Question about Mantis Garden
I have an old stile mantis tiller. there is a screw holding clutch drum on . what direction does it turn to come off. cant turn it either way.
    Sergeant:
  • 342 Answers
Try a bit of lube spray and then a bit of heat. It will come good if you know what direction the clutch drum spins. It will be the opposite way. Perservere it will come off.
Posted on Apr 23, 2017
Testimonial: "it took the heat and a hammer to break it loose."
Carburetor settings on Mantis tiller
Turn the carb mixture screw all the way in until it bottoms out and count the turns as you do that, then turn it out the same number of turns plus 1/2 more and see how it idles, if it runs poorly try turning it in and out slightly for best idle.
Oct 15, 2016 | Mantis 2-Cycle Tiller
Engine runs tines dont
The following was extracted from the Mantis owners manual..
At some point, you may find that the tines won't turn when you press the throttle. This may mean the engine isn't sitting all the way down on the worm gear housing. Perhaps you've been using your Tiller
for several years. Or perhaps you've removed the engine for use with the Mantis hedge trimmer attachment, then replaced it. In either case, the flange bolt may have come loose and lifted the engine up.
If this happened you'll notice a gap between the bottom of the engine clutch case and the top of the worm gear housing.
To fix this, loosen the flange bolt. Take the engine off the worm gear housing. Notice the hex head on top of the drive shaft . Inside the clutch case, you'll find the clutch drum. Make sure the hex head
lines up with the clutch drum inside the clutch case. Then put the engine back on the worm gear housing. Make sure the plastic carrying handle is not under the fuel tank. If you've followed these steps properly, there will be no gap between the clutch case and the worm gear housing. Make sure you tighten the flange bolt.
Jun 12, 2015 | Mantis 2-Cycle Tiller
When I Start Mantis Tilleer it starts in gear ( tines are turning)
The Mantis has a speed controlled automatic clutch.
Lower the idle speed by turning the idle screw counter clockwise. The idle screw is attached where the throttle cable meet the carb. The screw has a pointed end that resembles a pencil point.
The engine speed should be adjusted just above stalling.
If the tines turn even when the engine pull rope is pulled, the the clutch is defective and needs repairing.
j
Aug 03, 2013 | Mantis Tiller
My Mantis Tiller won't start and there is grinding type noise when I try and start it. I recently did some very lengthy trench digging over a period of about 2 months.
It sounds like the clutch springs may be overheated and the clutch shoes rub while you try to start it.
If you loosten the screw that holds the engine to the gear box you can try to start it without the clutch and see if that is it.
Good luck
Apr 08, 2011 | Mantis 4-Cycle Tiller
My Mantis tiller is 9 or 10 years old. I've recently had the carburetor replaced but this year the tiller won't idle. The tines want to turn and you have to hold in the air to start it and move it to the...
My name is Dane and I am going to assist you in solving your problem.
You should have an idle screw adjustment on the carb to adjust the idle RPM. As you pull the trigger, watch on the carburetor for a small moving plate. The idle screw should touch that plate. Be very careful, and have someone hold the tiller and start it. Back off the screw just enough until the tines stop turning. I hope I've helped. If you found this reply useful, please leave me some THUMBS UP, if you feel I've deserved them. Thank you! Dane
Dec 06, 2010 | Mantis 2-Cycle Tiller
We have a Mantis electric cultivator that won't start. it's only a couple of years old
Electric tiller, and it will not run ?
I would check the cord that you plug into.
You must remove the plastic housing, by removing the screws.
Next look at the plug, is it in good shape, has anything been pulled out of it ?
The motor brushes should also be inspected.
Please let us know, we repair all Mantis equipment.
Jan 27, 2010 | Mantis Electric Mini Tiller/Cultivator
Engine looses power, then speeds up, then looses power again
This sounds like the little fellow is getting hot. Are you using a good oil in the fuel don't skimp on that oil use the best you can find and get a new plug to sounds like the oil is killing your tiller.
Aug 02, 2009 | Mantis Tiller
Mantis 2 cycle - tines lose power.
I had this problem today. Loosen the flange bolt. Pull the engine off and check that the hex end of the shaft is lining up with the clutch pad in the engine-that it seats properly. Then make sure the shaft is seated all the way into the worm gear and put the engine back on. You will probably have to wiggle the shaft until it seats into the clutch. Tighten the flange bolt when the engine is seated flush with the worm housing (with no gap). That's all I did and the power is back up. Hopefully you still have your manual with the parts blow-up. (page 29?) BTW, have you checked that the wormgear is greased?
Jul 05, 2009 | Mantis 2-Cycle Tiller
Cord is frozen and tiller won't start
take pull rope cover off and oil the clutch that screws on the crank shaft
Apr 24, 2009 | Mantis Tiller
Won't stay running...
I had the same problem with my mantis. It would start fine after a few pulls, but had no power. I changed the plug, replaced the carb completely...nothing helped. Took it to a shop and paid $70 for a tune up that didn't help at all, and the shop owner just said "sorry".
After everything else was done, I pulled the cover off the muffler, (3 screws) then removed 3 screws over a small spark arrestor screen and found it was clogged...cleaned it and guess what...IT WORKS FINE NOW!
The best and easiest fix I have ever done to a small engine. I felt like an idiot, because the exhaust side of the motor MUST be clear to work properly on small engines. The only reason I was removing the muffler in the first place was to check the compression and VOILA!!!
An easy and quick fix I recommend for all Mantis tillers before you waste money on carb issues (which is what the company will tell you to fix to solve this problem).
Apr 19, 2009 | Mantis Tiller
Garden Logo
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
