Question about Chime Home
Chiming on the hour
My religion anniversary clock with some top doesn't chime on the hour
3 Suggested Answers
SOURCE: Salton Chiming Wall Clock is chiming inconsistently
yes .
check volume setting.
if you have a manuval volume control try to clean inside of volumecontrol.if ok fine
or
if not ok Replace volume control with same type( new one.).
Posted on Nov 20, 2008
SOURCE: timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Posted on Nov 10, 2010
After spot cleaning mantle clock with German movement (circa 1960), the clock chimes properly on the hour but does not chime on the half hour.
I am hoping that you oiled it also? One trick I have found is to gently lift the hammers and release, sometimes the hammers will release and strike the chimes/gong. Do this 4-5 times and hopefully it will get it chiming for you again.
UsedClockParts.com
Nov 09, 2016 | Home
How do I get it to chime on every hour
most chiming clocks only chime on the hour from 6 am to 9 pm
if it is a digital clock with a chimer the set it to 12 hour and not 24 hour
make sure that the chime has a good battery in the chime circuit and it is set to chime on the correct hour
If the statement made to you was correct then it would be chiming at night instead of the day
Oct 13, 2015 | Home
My sterling and Noble westminster chime clock is not chiming. I have brand new batteries installed but still no chime
A handsome clock in solid red oak. The face is off white with a convex lens and a bright brass-toned bezel. The Westminster chime is pleasant sounding while counting the hours.
Runs on 4 AA batteries; two to manage the clock and two for the chime. The external speaker is located at the top of the clock for a clear, unimpeded sound. A button on the chiming unit allows you to control the striking of the hours.
You will see above that one set of batteries does the chime. Make sure they are good and inserted with correct polarity.
As mentioned, look for a button switch to turn the chimes off It is a feature so you can turn the chimes off when you go to bed.
Sep 14, 2015 | Home
My regulator wall clock is not running right.the minute hand is chiming on the hour and the hour is chiming on the half hour.
Remove the dial nut and switch the hands so that they are correct and replace the dial nut.
UsedClockParts.com
Jun 25, 2015 | Home
My wm widdop clock chiming out of sequence
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Oct 21, 2014 | Home
My clock chimes the correct amount of chimes on all hours except 7. At 7 it chimes 5 times
In a quartz movement clock, with a problem like this, the chime box (or whole movement) will need to be replaced. Timesavers.con carries a large selection of chiming quarts movements.
Jan 12, 2014 | Howard Miller Greer Chiming Quartz Wall...
Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Jul 29, 2009 | Seiko Mantel Clock
yes .
or
Nov 10, 2008 | SkyScan 86709 Atomic Wall Clock
Timex westminster anniversary chime clock doesn't chime correct number
Oct 04, 2008 | Watches
Problems with Howard Miller dual chime dual west and Beeth movement clock
If you manually set the time, the chimes will be off unless you wait for the chiming to finish before continuing to turn the hands.
Press the TEST button to get the correct number of chimes in synch with the actual time.
Jun 21, 2008 | Audio Players & Recorders
Home Logo
Top Chime Home Experts
spencer hughey
Level 1 Expert
john h
Are you a Chime Home Expert? Answer questions, earn points and help others
