Question about Boating
How and where can I buy 2 steering cables for my motor guide trolling motor, 24 volt with 70 lb thrust?
3 Suggested Answers
  • 2702 Answers
SOURCE: The switch keeps burning out and the motor turns
i think its time to strip this motor out,, it sounds like its has a short in the field coil winding,,as its pulling far to many amps,,,,
Posted on Jul 01, 2010
  • 166 Answers
SOURCE: I have a Motor Guide
How does the prop rotate? Is it hard to turn? Have you checked behind the prop for fishing line? Are you getting 24 volts to the motor?
Posted on Jan 01, 2015
Good battery , good battery in remote 70 lb thrust trolling motor - no go. ?
Hey Rob,, ??? ..Did you have the batteries CCA checked?? Cold Cranking Amps..?.. this is the only check to determine if your batteries are actually "good"...Next, take a volt meter and check the voltage at the trolling motor connection..if you have voltage at the plug, its time to move up to the head of the trolling motor...Since I do not know what brand if trolling motor we are working on.. these guys will take care of you from here...
Jul 09, 2017 | Boating
Will a 12 volt lawn and garden battery run my 24 lb thrust minn kotta
Yes but not for long. You need to buy a deep cycle battery. Regards Phil.
Nov 18, 2012 | Minn Kota Endura 30 Freshwater Transom...
I have a Motor Guide Brute 767, 67 lb thrust 24 volt trolling motor. It will only run at about half speed even with new batteries.
I believe you may have a bad low voltage circuit board problem. I do not think they make the board any longer but you may be able to convert it to work by bypassing the circuit board. I am working on one now.
Mar 22, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
I have a 74LBS thrust trolling motor that hasn't never in my opion worked right, I don't think its wired right to get the proper 24 volts, However I have took it loose and hooked it directly to 2 marine...
Here is a picture of the wire connection for 24 volt. Compare to yours is it correct? If it is, I wish you listed make and model I could of sent you the right picture diagram of you motor. Use this picture as a starting point. Test the wires through the motor testing for 24 volts. Again if I knew make and model I could show you exactly were. Last if voltage is correct all the way through. The motor is the last thing to tear down. If the brushes or armeture is damaged in anyway, or manufactured wrong, it would lead to power loss.
Nov 18, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Proper batterie hook up on minn kota 70 thursh
Raventrans click this link to take you to a website which will you can click on schematics. I suggest adding a 50 amp fuse for your 70 lb thrust unit. scroll to the end of the schematic to find the battery hookup for a 24 volt hookup.
Oct 15, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Boating Logo
24 people viewed this question
Top Boating Experts
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
