Question about Miscellaneous
How many liters in container measuring .670x.445x.600
    Top Expert:
  • 3,113 Answers
What unit of measurement is the .670x.445x.600?
Posted on Jun 01, 2017
2 Suggested Answers
  • 44 Answers
SOURCE: I have an icebox with internal dimensions of .670x.445x.600 just wondering if someone can tell me how many litres it holds Thanks
IF these numbers are the decimal fractions of a METRE,
then they actually represent the total number of MILLIMETRES for each dimension, and corresponding MILLILITRES if all 3 whole numbers (670, 445, 600) are multiplied together
which equals 178890000
so then it's 178.89 litres
Posted on Apr 23, 2017
Apr 23, 2017 | IceBox Computers & Internet
WMH1163XVD seems to no be on full power. Takes 1 minute to heat up a piece of bacon
1 minute to cook a piece of bacon sounds pretty fast, really.
Try this:
MICROWAVE HEATING POWER TEST
The following test will provide a suitably accurate measurement of the output power of any microwave oven. Variations or errors in performing this test will produce uncertain results. If the line voltage (from the electrical outlet) is low, the magnetron output will be correspondingly low.
Equipment needed:
- Microwave safe container with 1000 mL (1 Liter) gradation.
- Fahrenheit or centigrade thermometer
Procedure:
Pour exactly 1000 mL (1 Liter) of cool tap water into the container. Using the thermometer, stir the water, then measure and record the temperature. For accurate results the water should be about 60 degrees F (20 degrees C).
Place the container on the center of the oven cooking shelf (do not leave the thermometer in the container and remove any metal racks), and heat the water (at full power) for 63 seconds. Use the second hand of a watch, not the oven timer.
After the heating time is completed, immediately remove the container, stir the water, re-measure and record the temperature of the heated water.
Subtract the starting water temperature (step 2) from the ending water temperature (step 3) to obtain the temperature rise.
To determine the output power in watts, multiply the total temperature rise by a factor of 38.75 if you're using a Fahrenheit thermometer or by 70 if you're using a centigrade thermometer.
If the oven is grossly underheating or overheating, then you probably have a bad magnetron.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgdee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jul 18, 2011 | Whirlpool WMH1163XVS Microwave Oven
How many litres of transmission fluid does a 2006 Dodge Charger R/T (5.7L V8) contain to be considered the proper amount of transmission fluid? Ex. The 2006 Dodge Charger R/T should take 6.7 litres of oil...
I don't know the exact liters, but if you are just changing the filter it would be 5 qts, maybe 5 liters. And if you are in a total rebuild, it would be 15 qts, or say 15 liters, We don't work with liters over here. I know your 5.7 liter engine is about 340 cubic inches. A quart is real close to a liter, 3.8 liters = 4 qts. If your tranny doesn't have a dipstick, it has 2 plugs on the right side of the tranny, one for level, one for fill, If you pull the level and nothing seeps out, fill it up, till it seeps out the bottom, then put the plugs back in. The tranny will drip for a month if you let it, so when you change the filter, you never really know how much dripped out, exactly, you could measure what came out, but what if it was low to start? Check it out, hope this helps.
Dec 23, 2010 | 2006 Dodge Charger
Wattage Power
Unfortunately, the old owner's manual doesn't say, but you can do a test to see what its heating power is:
Equipment needed:
Procedure:
Apr 28, 2010 | Hotpoint RVM1435 Microwave Oven
What is the wattage?
Oddly, the owner's manual doesn't say.
You can contact GE customer service here, or if it's working properly, here's a test that will tell you how much output power it has:
Equipment needed:
Procedure:
Apr 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Hotpoint microwave oven, countertop, model RE964. How many watts is it?
The owner's manual (which you can download here) does not say, but most of their ovens from that era were 700 watts.
There is a way to check:
Equipment needed:
Procedure:
Jun 06, 2009 | Microwave Ovens
I have a microwave peanut brittle recipe but it burns, someone told me that I need to calibrate my microwave. How do I do that?
Equipment needed:
Procedure:
Dec 15, 2008 | Microwave Ovens
1) What's the expectect temp range for 1L water, for GE load test for 1KW ovens? 2)Why didn't my brand new oven come with a repair/maintenance packet like my old one did? Tom
1) MICROWAVE HEATING POWER TEST
Equipment needed:
Procedure:
2) If it's not
hidden either behind the grille or control panel, they may have left it out as a cost-savings measure.
Nov 26, 2008 | Microwave Ovens
My whirlpool microwave heats up the top cover / outer metal casing. It seems to get hotter and hotter, even though the food inside may not be all that hot. Eventually it may even stop running the...
If the cooling fan is not running, then that definitely needs to be addressed to prevent magnetron damage.
-.htmThere should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
-.htmYou can usually find helpful exploded view diagrams and order parts by entering your full model number here.
It might be useful to first do a standard heat test.
-.htmMICROWAVE HEATING POWER TEST
Equipment needed:
Procedure:
To determine the output power in watts, multiply the total temperature rise by a factor of 38.75 if you're using a Fahrenheit thermometer or 70 if you're using a centigrade thermometer.
-.htmWe're happy to help and we appreciate your thoughtful rating of our answer.
Jul 12, 2008 | Whirlpool Microwave Ovens
How can you check to see if your microwave oven is working at full power
Equipment needed:
Procedure:
Jul 06, 2008 | Microwave Ovens
Miscellaneous Logo
Top Miscellaneous Experts
ray012965
lugnuts1
ajschmitz6
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
