Question about Refrigerators
Colemach shutoff when inside ceiling filter door opened
2 Suggested Answers
rotorhed131
  • 4 Answers
SOURCE: my ge quietpower 1 will not shutoff when door is opened
The exhaust vent inside the dishwasher is twice the size of the external vent and all of that steam is shorting out your control board. In serious cases it can short out and cause a fire! It was a very poor design to say the least and should have been part of a major recall. If you get 4 years out of your machine then it is cooked! GE had to know of this p[roblem, because they installed a small rubber blanket on the inside to cover the switch board to make up for the different sized vents. This machine was designed by idiots and intentionally deceived the public by letting them on the market with a known problem. DON'T BUY GE APPLIANCES!!!
Posted on Feb 11, 2012
Bottom mount Freezer Iced up
if you have frozen water droplets on everything most likely the door was left open and when the warm air mixes with the cold air in the freezer this happens,look at the top of the door or the sides of the freezer door,also up on the ceiling where the light switch is,if there's ice there the door was left open,common problem with freezers on the bottom,you can shut down the machine,and with a hair dryer blow the hot air into the vent holes in the back inside wall of the freezer and if ice is on ceiling melt that out too.good luck.
Jul 09, 2012 | Kenmore Refrigerators
Kitchen Aid KGRA806PSS
hmmm....that interlock is dependent on a temperature sensor, to ensure that no one opens that door when it's too hot inside. I'm assuming that it's still locked, even after the temperature has dropped off?
Feb 26, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
My ge quietpower 1 will not shutoff when door is opened
There is an interrupt switch generally located in the door as part of the latching mechanism that stops the washer, yours is probably either shorted or has become damaged is some way.
Dec 16, 2011 | GE Dishwashers
I have a frost free refrigerator (MODEL #: FGTD 20V4GW2 and SERIAL #: ba00230071) yet the ice/frost builds up of the door, top and front of the freezer. Also the bottom compartment where the milks,...
if ice is on the door and ceiling and frozen water dropleats on the food packages the door was left open and the air ducts are frozen.when you open the freezer door do you hear the fan blowing,if not it could be bad or iced up,if the ice is on the inside back wall of the freezer you have a defrost problem,get back to me and tell me if the ice or like snow is just on the back wall or if the door was left open ice will be on ceiling ,door and shelves and food packages,also that's not a good model number if the freezer is on top look at the left wall up near the ceiling in the fridge section,you should see a tag there with the model number.
Sep 25, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
Is the water filter on the top of the refrigerator
on my Maytag the water filter is inside, on the internal "ceiling" , a long tubular form with a tab on front that says "push" inside is a filter cartridge.
I have never changed it as believe it will show on display when it is needed.
Feb 24, 2011 | Maytag MFI2568AE Side by Side French Door...
Were is the filter located on this model of frige we just bought it of a firend and he has lost the manual for it and we would like to replace the filter.
On my Maytag bottom freezer French door model the filter is inside, at top right tubular form on "ceiling" with a tab on front says "push". Cartridge filter inside.
Feb 23, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
The middle light on my ceiling inside the car will not turn off
there is no manual switch for this light, aside from removing the bulb.
if the light is staying illuminated, you likely have a problem with one of your door switches. are you experiencing any warning chimes like an open door? if so, look towards the drivers door. if not, look towards the passenger side. good luck!
Jul 07, 2010 | 2002 Ford Mustang
Daikin a/c FDY100LVIR N81. installed in suspended ceiling approx 2 mtrs. away from ceiling filter inlet. No filter pad provided for this inlet?. Told to attach a piece of wire to end of unit to withdraw...
Is this a new unit? Lots of units now come with no filter slot. I'm assuming this is above an acoustic tile ceiling. 24x48??? You need to have a 24×24 filter back return grill that lays in the ceiling. That way you change the filter by standing on a ladder. I'm a little confused about the wire thing but, the installer should have thought about how the return air was being filtered BUT, technically not their "responsibility." I'm guessing above the ceiling there is no duct attached to the return side of the unit??? If this were my unit I would buy a filter rack and have it attached to the unit and have my filters the unit. I'm assuming this is a business so what about your fresh air intake?? What filters that??? You need a filter AT THE UNIT. Not attached to a wire or whatever some i*^*t suggested. Hire professionals with credentials capable of doing the job right the first time!
May 26, 2017 | Heating & Cooling
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Side by side refrigerator
The ice maker is not producing ice or not enough ice
production.
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
