Question about Husqvarna Garden
How can I replace the drag link on my Husqvarna mower? I can get the front link unattached from the wheels but getting the rear link and access to it seems problematic.
  • Husqvarna Master
  • 645 Answers
You must drop the sector (steering) plate to access the back points. Mark your steering wheel so you can get it aligned once the drag links have been changed.
Posted on Nov 28, 2017
  • 115 Answers
the rear wheels are made stationary they can not be adjusted sorry!!!!
Posted on Dec 28, 2008
  • 284 Answers
SOURCE: Need to remove rear wheels to replace tires on MTD riding mower.
most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
Posted on Jun 14, 2009
  • 1564 Answers
SOURCE: HUSQVARNA-YTH1848XP riding mower with loose front right wheel.
Of course they are. The company sent you the wrong bearings.
Posted on Aug 22, 2009
  • 347 Answers
SOURCE: Rear brake pad dragging
Posted on Jan 01, 2010
  • 6468 Answers
SOURCE: Drive wheels won't freewheel when pulling mower backwards,
pull off what looks like hub caps and check the wheel clutches
Posted on Apr 05, 2012
Looking for repair manual for husqvarna 175cc 22 in self propelled rear wheel
Search by engine model #. If not engine problem search by mower model #+parts.
Jun 12, 2016 | Husqvarna Garden
My YTH2648TDRF has only one rear wheel that engages the mower, shouldn't both rear wheels drive?
The rear drive uses a differential to drive the rear wheels, just like a car, the differential drives the wheel with least resistance, to enable the wheels to revolve at different speeds when going round corners; so it's quite normal for only one wheel to be driven. If your mower is having difficulty with slopes (do you call them grades?) I suggest you fit a new drive belt, a slipping belt is the most common cause of low power. Hope this helps.
Jan 12, 2016 | Husqvarna Garden
Replace front drive front wheel mower
cost to much for gearbox wheels drive coggs just buy new one it would be better and dont buy front wheel drive they go bad to fast rear wheel drive better
Aug 18, 2014 | Husqvarna Garden
Husqvarna YTH1842
The ball joints are not replacable, you would have to change the complete rod pt no. 532175121 drag link from steering quadrant to the front l/h wheel, there is then a tie rod from letf to right pt no. 532171888
Aug 19, 2013 | Garden
2007 Sienna rear wheel stuck dont think it's the hand brake
Not sure why this is in a Husqvarna post... but anyway, regarding the 2007 Toyota Sienna I assume you're talking about:
You probably have a stuck brake caliper. They're easy to change, just search YouTube for a video, and look at this link:
Dec 31, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Adjust steering on riding mower 42 inch
If this is your front end, I'd say you probably bent the linkage rods. 61 & 62.
Most alignments start with the steering wheel centered, bring the closest wheel in to alignment, then work the other one in. Again, on these the links often get bent.
Jul 02, 2012 | Husqvarna Garden
Husqvarna 6021p push mower. How can I get the rope to recoil?
if it wont rewind you have to remove the recoil that retracts the rope replace it or repair it
May 19, 2012 | Husqvarna 675 hp 21" Honda Rear Bag Push...
Replsce steering cable
this is really a matter of your mechanical abilities - what i think is easy may not be for you -
Oct 18, 2008 | Husqvarna Garden
Garden Logo
42 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
