Question about Vizio Televison & Video
I have 55 vizio after thunderstorm picture comes on for minute or so then goes to black screen or to vertical colored lines and static. Is this Tcon board?
  • 203 Answers
SOURCE: Vertical colored lines on screen-no picture
It's definitely possible. I'd have it checked by a repair center for something like this.
Posted on Jun 10, 2007
  • 217 Answers
SOURCE: vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Posted on Aug 03, 2008
  • 8457 Answers
SOURCE: I have a 42" Vizio picture has an annoying thick red line
Ur backlight inverter video board is dying.
Need a new one.
Posted on Sep 22, 2009
SOURCE: vizio p50hdtv10a no picture, gray screen
This could be several things. It could be the main board 3850-0042-0150 or the plasma controller board 6871QCH083A.
Depending on what you actually see on the screen it may as well be bad Y sustain board (although less likely).
Unless someone has seen that particular issue in that particular model (or other that share the same deffective component) it will be anyone's guess which is the exact module. They all can be causing what you describe.
Since TV shuts itself in one minute I'm leaning towards the main board.
I'm afraid you'd have to either experiment or bring it to a service center that will either have such a TV and can try or will experiment on your behalf. Just make sure you do not pay for boards they experiment with. I know some of the other TV service shops in our area (and without a doubt elsewhere too) do that.
A TV service center (just as anyone with regular contacts with eBay) can resell incorrectly ordered part and end up losing $10-$20 on it which , if split between customer and technician, I think is completely fair. Just make sure you don't end up paying for a board that was ordered and turned up not the one in fault.
Posted on Oct 31, 2010
  • 8 Answers
SOURCE: I have colored vertical lines
Check the wire that goes from the main board to the actual LCD board. Unplug it and wiggle it around before plugging it back in. The cable is notorious for going bad. If this solves it you should be fine for a while. Eventually you may need to replace the wire. The TCON board is most likely not the culprit in this case.
Posted on Mar 01, 2011
Vizio 55 inch T V/ model # SV470M
The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details about flat panel TV repair then check the following link.
Jul 24, 2016 | Vizio 8 Feet High Speed Hdmi Cable Model...
Vertical color lines on an Insignia 55 inch t.v.
If you wish to get some details; check the site linked here. Pull up older posts.
May 14, 2016 | Insignia Televison & Video
Can be T con board or the LCD panel itself . Only be able to confirm by replacing the tcon board.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Seach for TCON Board article
Mar 21, 2016 | Televison & Video
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
I have a Sony KDLW3000, the picture has colored vertical lines on the whole screen,
The Tcon board is usually at fault with that symptom. You can get a replacement Tcon from
Apr 01, 2012 | Sony KDL Televison & Video
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Screen turned black except vertical color lines in the center
good day your vertical ic is defective needs to replace look for qualified technician to fix your tv
Jun 20, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Need a new one.
Sep 22, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Screen is half picture and half black with vertical colored lines
I had the same issue. I could get the tv to work intermittantly by pressing on the boards while playing. This points to bad solder joint, so I resoldered every molex plug connector, and it nows works like a charm.
Apr 06, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
