My tv led 32HD won't turn . After I opened saw two capacitors of 6.3 v 4700uf was raze up and I changed them but still .on stb only.
2 Suggested Answers
  • 26 Answers
SOURCE: Ilo-32HD
Check the menu to make sure it is not in a lock mode. If that is OK, it probably needs a control board. On some brands that might be called a digital or tuner board.
Posted on Jan 22, 2008
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
I have started setup for hd cable. Am connected to hdmi and have picture and sound but am unable to change channels. What do I need to do.
With the HDTV set for an HDMI Input that matches the HDMI Jack that you've connected to the cable HD STB (set-top-box or "converter"), use the cable STB remote to change channels on the STB - not the TV.
You can not change channels of the STB with your TV remote. You may however, be able to program your STB remote to operate your TV. Most will allow you to power the TV on / off; volume up / down / mute; change input (HDMI1 / HDMI2 / ANT / Composite / etc.) and even some of the more complex functions as well. Contact your cable company for more details.
Feb 25, 2016 | Sylvania Televison & Video
Samsung UN32F5500 32-Inch 1080p 60Hz Slim Smart LED HDTV -- turning on and off, fix?
sad to inform you but we do not have any parts for anything here on FIXYA.COM .
Nov 05, 2015 | Samsung UN32F5500 32-Inch 1080p 60Hz Slim...
Why
Tried changing the power supply ?
JA
Aug 11, 2014 | Televison & Video
The yellow LED on my Toshiba 32CV510U flash all the time and TV won't turn on
check some leak or bulged capacitors at the power supply board then replace it.
Oct 02, 2012 | Toshiba 32CV510U LCD TV
Dear Guru, im Peter thanks 4 ur quick response however my problem still remains with LED samsung 40''...i have no display just standby red light it connected with cable (satellite televion) and remote...
Hello Peter, my suggestion is unplug your cable satelite (STB) conection.
Turn on the TV and see if there are changes or is still standby.
If your TV like normal after unplug satelite tv (STB) connection, you should check you STB.
If still not working, try to unplug AC cord from power line. Wait until led display indicator off, that plug again. If it still not working, i think you should call samsung technician to check you tv.
thanks.
Mar 17, 2011 | Televison & Video
Tv will not power on. Led light is meaningful.
Is very unlikely that the backlight inverter board is defective, even if it was the tv should power ON but will not illuminate the screen and no video.
Check this link to find the power supply.
Jul 25, 2009 | iLO 3200 32 in. LCD Television
Hitachi 50UX58B won't turn on
try checking c707 you have to look close they go bad look around it i had the same problem a small pin hole burn in it
Sep 16, 2006 | Hitachi 50UX58B 50" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
