Question about Kenmore Refrigerators
I have a kenmore elite refrigerator 795.79783.901 if I turn on water to fridge the water will not stop coming out of dispenser till I shut off the appliance waterm valve
    New Friend:
  • 28 Answers
You have a faulty valve on the dispenser.. possibly just a faulty micro switch keeping the valve open.
Neither are expensive.. but getting into the part of the freezer to change them, might be a bit tricky, as manufacturers always have hidden screws, to deter the uninformed, or to cause them to break more, and then call in the professionals. (them)
Posted on Apr 24, 2017
  • 100 Answers
SOURCE: Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Posted on Oct 30, 2007
reg501
  • 413 Answers
SOURCE: kenmore elite HE 3t washer
F32 is the code for a Water Level Switch Failure.
1. Remove the top panel from the washer by removing the three screws in the top back of the washer.
2. Inside the back right corner is a round plastic box, fastened to the side with a plastic snap. In will have a wire connector and a small, rubber hose connected to it.
3. Check to make sure all the connector wires are connected and tight. Unplug washer for 30 seconds to reset it. If the cycle fails still with the F32 code, you'll need to replace the Water Level Switch.
4. If the Water Level Switch does not eliminate the F32 code, it then the machine controller may have failed.
Posted on Jul 04, 2008
SOURCE: Ice and water dispenser lock
I resolved the problem on my Kenmore Elite model 106.55616400 by removing the drip tray, taking out two screws that hold the panel, and disconnecting and reconnecting the wires from the panel to the board. Unplugging the refrigerator did not work.
Posted on Aug 06, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
Kenmore elite refrigerator water stopped dispensing from door
HI.CHECK WATER SUPPLY FIRST.then defrost fridge.if this basic fails u need to check 1-supply to valve 2-the valve itself 3-pipes 4 -microswitch.good luck ali
Jul 04, 2012 | Kenmore Side by Side Refrigerator
Water is leaking from our water dispenser. A large amount. An 8 oz cup fills up within an hour. It is coming from the water dispenser on the outside of the fridge. The ice maker is working fine but the...
Your water valve on the back of the refrigerator is plugged up, there are two sides to it, one side is for ice maker the other is for chilled water dispenser.You may be able to clean it out, if not then you will have to buy a new valve.Hope this helped.
May 29, 2011 | Kenmore Refrigerators
Water dispenser does not work
the volve for the water is might be bad need to be clean or replace the volve to the ice unit is with the water but they seperate units...
Dec 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water has stopped coming out of the filtered water dispenser
I just had this same problem and finally figured it out. The water in the line was frozen because my freezer was turned to 6 (note on inside of freezer says recommended temp is 4) so I turned the freezer to 4 and the refrigerator to 3. Next day the water was flowing.
Hope this fixes yours,
Sherry in Pittsburgh
Jan 10, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Kenmore Elite - Interior water dispenser stopped working
Frozen water tank, some of these had an insulation kit that will prevent this from happening. Make sure you have water coming out of valve to tank, if so it will probley be a frozen tank. Make sure fridge is on factory settings. If it doesnt thaw out, check into the frozen tank kit...
Jul 14, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Trio
How to remove the speaker from a Kenmore Elite Refrigerator.
Our Kenmore Elite fridge has been beeping since we bought our house 9 months ago. There's nothing apparently wrong with it, the filters have been replaced etc. Sears said it would be a minimum of $300 to replace the electric panel (and my thought was that whatever is causing it could happen again!). We were ready to buy a new fridge.
Tools:  thin spatula or hand held flat razor (for scraping paint) flat screwdriver  soldering iron
I pried open the water dispenser with a razor thin spatula (i began with just my hands). the electronics then turned off. When the dispenser came completely off an electronic board dangled down.
On the board is the word 'buzzer' with two soldered points, underneath was a round black object, obviously the speaker. My husband and decided that if we pried the speaker off with just a screw driver, it may break the whole board. So we got out the soldering iron and one at a time, heated both soldering points labeled "buzzer." As each heated we used the screwdriver to pry the speaker off the board.
The speaker gently slipped off the board into our hands. We placed the board back in its place and snapped the water dispenser cover back into place. The whole thing took 2 minutes. The electronic lights all came back on the dispenser. Everything works perfectly. There's one less beep in our house!
Dec 03, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
66 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
