Question about The Computers & Internet
Motorhome house batteries were dead because five hold lights were left on. It has been pluged into ac for 24 hours and lights when turned on are quite dim. Do think the batteries have been damaged?
  • The Master
  • 4,286 Answers
It is possible the batteries were damaged but if they were healthy and not too old, they probably weren't damaged.
The in-house charger will be either an intelligent type or a low current type, both of which would be unsuitable for recharging a completely discharged battery.
The batteries should be removed and independently charged with something more suitable and in the case of a deep discharge it might be necessary to give them an electrical kick to get them started - like starting a 12 volt battery off with a 24 volt charger.
It is important to monitor the current and ensure it doesn't heat the batteries very much as that shortens their life. If the batteries aren't sealed don't be tempted to top up the liquid in the cells as the level will rise as the battery is charged.
Think of charging a battery like filling a tank - the capacity of the tank divided by the fill rate gives an indication of how long the tank will take to fill. A 100 AH battery at an average charge current of 5 amps will take 20 hours to recharge.
Realistically the average charge rate will be much less from the average battery charger and if the battery is no longer young it will take longer for the necessary internal chemical changes to take place so recharging fully is likely to take anything from a couple of days to a week.
It is important to ensure they are fully charged before being put into service again in order to avoid partial sulphation. The best method of checking is with a hydrometer but that is impossible with sealed batteries and a voltmeter provides an alternative. An accurate measurement of battery voltage can only be made when the battery has been off charge for several hours.
Posted on Apr 22, 2017
Hi , i have an Mge Evolution S 2500, it was kept away for quite awhile. I charged it for 8 hours. When i connect AC power. Light number 27 (red light) stays on & light 21(the bargraph) flashes. I removed...
Did you check them with a load because if you didn't and they are dead(possibly a dead cell) the voltage will roll-off as soon as you plug equipment into the strip.
Jan 30, 2015 | Computers & Internet
I have a portable DVD player,Yukai 700 I have charged the battery several times , but it only lasts five minutes in its dead. Once I charged it for three hours done for seven hours in the last time 24...
This means that the battery is unable to hold a charge any longer. THe only option in this case is to replace the rechargeable battery for your Yukai 700. A battery has a charge life meaning you can only charge it for a set number of times. It seems that it has already exceeded that.
Aug 14, 2008 | Mustek Televison & Video
Why does my new motor trend power house jump starter with air compressor not take a charge from the a.c. or d.c. charger?
Contact manufacturer. If still under warranty they should replace. Sounds like the internal battery is dead...there has to be a little "juice" left in the battery for the charger to have a complete circuit to charge...some of these units take 24 or more hours on an initial charge.
Hope this helps,Ron
Nov 30, 2014 | Power Center Jumpstart 11-411
After battery replacement, upon power up, constant beep with fault light full on and battery light flashing. On some trys, the bypass light will also light up. No response from buttons. Unit is...
Try and push and hold the on button for about 3 sec. This will start a manual battery test. If only three of the five battery led illuminate allow the ups to recharge the batteries for 24 hours. Battery light flashing means internal battery source not available. Check battery connection, completely power down and reboot UPS
Sep 06, 2011 | Liebert UPStation GXT1000RT...
My acer aspire starts up to the microsoft logo then turns off. i think the battery is dead because when i take out the power cord the battery light goes out. but should it still start with the charger...
If your battery is dead you can still use your laptop with the power cord connected and turned on
have you tried charging your battery for a couple of hours with out using the laptop just to see if the battery will charge and hold its charge for a while
many thaks
Jun 23, 2011 | Acer Aspire 5735 Notebook
I have my GPS pluged in and the little red indacater light is on. but the unit will not turn on it has been stored for about 6 months. does it have to be pluged in for a few hours before i can use it...
hi buddyd56
press and hold the power button for up to 15 seconds...the 6000T 3000T and the 3050 all require you to hold the power button for up to 15 second if its in the off position or the battery is dead.. most all other magellan gps will start within 7 seconds if the battery is totally drain or its in the off position.
let me know if that doesnt wok, but it works if there
is no damage to the gps like a bad screen ect
good luck
Nov 11, 2010 | Magellan RoadMate 6000T Bluetooth GPS...
How do I set the current time on the Woods Digital Timer Model#59203?
78a8604.jpgWoods 59301
Manual for 59301
Plug timer in wall for 1-2 hours so rechargeable battery charges
If display does not show after 1-2 hours, the battery is dead and timer is no good
After 1-2 hours, you can remove timer from wall to program
Press reset (R) with paper clip to clear memory
Select format: Press and hold Clock button until 12 hour or 24 hour shows on display, then release
Press hour button to change display to 12H
press Clock button and display returns to normal
AM shows in upper left corner
Set current time:
Press and HOLD clock button
While holding clock button, press hour button and minute button until display shows current time
Release clock button
Press and HOLD days button until current day shows in display
Release days button
Further instructions to set ON-OFF times are in manual (click link shown above for manual)
If you have problems, re-post additional question.
Oct 17, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Dead unit
My Quest2 has a short in it that drains the battery even when it is turned off. But the battery lasts normal 15 to 20 hours when fully charged and unit is on. Whenever the battery is completely dead, I have to place it on the charger for a hour or two before the unit will even start even though it is plugged plugged in. The battery can be replaced by the staff at batteries plus for under $60.00
Oct 12, 2008 | Garmin Quest GPS Receiver
Dell 5160 orange light
I have never found hibernation to work successfully.
Disable hibernation if you ever get it started.
Try reading the manual on how to restart for hibernation, press "spacebar", "enter" or something.
Oct 10, 2008 | Computers & Internet
SanDisk Sansa e250 MP3 Player won't charge anymore
an itrip has different charging rates than an ipod, so you fried something inside of your sandisk.
Jan 08, 2007 | SanDisk Sansa e250 MP3 Player
Computers & Internet Logo
37 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
