Question about Air Tools & Compressors
My belluccio airbrush makeup compressor is not working properly. The green light does not come on and and I cannot adjust the air pressure to high or low as it used to, help!,
SOURCE: AIR CONDITIONING
have you checked the orfis tube also called expancion valve also posible you got a bad compresor . have been there on getting bad parts 50 years experince.
joss605
Posted on Sep 06, 2008
  • 1388 Answers
SOURCE: pressure switch out of adjustment
Before you adjust the perssure switch, make sure that the intank check valve is not leaking pressure back to the pressure switch after it cuts off at 140psi. The check valve should hold pressure at 140psi. Follow the discharge airline to the tank to find the checkvalve (either chrome or brass with large cap). To check for leaking valve, run compressor till shut-off at 140, then unplug the compressor from wall and remove the 1/4 air fitting at the checkvalve and check for leak. If leaking, replace valve and leave the pressure switch at present setting. You should be good to go. Good Luck with your repair and email if you have questions.
Posted on Apr 04, 2009
  • 103 Answers
SOURCE: how do you regulate the air pressure on FUWA AIRBRUSH COMPRESSOR
There is usually a regulator where the air coupling is. if not,just add one with some simple fittings and a regulator you can find at home depot in tool dept.
Posted on Jul 16, 2009
melvi_99
  • 387 Answers
SOURCE: Low pressure side of air conditioner reading very
very high pressure suction will cut by high pressure sensor to command compressor on/off, release refrigerant, check condenser clogging, filter drier expansion valve, or accumulator and orrifice filter and tube
Posted on Jun 25, 2010
roniecon
  • 6927 Answers
SOURCE: 1997 geo prizm the AC blows air out at 80 degrees,
What are the pressures?And the low side line going into the firewall should be cold.We need to know what the pressures are,and is the evaporator sweating>and giving off condensation?If the vents are blowing out 80 degrees,then the temp door is not moving .It is either a door actuator motor,or a vacuum that is not working the temp door,check for a bad vacuum under the hood,going into the firewall.
Posted on Aug 03, 2010
Testors Blue Mini Modelers Airbrush Compressor
Air compressors are rated for a maximum pressure and maximum output flow. Your description implies more air is going out of the compressor than it's designed flow rate. Check for a major leak at hose fittings or around the compressor. If this is an old unit, a compressor gasket could be cracked or broken.
May 31, 2014 | Ingersoll Rand - Rand Type - 30...
Won't spray
There are a lot of variables while airbrushing. If you are having trouble with a new airbrush(or one that isn't hugely gunked up) you likely need to do 1 or both of the following to get it to spray the paint:
1) Thin your paint, use the correct medium based on the paint type. Water can be used to thin water-based paints but too much will result in a bad coat and finish. You are looking for a milk-slightly thicker than milker consistency.
2) Crank up the air through the airbrush. Assuming you have a regulator you may need to turn the pressure up to get thicker paints to spray. If you are using a siphon feed you may need a couple extra PSI to recoup for what you are losing from the syphon. Make sure to check the max pressure your airbrush can handle before cranking it too high(most can handle at least 30 PSI).
Hope this helps.
Jan 23, 2013 | Airbrush-Depot Master Airbrush Model G23...
Salon tc 60 airbrush compressor won't build up over 17 lbs pressure.
Either the pressure switch needs adjusted or the compressor needs rebuilt.
Jul 27, 2012 | Hobbypet TC60 Super Quiet High Performance...
Bubbles in color cup of airbrush
I assume you have adjusted the nozzle... On my unit, there is a SMALL hole in the cap for the cups to let in air above the paint. Also OFTEN the paint must be thinned to use in an airbrush. Since you havent been able to draw water even, thinning is NOT the problem.
The airbrush aspirates the paint by Bernouli's principle, that is where there is higher velocity of a fluid, there is a lower pressure. The nozzle creates that and the adjustment is important. On mine which is a "Wren", I think by Binks there is a conical piece that the paint comes out of with a throttling needle. This has the be unscrewed to open the paint path and adjust it. The air flows at high speed around this cone creating a vacuum.
The headline says "Eclipse" but that is a gravity feed so I suspect that is the old Fixya problem of having incomplete choices to pick from.
Feb 18, 2010 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Does this dental air compressor have a oil pressure safety switch?if so, where is it located? can I find a wiring diagram
Air compressors are designed to operate many different tools. The value of a commercial air compressor is many times greater than the purchase price because of the amount of work a single air compressor can perform. Dental air compressors are some of the most reliable because of the high-quality air they supply and precision tools they operate. As a result, dental air compressors can be adapted for a number of different tasks, including artistic air brush painting
1.Disconnect the air compressor from the dental tool air supply. Pressure and air supply rate-of-flow settings are different for air brush painting than for air delivery for dental tools.
2.Reset the air pressure on the tank to a range between 15 and 20 pounds per square inch (psi). The exact operating pressure for airbrush painting will vary, depending on the application and the type of paint used.
3.Reconnect an air-supply hose and a siphon style airbrush to the compressor.
4.Fill the airbrush's paint vile with lacquer-based paints. Test the air brush and paint performance on a piece of cardboard, or scrap piece of cloth
material before beginning the painting project. Every time the air compressor is connected to airbrush, or a new paint color is loaded into the brush, a short test spray should be performed. After each test adjust the air volume, and the paint flow in the gun to achieve the desired results8_16_2012_1_32_17_am.jpg
Aug 04, 2009 | Air Tools & Compressors
How do you regulate the air pressure on FUWA AIRBRUSH COMPRESSOR
Jul 16, 2009 | Fuwa Fuwa Kutsuwa Fuwa Air Compressor MA...
Air Tools & Compressors Logo
49 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
