Where do I find key board functions? - Computers & Internet
Hi, am ganesh functions keys
If those are the only keys on the key board that are not responding, I would try to
1. boot in safe mode and check response. If you have other keys on the laptop that are not working,
2. I would boot operating system from a flash drive and check
and if both still are not working for you
3.try an external key board
Last replace the key board
Hope this helps
Sep 05, 2013 | Gateway NE56R Dual Core 2.10GHz 4GB 320GB...
Where is the number lock key on the dell inspiron im5030
there is a large hole in the keypad user manual for the keypad on your laptop almost as if there is no number lock installed
the closest that I can get on the net is that the function key adds extra keys to the board
however with out a board to practice on that is not much use
next suggestion is to take the laptop to a dell service agent( maybe a shop that retails dell products ) and see if there is anyone there with information on the keyboard that can show you how to get the number lock to operate
It has to be on the board probably in the layers of the function key and with help it will be revealed
on a normal board the number lock has a small square box with 1in it
so that symbol appearing when function is used may be the key you want
May 07, 2017 | Dell Inspiron Computers & Internet
I do job on hcl black and white monitor its functional keys f1 to f6 has been unlocked plz advice me how can it be unlockes
Peculiar ! no chances of blocking functional keys F1 to F6 or upto F12. Clean the functional keys. You may find solution, but depends on key board manufacture. Or otherwise, better to change key board, try, choice is yours.
Feb 28, 2011 | Computers & Internet
Need to find list/definitions of "function Keys"
Please open this LINK, scroll down to page no. 2-5 i.e. the section with "To use the Function Hot Keys Fn". There you'll find the details about the functional function keys of your compaq. It seems your function key i.e. Fn key is activated, to deactivate, press and hold down the Fn key while you tap the Numlock key once.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Feb 26, 2011 | Compaq Computers & Internet
My key board with Dell Latitude laptop key board is not working. I purchased MK 250 wireless key board and conneted to TV for display The functional key for selecting the monitor is not there on the new...
The keyboard has a feature (and associated button) called F-Lock. By default, when the computer boots, F-Lock is turned on. In the F-Lock mode, rather than sending the standard key commands for the function keys, the keyboard sends special alternate commands (like print for F7 and save for F8) that are configured in the iTouch program. In order to force the keyboard to send the standard function key commands, you must TURN OFF F-Lock by pressing the F-Lock button! Oh, and by the way, there are no indicator lights on the keyboard, and the F-Lock button is an always up momentary button - just like the keys on the keyboard, so there is no way to tell what state it is in, other than by pressing it and then pressing an F key to see what happens!
This should solve your problem. Just turn off the F-Lock Mode.
Hope this helps if it does please leave a comment or a vote.
Thanks JHH
Dec 04, 2010 | HP DC170B Keyboard
KEY BOARD NOT FUNCTIONING. absolutely new laptop
There may be a function on the keyboard to disable it. Look on keyboard and see if there is any function keys that has a keyboard on it. You may need to press the FN key and the other key with keyboard to enable and disable the feature.
Oct 22, 2010 | Acer NSK8458AN Keyboard
Other keys are functioning except for key number 9 and key for option
Hi, What controls the keys on phones are little IC chips inside the phone on the phone board. When it gets damaged it affects the number keys. Replace the IC chips are the number key will function.
Take care.
Oct 05, 2010 | Cell Phones
The function (purple) key symbols type when I am trying to type non-function (white) symbols. When I press the function (purple) key, the white symbol types.
There's a "Fn" key on the bottom left hand of the key board.
This key switches between the purple/white key funtions.
This gives the opportunity to have loads of functions with just a few keys.
Mar 20, 2010 | Panasonic Toughbook CF-73 Notebook
To use my key board with out pushing the fn button
The Fn key is used in conjunction with F3 to F12 function keys to select second function assigned to these function keys.
Why do you want not to use the Fn key on your keyboard?
May 23, 2009 | Samsung NC10-14GW Notebook
Key board not writing as stated
liklely dust on ur keyboard, use a blower....
Apr 02, 2008 | Dell Latitude CPX650 Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
