Question about The Toys
Can i upgrade a stock wl toys v913 helicopter to brushless
Can anyone answer my question? i want to buy a wl toys v913 brushless heli, but every site i try to order from is waiting for restocking, my queston is if i buy a v913 stock heli can i up grade it by using a brushless motor, and a brushless esc and can i use the original Receiver Board, or do i have to change the Receiver Board to.
SOURCE: heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Posted on Apr 23, 2010
  • 906 Answers
SOURCE: find charger for world tech rc helicopter skyhawk
good day,
hope this link below will help tp solve your problem.
toys
Posted on Jul 29, 2010
  • 4 Answers
SOURCE: hsp bruchless
Hi there
I have the same electronics on hsp rally monster pro. 3300kv - but 75A ESC, i upgrade it to 6000kv with 5000A lipo without any programing to the ESC . it worked fine for couple of runs but i faced wires over heating problems after that something wrong went to the ESC !!! . .
Am going back to 3300kv, but need advice of what is the higher ampers/voltage battery can i use?
Posted on Aug 06, 2010
  • 4 Answers
SOURCE: Novatech High Speed HSP Brushless 70A ESC for Cars, Buggi: wont reach top speed...
The green light wont go solid. .right? so not full speed
Its something wrong with the remote controller, not giving the full speed signal . either change both Tx - Rx crystals . or change the remote. .
but before that try to trim the throuttle on your Rx
SOURCE: Novatech High Speed HSP Brushless 70A ESC for Cars, Buggi: i need to no how to program my novatech 70 amp esc...
throw it in the garbage
Posted on Nov 07, 2010
My wl v912 transmitter will not switch to mode 2
Mode exchange: hold on the switch button and turn on the power switch "at the same time". Did you try this?
You can change rom modes 1, 2, 3 and 4.
Feb 11, 2015 | WL Toys WLToys V913 Large 4 Channel 27" RC...
My v913 helicopter took a little crash to the front and now my controller wont connect to my helly the red light on the helly used to blink to link up but now it just stays solid red
sorry Kyle but you're going to need a new circuit board for that the 913 it crashed and must have cracked or something so you can have to change hair a circuit board
Jan 03, 2015 | WL Toys WLToys V913 Large 4 Channel 27" RC...
How do I attach mjxf45 tail motor to v913 circuit board (esc red wire black wire and white wire?thanks cessnaman
Both hellicopters have the same wiring for the tail motors (white blue) and I think the same motors. Anyway the wiring for any 3 cable esc with any 3 cable motor doesn't have a standard. If you place them "wrong" the motor will not spin to the side you want and you have to make another combination. Generally on rc planes, bellicopters, cars etc the three color cables have black color for ground red for voltage and white for singnal. You may also see black , red, wellow or brown , red, orange coloring with the same meaning. These cables are used most on receivers and peripherals connections.
Oct 01, 2014 | WL Toys WLToys V913 Large 4 Channel 27" RC...
Upon initial take off my tail motor spins very fast making the helicoptor spin out of control. nose to left, tail to right. any suggestions?
Maybe it's the transmitter? Is there a trim facility and if so does it do anything? If you've replaced the control board that doesn't leave much else ( I assume the drive power to the tail rotor comes off the control board and there isn't any other servo related intervention in between)
Jun 17, 2014 | WL Toys WLToys V913 Large 4 Channel 27" RC...
My v913 does not respond to left turns. mode 2
i think it has something to do with the signal to heli from transmitter
Jan 15, 2014 | WL Toys WL V913 Sky Dancer 4CH FP...
My S107G is fully charged, I turn on and off transmitter on different frequencies, turn the heli on and off according to my instruction manuel, but the lights on the heli are on,the circuit board red led...
I have similar problem with my LS-208 heli.
Helicopter leds are blinking red/green, front white led is on, and tail leds are blinking too.
Remote controller red led is on as should be but helicopter doesn't respond to controller at all.
I followed instructions above with no success.
Anyone has a suggestion?
Regards, Yaron.
Jun 12, 2012 | SYMA Toys industrial New Syma S107 Radio...
I bought a cloud force RC helicopter and its battery runs out in 5 minutes, after a full charge. The batteries are brand new. Do you think theres something wrong with it?
The batteries have degraded. Even if you bought the helo brand new, it might have been sitting on the shelf for quite some time since it was manufacturers and Ni-Cad and Li-Po batteries have limited shelf life.
You can always replace the batteries. The stock batteries in the Brookstone Cloud Force uControl RC heli are 3.7V 150mAh, but I I suggest you seach for and buy Syma S107 / S107G Upgrade 3.7V Lithium Polymer 240mAh batteries. I picked one up for my Cloud Force and because it's slightly bigger than stock, you'll need to tape it under the body between the skids, but some people have also managed fit it between the frame where the stock battery rests. Some generic replacement instructions: http://www.micro-helicopters.net/syma-s107-battery-replacement. The 240mAh battery works perfectly and runs the chopper longer than the stock one did brand new. Aside from a year's heavy use reducing this thing's usable run-time to 30 seconds or so, this has been a great micro-heli.
Nov 21, 2010 | Brookstone Toys
My helicopter wont fly the main propellers on top of the helicopter stopped working
either stripped the main gear inside the heli or the main blades where they slide on the shaft. you should be able to buy a replacement set of blades. try that and see if it'll fly.
Apr 01, 2010 | Air Hogs Havoc Heli Helicopters
Toys Logo
37 people viewed this question
Top The Toys Experts
Paul Carew
Lawrence Oravetz
Are you a The Toy Expert? Answer questions, earn points and help others
