Question about Refrigerators
How can I remove the clear plastic cover of the top shelf in the door of my BRFB1052FFBIN Blomberg built-in refrigerator?
I want to remove the shelf and I can't because the cover prevents me from lifting up the shelf enough to remove it from the door. Thank you
  • 1861 Answers
SOURCE: Chg Passenger Low Beam Headlight 02 Toyota Celica
Remove the plastic cover. No need to remove the assembly.
Posted on Sep 29, 2008
  • 833 Answers
SOURCE: Hidden Ice build-up inside plastic bottom cover of freezer
Generally, icing is the result of too much water vapor inside the unit, blockage of the circulation channels and too much packing in of the box.  The water vapor is generally caused by: uncapped items in the fridge, opening the door too often, humid conditions, bad door seals.  There is of course, there is a possibility that the defrost cycle on the unit is not working.  About once a day, depending on the brand, you should notice that the fans and compressor don't run and you should hear a bit of creaking, sloshing or other strange noises as the ice melts.  If this is not happening, your defrost timer or the coil it heats could be bad.
Posted on Nov 12, 2008
  • 3361 Answers
SOURCE: top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Posted on Mar 12, 2009
SOURCE: Whirlpool Refrigerator Shelf falling off support pins regularly
I got a new refrigerator that has the same problem. I solved it by cutting a triangular pencil grip for children's pencils down so they extend out just past the pegs on both sides (making them longer). The grips fit on snug, just like on a pencil, you don't have to screw the shelves in permanently which allows them to be taken off and moved. Works like a charm and holds the shelves in very snug.
Posted on Apr 05, 2009
  • 704 Answers
SOURCE: How do I replac the clear plastic cover over the ice shute on the
If you look up into the dispenser area, you'll find a small (1/4") hex head screw that holds the right side of the ice dispenser chute and flap in place. You can remove the screw and the clip that holds the assembly in place and you can remove the chute and flap from the door.
Once you have that out, you can see the clip on the chute that holds it in place on the dispensing lever. Unclip it and you can install the new chute by reversing the steps described.
You can also try to just unclip the chute, but you could break it or the dispensing lever/arm in the process, hence the reason for removing the assembly instead.
Hope you find this Very Helpful and best regards!
Posted on Aug 19, 2009
For right hand side door plastic egg holder clear plastic on "top shelf"
What's the problem with the egg holder? Please be specific.
In any case, to replace interior of a refrigerator is not easy. Must find proper parts, disassemble and reassemble door. Some time ago I had problems with plastic parts of the door and the repairman I called simply could not do the job because parts were not available
Refrigerator Parts and Accessories Frigidaire
Refrigerator Egg Tray eBay
Aug 31, 2015 | Refrigerators
Door shelf, need to take it apart.
Gently squeeze the sides of the clear door to allow its pivot pins to disengage from the surrounding plastic. After cleaning, repeat the process to reinstall it.
Dec 02, 2017 | LG LBC22518 Bottom Freezer Refrigerator
How the heck do you replace a simple lightbulb in the refrigerator of a ge ss double door? Very irksome that something that used to be so simple many people now have to ask for help.
I just looked at mine... it's a GE Profile as well and what I see is a plastic cover with the two temperature dial settings and the light behind the plastic cover. Once I removed everything from the top shelf, I simply reached to the back and under the plastic cover at the bottom and I was able to grab the light bulb and unscrew it with ease. It may look more difficult than it actually is.
Oct 28, 2009 | GE Profile PSW26P Stainless Steel Side by...
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Ice chute door hangs open ...kenmore 106.57904700
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
Sep 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Remove the top freezer door hinge cover and disconnect the plug . This removes power to the door . Using a butter knife or small screwdriver , insert it between the grill and the lower portion inside of the dispensor cover . Press down and inward slightly , to push the cover outward . On both sides of the grill . Plastic clips , so be careful . Disconnect the plug onto the cover and lift cover upward , to clear the upper tabs .
Sep 06, 2009 | Kenmore Refrigerators
Need top shelf for admiral refrigerator
Click on this link to see if they have what you were looking for.
Your refrigerator stopped being built more than 6 years ago, so some items are no longer available.
May 02, 2009 | Refrigerators
LG LRSC21934 side by side. Noticed lots of water on the top shelf. Replaced filter since it was due but the water is back after a few days. Seems to be coming from the removable plastic cover above the...
Make sure your door fits good and flat. I run a piece of paper all around it to check the seal. Close the door on the piece of paper and try to slide it. Check all around.
Apr 25, 2009 | LG LRSC21934 Side by Side Refrigerator
need to know brand locate the serial plate on most brands it's in the refrigerator compartment then i can name your part
Dec 30, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
