I need enough mulch to cover a 400 sq. ft. area 1 in. deep
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 126 Answers
CONVERT 1088 SQ FT TO LINEAR FT
each unit in sq ft is 1 X 8 = 8 sq ft X 16 =128 cubic ft and you have an area of 1088 square ft
not the same to get a quantity so think about the first dimension as you only need 2 to get sq ft
female or not , this is simple grade 3 maths in area measurements
Jan 24, 2018 | Heating & Cooling
I am trying to figure out the square footage for siding on my house the front and back are 50ft long by 8 ft high. the sides are 30ft by 8 and then the peaks
50 X 8 = 400 multiply that by 2 ( front plus back) = 800 sq ft
sides 30 X 8 = 240 again by 2 for both sides = 480 sq ft
add both sums = 1280 sq ft
now to work out the triangle areas for the peeks you have to provide the vertical heights of the peaks and use the formula for areas of triangles (1/2 base by height) to get the rest
however you have not considered on the window/doors areas that could be used in the apex areas
you have a basic area but you are advised now to get quotes from cladding companies who can calculate it to close area to save wastage
Aug 01, 2017 | Heating & Cooling
My pool is 16feet wide by 32 long 10 feet deep what is the square footage
What you looking to know?
Square feet suggests a flat area, like the floor plan of the pool, which would be 16 x 32 = 512 square feet. Like you'd measure walls for tiles or paper etc.
As you've given 3 dimensions, sounds like your after the cubic capacity/volume of the pool, in which case your looking at cubic feet (same as flat area above, but with the added depth to go from flat 2d, to 3d (2 vs 3 dimensions)), which would be 16 x 32 x 10 = 5,120 cubic feet.
Jun 02, 2015 | Pool & Spa
How many cubic feet for 1560 square feet 2inches deep?
2" out of 12" is equal to 2/12 feet; or 0.16666 feet.
1560 sq ft x 0.166667 ft = 260.00052 cu ft; or 260 cu ft
Apr 08, 2015 | Rubber Landscape Mulch Mocha Brown
1904 sq feet how do I convert this to linear feet for roofing
I have done tons of roofing and we always use square feet .length X width= sq ft .like 50 ft long by16 =800 then double to get both sides of roof is 1600 sq ft
Feb 12, 2015 | Cars & Trucks
168 sq. ft. how many cubic ft. for 6in deep, mulch
168 square feet by half a foot is 84 cubic feet.
Aug 31, 2014 | Office Equipment & Supplies
How to measure air conditioning tonnage to square feet of hom
Read size of air conditioner you need , each ton of air conditioning will keep cool 400 square.so higher ton yo pick you feel cool.please read below square feet to ton chart.
1 ton on 400 sq. ft.
2 ton on 800 sq. ft.
3 ton on 2000 sq. ft.
5 ton on 2570 sq. ft.
May 28, 2014 | Computers & Internet
Convert 2,000 cubic ft to sq ft
Cubic foot is a unit of volume. Square foot is a unit of area. There is no conversion.
Let's say you have 2000 cubic feet of mulch. That can cover a 2000 square foot yard one foot deep. It can also cover a one square foot flowerbed 2000 feet deep.
May 19, 2014 | Miscellaneous
Republic EZ broadcast spreader...what number to use when lining up the mark to calibrate the spreader...lost the instruction book
Hello, to solve your question about what number to use to calibrate your broadcast spreader, please use the step-by-step instructions below:
1. If you don't already know the square footage of your lawn, please walk off or measure, multiplying the length by width. For example, my lawn is 100 ft wide by 100 ft long; this equals 10,000 sq. ft.
2. Use this figure (30,000 sq ft) to determine how much fertilizer, insecticide, fungicide,apply etc., to purchase and apply.
3. To calibrate the spreader for applying your product at the correct rate, first weigh and hold out an amount of product to cover a pre-determined test area; for example, enough for a 200 sq ft space.
4. Because most lawn fertilizers are packaged to cover areas in 1000 sq ft increments, it's easy to figure how many 1,000 sq ft applications you need for your lawn.
5. Set your spreader to 3 and measure 1/5 of the recommended application on your product, to cover a 200 sq ft area.
6. Use your spreader to cover this 200 sq ft area.
7. If there is product remaining in the hopper after walking this 200 sq ft area, increase the setting number and move to another test area, repeat steps 5 and 6.
8. If there wasn't enough product to cover the test area, back the number down, move to another test area, and repeat steps 5 and 6, until you finish with product and lawn test area at the same time.
9. Remember to never leave product in your hopper because many chemicals are corrosive and can destroy the moving parts, making the spreader inoperable.
I hope this helps!
Apr 02, 2011 | Garden
What is the capacity on my Rheem Classic High Efficiency Outdoor a/c unit. I have a home that is 3200sqf. It seems to be on some type of a damper system... Is this unit big enough for my home?
depending who you talk to a ton will cover about 500 sq ft (as some say 400 sq ft others say 600 sq ft). I believe your unit is a 3 1/2 ton unit. Below is a chart
0sf-750 sf= 1.5 ton
751-1000sf= 2.0 ton
100sf1-1250sf=2.5 ton
1251sf-1500sf=3.0 ton
1501sf-1750sf=3.5 ton
1751sf-2000sf=4.0 ton
2001sf-2500sf=5.0 ton
I would say if you have two units then you are covered, remember the area(region) walls, ceiling and other climate factors will play into your tonnage for you house. The best thing is to consult with a honest and reliable a/c installer in your area. i hope this helped Tim
Sep 02, 2010 | Ruud UAMB042 Air Conditioner
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
