Question about Boating
I have a evinrude 5hp 4 stroke 2000 model will crank and run for about 2 minutes and dies out like running out of fuel. i put a new fuel pump on and still same problems
    Passionate:
    Visited the website for 10 consecutive days.
  • 83 Answers
Sounds like the carb is sticking and not letting it stay functioning correctly. Usually, this means that it is time for a carb rebuild. After you get this problem fixed I would highly recommend putting a stabilizer in your fuel to keep it from gumming up your carb when it is sitting.
Posted on Apr 24, 2017
kyo0141
  • 15 Answers
SOURCE: 92 lesabre runs 4 minutes and dies
Make sure and check your ignitioin fuse if its out the car will start it just wont stay running verry long sometimes in most cases will turn over but not start
Posted on Dec 29, 2008
SOURCE: what is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
Posted on Jan 05, 2009
greg_margo
  • 1959 Answers
SOURCE: Dies after running about 2 minutes
It's got all the symptoms of a leak in the fuel line. You may want to start backward at the tank and work your way all the way to the carb to find it but it would be surprising if it was something else. All the best.
Greg
Posted on Jun 15, 2009
  • 58 Answers
SOURCE: Evinrude, 15hp 4cycle outboard, 2000 model - starves for gas
hi obviously a fuel fault someware / when motors are winterised the fuel system is usualy emptied, this causes gaskets and diaphrams to dry out and split try it with the tank filler off /replace the diaphram in the carb and i am pretty shure that will solve the problem /nb / as this motor has stood for a time and does not do much work /outboards love work check the water pump impellor and put a spoonful of oil in a full tank of gas hope this helps merlin v12
Posted on Aug 29, 2009
  • 677 Answers
SOURCE: 4 stroke 6hp mercury outboard -brand new first
????? Was the dealer using his fuel tank or yours.Might be a blockage or contaminate in the fuel tank.Hope this helps
Posted on Dec 03, 2009
2010 150 Evinrude E-Tech. Motor was running great then just shut off. Will not start again.Could it be it needes to be reset, all 4 lights at tach light up showing good.
first bit of advice
do not use e-mix fuels in outboard engines
WHY
because ethanol separates from the fuel if not used continuously so letting it stand between outings is not good
secondly ethanol is hygroscopic which means that it absorbs moisture from the air that is going in via the tank vent and that results in corroded aluminium parts and rusted fuel tanks and outboards operate in a very moisture laden environment
now for the problem
being a late model engine , it should be a 4 stroke and like any 4 stroke engine , check the timing belt/chain, crank/cam position sensors , ignition module
it is important to check all harness connections as salt water rapidly causes corrosion in electrical connections and components
have the service agent do a scan for fault codes remember this
Suzuki out board 2 stroke motors were used in the early suzuki 4x4 cars and modern 4 stroke engines are simply car engines on end
Sep 18, 2017 | Clymer Evinrude/Johnson 5-70 Hp...
I have a 1998 model E25RMECA I NEED TO KNOW WHAT TYPE GAS TO USE IN IT. AND IF IT IS 2 CYCLE OR 4CYCLE.
I found a mixture of sites for the information
one owner of a 1998 25 hp evinrude says that it is a 2 stroke with a fuel mix ratio of 50:1 as 25:1 is a bit smokey
another site says that the recommended octane fuel rating is 87 although it might run better on 91
best advice is to find an evinrude service dealer and get the right information as the later 25 hp units are etec engine which will be 4 strokes
Oct 23, 2015 | Clymer Evinrude/Johnson 5-70 Hp...
Why my 97' f-250 7.3 powerr stroke keeps dieing while idling
The power stroke engine has several things that will cause this problem #1 crank shaft sensor AKA cam shaft sensor on crank shaft located on passenger side of engine near crank shaft pulley # 2 IPC sensor Injection pressure control if has oil in sensor replace it & wiring pigtail .#3 high pressure oil pump not up to par. #4 injection pressure regulator solenoid they get sticky. with a good scanner that has FORD enhanced software you can check all of these without leaving the drivers seat and perform running tests on injectors and test the ficm module interface with the pcm. Fuel Injection Control Module & Power Control Module.
May 02, 2014 | Cars & Trucks
Evinrude 115 v4 carbs flooding it will crank run for a sec and cut off u can crank back up and give it gas and it will run for min and flood out real strong gas smelling smoke
Hello, It is important to insure engine compression is good and even on all 4 cylinders before proceeding with any repair on any 2 stroke engine. A general rule of thumb is +/- 10% difference and 115psi and up is best for good power and idle quality. If you need a compression tester get a screw in type from your local auto parts.. approx. 25.00 will get you a good enough unit. after insuring your compression is satisfactory, I HIGHLY recomend all of the next steps. Your carbs need rebuilt. 2 stroke engines must have a very clean and updated fuel system throughout. Rebuild both carbs and acid dip them for the best cleaning, wash with water thoroughly, blow out water after washing with compressed air, inspect all holes to see light through with a flashlight, install and rebuild fuel pump, replace all fuel lines & primer bulb. Drain fuel tank and mix new fuel 50 to 1. also replace water pump impeller and lower unit oil.
Lots of work but pretty easy with a manual and will insure your engine a good running long life.
I hope this helps and there is much to discuss when it comes to outboard engines but this engine series was one of the best in my opinion. Let me know if you need anything else. God Bless
Oct 02, 2013 | Boating
1996 Evinrude 9.9hp, 2-stroke power loss.
Checked the vent cap on the fuel tank?
Check if it runs again great after pumping fuel...
Check when it drops power if both spark plugs still sparks...
You can have a bad coil or cdi...
Jul 25, 2017 | Boating
2000 Blazer Will not stay running
Wow, you seemed to have changed what I would have recommended to someone in your shoes.
If the fuel pump relay is hot, I think that there could be a crossed wire somewhere.
I would take it to an auto electric shop to diagnose problem if it's worth putting more money into it.
Jul 05, 2010 | 2000 Chevrolet Blazer
Aug 28, 2009 | Boating
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
