Question about Craftsman Garden
The original owners manual does not have the part number that I'm desperately trying to locate. Need all part numbers for drive/brake assembly for craftsman 917289080
  • 5,299 Answers
Sears Parts Direct has the parts diagrams for the 917289080 here: . I suggest you start with the Ground Drive diagram.
I hope this helps.
Posted on Apr 22, 2017
Apllied park brake and a spring broke, need manual, part number, schematic to reinstall
Manual can be gotten in electronic form from sears at the website (linked at end of post), where you can download manuals for lots of appliances, tools, etc. Flip up your tractor's seat and look for the model number sticker, should be near the battery if battery is under seat. You will need the model number (model, not serial) to find the right publications. When new, the tractor probably came with an owners manual and a parts manual.
Alternative: get your model number, google it and the term "parts manual," and you will probably get right to the info at several websites.
Amazon is a possible parts source, with some decent vendors and prices; I've ordered several repair parts for my 2009 YTS 3000, which is technically a model 917.289210. That should be the pattern for Craftsman model number: three digit number probably starting with nine, decimal point, six digit number. Note that my owners manual has a typo and omits last character of model number. Watch out for such printing errors; you might be actually looking at the correct publication but it's mismarked. Be sure to save a PDF copy of the manuals so you'll have them later. Craftsman Riding Mower Tractor Parts Repair Parts Sears PartsDirect
As for assembly, the parts views will be some help. Once you get the new part it might be pretty obvious. For example, there might only be one hole or hook relativley close by that other end of spring could attach to. In general, all the "parking brake" does is hold the foot brake pedal down in the applied postion, not much different from jamming pedal with a stick (no I do not recommend this method). Unfortunately, due to safety interlocks, you need the parking brake to work if you want to leave the seat while tractor is running, as you've probably discovered.
Jan 17, 2016 | Craftsman PYT 9000 26 HP 48" Yard Tractor
Why does dishwasher start, run 3 minutes, begin drain cycle then stop?
Okay, maybe it's the spelling that's a problem. Try Case Brake Assembly, or Brake Case assembly. The part number (for your dishwasher) is DD94-01005A. It's available from for about $54. You may also need the Case Sensor, part # DD94-01006A for about $44, but I would start with just the Case-Brake Assembly first. 90% of the time, that part alone will fix your problem.
May 26, 2015 | Samsung DW7933LRABB
My Serial number is 94590994 and I cant tell what universal remote I need. TV is Stuck on channel 2
Do yourself a favor and save time, money and aggravation and locate an original remote, universals if they will program will be missing key features the original had.
If you insist on a Universal, use your computer and Google with the model number search for remote. that should give you a few hundred different remotes that might work.
Dec 15, 2012 | Toshiba 32A33 32" TV
My buttons dont work
The set (carefully read owner manual to see--has a feature that locks out the front controls--getting very common now---likely will need the original remote but look at owner manual first---have not got? Google the model number with "manual" to try to locate a free one.
Apr 09, 2012 | iLO IWT3206 TV
How to set up?
The owner manual should have all the info you need--if you do not have it GOOGLE the model number to try to locate it.
All setup is done with the original remote in the main menu except how to hook up (owner manual usually has extensive details for that).
Mar 31, 2012 | Televison & Video
I am desperate to find an owner's / instruction manual for the Promaster SST Citizen Eco Drive watch.Please TELL ME A PHONE NUMBER I CAN USE TO OBTAIN THIS.
To determine the exact model and specifications of your Citizen Eco-Drive, flip the watch to the reverse. On the case back will be extensive information about your timepiece. You're looking for the "movement caliber," a four-character combination of letters and numbers, separated from the seven-digit "case number" by a hyphen.
Next step, visit this links:
Hope this helps (remember to rate this answer).
Apr 14, 2011 | Citizen Eco-Drive watch
Go to Click on Manuals and then list Weider on the manufacturer tab. I originally typed in my model number and mine didn't come up, but later I sorted through the list of all models and mine was listed.
Oct 16, 2010 | Weider Nutrition Weider Total Body Works...
Desperately need specs.& a diagram for hdd led, pwr led, pwr switch. they have been disconnected from the motherboard
What is the part number of your motherboard?
Look on the motherboard for a part number. Usually it is a combination of letters and numbers.
Common motherboards are Gigabyte, MSI, ASUS, Asrock, etc
Type that part number you found on your board into Google. You should be looking for a weblink that points to the manufactures website. eg
If you wish, write down the part number of the board and then go to the manufacturers website eg and then type in your part number.
You will be looking for the motherboard manual once you locate the motherboard on the website. If you do have the manual it is usually shown where the computer case leads go in that manual.
One another note, often with a magnifying glass you can work out what leads go onto what pins on the motherboard pin assembly. for eg the speaker connections are usually marked SPKR (or something similar) and the adjacent pins will be for the RESET, LED, POWER etc etc
Good luck, ask for more help if you need it.
Apr 13, 2010 | E-Machines (308714) Motherboard
1996 ford f250 4 wheel drive truck
Item Part Number Description 1 N800794-S60 Bolt, M16-2.0 x 50 2 N601797-S2 Bolt, Caliper Mount M12-1.75 x 30 3 2C150 Pin Assembly 4 2C357 Disc Brake Caliper 5 1175 Seal 6 3423 Bearing 7 3105 Front Wheel Spindle 8 4221 Differential Bearing 9 4222 Differential Bearing Cup 10 1190 Wheel Seal 11 1102 Front Disc Brake Hub and Rotor 12 1102 Front Disc Brake Hub and Rotor 13 1197 Locknut 14 1B198 Lockwasher 15 1C245 Thrust Washer 16 35704 Dana Nut 17 2K004 Front Disc Brake Rotor Shield 18 2B292 Anchor Bracket 19 3130,
Jun 11, 2008 | 1996 Ford F250 Crew Cab
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
