Question about Coffee Makers & Espresso Machines
My coffee maker keeps turning off. It makes coffee and then turns off. I turn it back on, and it turns off again. I know it will turn off in 3 hours or so, but this happens in 5 minutes
SOURCE: toshiba 62hm15a
my tv was making a similar sound so i took off the back. There was a bundle of wires that had come loose and were rubbing the fan blades. I retaped them back and no more noise. seriously.
Posted on Sep 30, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: coffee pot won't turn on
The parts to repair a problem of this magnitude are generally not available. The DCC-2000 has a thre-year warranty. I would call Cuisinart and see if you can get an in-warranty replacement. I have a high opinion of cuisinart and their products, but this particular coffeemaker, I do not personally reccomend.
-Tha Mp3 Doctor
Posted on Mar 20, 2009
SOURCE: AFTER ABOUT 5 MINUTES IT TURNS OFF THEN I TURN IT
I found vibration also made mine go out... Found square cap beside transformer had solder connection on one leg cracked loose and 2 other through board connections cracking... Reflowed solder on all through connections on primary side of Power supply fixed problem.
Posted on Mar 02, 2010
espressonist
  • 1711 Answers
SOURCE: my keurig coffee maker turns its self off, even
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Posted on Aug 15, 2010
SOURCE: A couple of days ago, coffee maker turned it self
spoke w/ Cuisinart. Unplug unit for 1 hr, then plug back in, reset clock & Auto Off setting. This resets the unit back to the factory settings.
Posted on Sep 14, 2010
Testimonial: "great it works!!! thank you so much!!!!!"
I just bought this coffee maker. I love it but the most I can program it to keep my coffee hot is 4 hours. I want it hot all day. What can I do? When it goes off, I can't even turn it back on again, even...
It is supposed to hold the coffe hot for 59 minutes , no more . After that it shuts off , fire hazard . Then you are supposed to wash it and make new coffe . Coffe after one hour tastes burnt , no good . Always make fresh new coffe .
Oct 28, 2013 | Cuisinart DCC-1200 Coffee Maker
Why does the plug loosen and my coffee is cold after pouring???
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers Good luck. bobbyone
Dec 13, 2009 | Faberware FCP240 Coffee Maker
My almost new Keurig (which I LOVE) keeps shutting down
I am having the same problem and will report back here if I find an answer. If I keep turning mine back on, wait for it to go off by itself. Turn it back on again...and again. Eventually I can get a cup of coffee. But my one-minute coffee cup usually takes 15 or 20 minutes.
Mine was a gift, so I'll probably just see if I can swap it out.
Cuz that's some good coffee.
Dec 13, 2009 | Keurig B100 Coffee Maker
How to use coffee maker
This type of coffee maker is made to keep hot water always ready to make another pot.
Pour water in ( at least 4 cups)then turn it on with the pot installed to catch the water. It takes a few minutes to get it hot . You might hear it heating. I can with mine.OK after the heating sound goes away put some coffee in the filter and in stall the filter.Now, fill the pot again (at least 4 cups) and pour the water in and put the pot ready to catch the coffee.It makes the coffee fast because it already heated the water from the first time you poured it in.When finished with the coffee just turn off the burner only.These types are made to stay on 24 hours a day.
I just turn mine off and let it heat up the water in the morning.
Nov 04, 2009 | Bunn Pour-O-Matic VPR
Faberware FSU-122 coffee maker does not perk
Oct 16, 2009 | Faberware FSU122 Coffee Maker
Self cleaning the quisinart coffee maker
I always use a mixture of 50:50 of cold water and white vinegar to help clean the internal parts of any minerals and scaling.
Unplug the coffee maker first, then add the water/vinegar mix to the reservoir.
Place a new, clean paper filter in the basket to help catch any deposits that will be dislodged and cleaned from the coffee maker.
As far as having the coffee pot dry, there is no need for that. I do tend to wait about 15 minutes to let the cleaning mixture disolve any deposits in the main water reservoir and then I turn on the coffee maker and let it process the water/vinegar solution through it.
Once it's done, turn off the coffee maker and discard the solution in the pot. And rinse out the coffee pot/carafe with clean, fresh cold water. Remove and throw away the used paper filter element andrinse out the basket with warm water and put it back on the unit.
Now fill the coffee pot/carafe with fresh, clean water and pour that into the coffee maker's water reservoir. Put in a new, clean, paper filter and turn the unit on and run a plain pot of water. This will help to clean out any remaining residue and clear the unit of the vinegar taste and odor.
Now you're all set to start making fresh tasting coffee again. I always recommend using filtered water for the best tasting coffee, as the taste is a direct result of brewing temperature, water purity, and the coffee you use.
Hope you find this Very Helpful and best regards!
Sep 22, 2009 | Cuisinart DCC-1200 Coffee Maker
Started making a Skeechy sound after making coffee.
It is possible there is a problem with the tank heater. Please get the model and date code located on the bottom of the machine. Then contact customer service with this information. The brewer contains a 3 year warranty and if your brewer is 3 years or less will be replaced at no cost. If it is over 3 years, then it will be replaced at a reduced cost.
Jun 01, 2009 | Bunn 10 Cup Home Coffee Brewer
My Bunn coffee maker boiles over the top vent
Try taking the top off the unit (3 screws) and remove the pour-in tray (1 bolt) and turn the thermostat down. Replace the tray - making sure you put the silicone washer in - put the lid on, and try it again. If this doesn't cure it, your thermostat is bad, and you need to replace the unit.
Nov 11, 2008 | Bunn GR10 Coffee Maker
My cuisinart coffee maker DGB-900 series beeps and wont make coffee unless I turn it on and off a bunch of times. The filter basket just keeps turning and clicking. I have cleaned it and checked to make...
The machine will not run if the covers /for the coffee grinder, the filter basket and the machine itself) are not properly closed.
It will beep and stop running if it is turned on when one of the covers is open or if one is opened before the end of the cycle. The beeping will stop as soon as the cover is closed.
To start the machine again, press the ON button.
If it still not will operate, head it back to the store.
Hope this will help you
/Mirran
Jul 01, 2008 | Cuisinart DGB-600 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
