Question about Simpson Washing Machines
Hi, our Simpson 5.5kg top load washing machine is coming up with error messages and beeping, the first one was E30, then the machine started again. The second one was E13. Can anyone help please?
SOURCE: Zanussi zwf1631w jetwash front loading washing m/c
had to call an enginer out, the problem was down to a faulty motor rota, to identify if e30 is this fault, rotate the drum (so the motor rotates) and try to start the m/c. if it runs ok you know to change the rota. hope this may help someone
Posted on Sep 16, 2008
  • 135 Answers
SOURCE: zanussi washing machine zwf1437w error code e30
E30 indicates a pressure system fault. There can be several causes but the most frequent is a blockage in the system.
First thing to do is check the filter on front of machine.
Please do this and report your findings.
Posted on Jan 29, 2009
SOURCE: GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
Posted on Mar 02, 2009
SOURCE: hi am getting e1 error in my washing machine
what is an E1 error message
Posted on Jan 04, 2010
  • 174 Answers
SOURCE: Zanussi E30 problem
hi this can be caused by an earth leakage on the motor or more likely the heater it only needs a few mAmps to do this. you need an insulation tester to find which is the culprit. or try disconecting the heater to see if you can get the machine past the fill stage.
Posted on Jul 30, 2010
My machine will not complete cycles
timer or control panel fault
if the water wont fill that is one error message
faulty water inlet solenoid
Jul 19, 2016 | Simpson Esprit 750 Top Load 7.5kg
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
Frigidaire affinity washing machine E30 error message
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Nov 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
Simpson washing machine error message e20
i am having a problem with it draining, it turns and washes though, where is the filter?
Sep 29, 2013 | Simpson Washing Machines
I have a Simpson ezi set 9.5 kg washing machine.It has stopped in the middle of a wash and the LCD screen I showing EFO.Can you tell me what this means and what I need to do to get machine to finish...
i have a 9.5kg simpson washing machine just 5months old and ive had this problem E20 quite frequently that its annoying. I printed out a manual and foundout why. i do not have the patience to remove draining hose im sure there is a simplier way. Ive notice if i tap the side of machine 3 to 5 times it drains lol! seriously never had a problem with my old 7.5kg hoover machine, please help
Jun 19, 2013 | Washing Machines
I have a Kenmore Catalyst washing machine, model #110.20056 992, that is triple beeping and only allowing one wash cycle type. Is there something I can fix on this?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 19, 2009 | Kenmore 3.2 cu. ft. Top Load Washer
Won't start
Feb 01, 2009 | Kenmore Elite 45986 Front Load Washer
Simpson encore 806 washing machine beeping and screen showing DF
DF means the temperature sensor is faulty. Replace it. Get a new one from your Simpson agent. Turn power off. Open panel by removing the 3 screws at the rear of panel & swing it up. If you are standing behind the machine look on the left hand side at the top of the circuit board. You will see a small white plug with 3 wires (red-white-black) Very carefully pull this plug toward you off the 3 pin base. The other end is the sensor pushed into the water inlet chamber. Pull it out. Push new sensor into water chamber (make sure black rubber o-ring is on it) Push wiring plug back onto 3 pin base. It can only go on one way. Do not force it or twist it as the 3 pins can be easily broken or damaged. Then close panel & power up.
Jan 11, 2009 | Washing Machines
My Bosch washing machine shows error code F37 and beeps
My Bosch washing machine shows error code F57 and beeps
Dec 09, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
Top Simpson Washing Machines Experts
Owen Barnes
Andrew Taylor
Andrew Taylor
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
