My pto wont go in gear; 8n tracter.
Try it while just coming to a stop.or just starting to move forward.
Depress the clutch and push it back towards engagement position....because it's tied to wheel speed the moving parts might allow it to drop in.
Apr 15, 2009 | Ford 8N Tractor
Garden Logo
44 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
