Question about Maytag Washing Machines
Have a top loading maytag that either leaves a soap residue on clothes also alot of lint.How can I prevent this?
  • Whirlpool
    Whirlpool Jun 16, 2017
    Hi Dixie, in regards to the white residue on your clothing, this could possibly be caused by the interaction of body soils with detergent can result in the formation of a residue that is distinct from lint but may appear similar to undissolved detergent. This type of residue has a tendency to accumulate within the folds and wrinkles of garments and may be widely distributed throughout the fabric load and on individual garments. Residue resulting from the interaction of body soils and detergent may actually be more prevalent with the use of warmer water, distinguishing it from typical undissolved detergent. Other causes if this residue could be from excessive lint or excessive detergent. We advise using an Affresh® clean washer cycle every thirty loads to ensure your washer is performing at the highest level and to use cold water to minimize the reaction with your detergent.
    Master:
  • 604 Answers
Clean everything out,drain hose etc
Posted on Apr 23, 2017
2 Suggested Answers
  • 245 Answers
SOURCE: My Maytag washing machine leaves residue (lint? soap?) on clothes
us liqwid soap us les chang filter.to meny close can trap the dry stuf.
Posted on Jan 25, 2010
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Jan 25, 2010 | Maytag PAV2300 Top Load Washer
    Hi We Have a ge front load washer and dryer and it seems that our clothes smell musty at times. I've tried leaving the door open on the washer when not in use. Could there be another prooblem??
    Try using vinegar, baking soda, or bleach in an empty load to counteract any residues left in onboard water. Also check for debris stuck in door baffle(rubber sleeve between door and tub).
    Nov 17, 2009 | GE WSXH208A Front Load Washer
    Kenmore 80 series washer leaves soap residue on clothes no matter
    After speaking with someone with trouble shooting experience in these matters, I now believe the problem lies NOT with the washer but with a bad batch of laundry detergent which fails to dissolve properly in the water.
    Mar 12, 2009 | Kenmore 22422 Top Load Washer
    Lint on dark clothes in my Whirlpool Cabrio washing maching
    sorry there right ..your not using he or low suddsing detergent ,or your using to much..as the water pumps out of unit the sudds stick to side of tub than when rinse water comes in it washes back on your clothes...i can only give you tips and something to look for...look for water not drainning fast enough ,,cut down on detergent,,wash your dark clothes first..give your unit a bleach clean about a pint of bleach..keep me posted onthejob
    Feb 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Clothing are left with lint after washing cycles
    Seperate fluffy linty clothes and wash those separately; never mix that stuff up. Also keep the dark and lights separate.I do a number of smaller loads that are in a lot of water; you get cleaner clothes and less wear. Overloads are hard on the washer and the clothes. Rots of Ruck.
    Feb 04, 2009 | Maytag PAV2300 Top Load Washer
    Maytag gas dryer taking too long to dry clothes
    Not too familliar with the gas temp either, but you should definitely take your lint filter out and clean it with soap and water. If you use dryer sheets, they can leave a clear film on your filter and it can be just as bad as a filter full of lint. Try this out, if it works, clean your filter periodically with soap and water to remove the chemical buildup.
    Jan 19, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
    The lint is not being washed from machine. All dark clothing has lint residue. How can I rectify this problem please? Currently my husband using damp cloth has to wipe over black clothing extensively prior...
    the self cleaning lint filter seems to be clogged. before you replace it try this cheap/ easy remedy.
    • run a load with no clothes on high water level, hot water and a gallon or two of bleach.
    •  no soap.
    • do an extra rinse after to make sure you rinse all the bleach away before putting more clothes in.
    the lint filter may be defective since it has always had this problem, but its worth a try.
    Jul 01, 2008 | Maytag Washing Machines
    Crosley CAWC529JQ1 top load washer LEAVES LINT ON CLOTHING
    try washing on a shorter time as this washer may have too good of wash action and the lint is fabric coming off your clothing
    add more soap powder and do not buy the cheapest soap as the soap is important in the washing cycle of your machine
    towels that are not too soiled brobably need 6 minutes at most on wash
    if this machine has a delicate wash cycle use that for tee shirts etc
    water pressure is important in rinse cycles
    do you have high pressure and water only trickles in check water inlets on back of machine where the hoses screw on
    good luck
    Nov 27, 2007 | Crosley CAWC529JQ Top Load Washer
    Washing Machines Logo
    90 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
